Octalink history??
Quoted: 455 Post(s)
Liked 112 Times
Octalink history??
Tell me when they came about and why they seem to be a thing of the past.
Thanks!
Thanks!
Octalink is proprietary to Shimano and I think it came out in late 1990s or early 2000s. I bought a road bike in 2003 that had Octalink. The interface between the BB spindle and crank was much better compared to the square taper it replaced. And it probably reduced the weight of the spindle. Octalink died when the 'next best thing' came out, external BB bearings, which allowed for a much stiffer BB and an even larger diameter BB spindle. Then that of course was dead when they came out with pressed in BBs.........
There's nothing wrong with Octalink, it just means you're probably mating it to a 8 or 9 speed drivetrain, which in itself is not bad, but now there's 11 and 12......
The dust caps were an ingenious thing that extracted the cranks. If you're buying a crank, make sure those dust caps, and especially the threads are in good shape.
Quoted: 4195 Post(s)
Liked 3,837 Times
One issue with the OS spindled BBs that also hade their bearings internal to the BB shell was the tiny balls it took to not grow the BB OD beyond the shell's ID. Bearing loads are relative to the rolling element's diameters. So 11 .250" balls have about 4 times the load capacity as 22 .125" balls do. Add that the smaller seals often didn't do their jobs well (just like tapered square ones) and you can see why some of these BB's didn't last as long as tapered square ones. Many of us shop wrenches saw these as a solution seeking a problem. There's a reason why tapered square has lasted the test of many decades and these OS spindled but inside the shell BBs haven't. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Quoted: 713 Post(s)
Liked 796 Times
I agree with Andy on the reduced service life of the Octalink bottom brackets and their cousin, the ISIS bottom bracket standard. Both sought to improve the interface between the crank arm and the spindle, while increasing the spindle diameter and making it hollow. The crank arm/spindle interface was an improvement, but the tiny bearings required by the larger spindle were not very durable or tolerant of contaminants. As a result, they usually had a very short service life.
Quoted: 455 Post(s)
Liked 112 Times
Thanks! My continuing education continues!!
SE Wis
Quoted: 2741 Post(s)
Liked 3,388 Times
I believe that 1997 with 9 speed Dura Ace is where it started and filtered down as is Shimano's MOA after that.
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
https://www.modernbike.com/bottom-br...talink-v1isyes
https://www.modernbike.com/shimano-o...ottom-brackets
Similarly...there's also 2 versions of Hollowtech cranks.....one that used Octalink BBs IIRC, and the other one everyone knows todays as their spindle-crank
Quoted: 2026 Post(s)
Liked 1,095 Times
While both Octalink and ISIS bottom brackets shared the necessity for smaller bearings, don't confuse the two designs. Shimano's Octalink bottom brackets were well made and generally had a good service life. I had them on two bikes and they lasted tens of thousands of miles and were still in good working order when replaced for other reasons. ISIS was designed to get around Shimano's Octalink patent and was made public domain. Therefore, ISIS bottom bracket were made by numerous manufactures in a wide variety of quality levels, mostly poor and subject to early failure. It's those ISIS bottom brackets that gave the whole concept its bad name.
That said, it was indeed external bottom brackets with their inherently larger bearings and somewhat reduced weight that made Octalink/ISIS obsolete.
Likes For HillRider:
SE Wis
Liked 3,388 Times
https://www.vitalmtb.com/product/gui...kset-M510,9589
Advanced Slacker
Quoted: 2761 Post(s)
Liked 2,534 Times
Self-extracting crank bolts far proceeded Octalink cranks and were provided on several square taper cranks and sold as an aftermarket part. Also, only Ultegra and Dura Ace Octalink cranks had self-extracting bolts. 105 Octalink cranks had standard fixing bolts and required a crank puller.
Likes For Kapusta:
Liked 406 Times
Yes, Octal-ink (splined) held up MUCH better than ISIS. In my experience, they work as well as square tapers. Maybe ST does last longer, but honestly they both last long enough that it is a non-issue IMO. I have many years of use on one set of Octalinks on both Road bikes and MTBs.
And on the other end of the spectrum, units like Campagnolo's AC-H, that would feel like gravel in no time on even a fair-weather-only bike.
Advanced Slacker
Liked 2,534 Times
Good point. Whereas all the Octalink splines were all Shimano, (and decent quality), square taper, being an open standard, could be from anybody with widely varying quality.
shimano made this one and the next to keep the competition from making parts for their groups. If the Octalink was a good idea it would still exist. It died because they made an error like the 10 speed hubs with inboard drive side bearings.
Advanced Slacker
Liked 2,534 Times
By that logic, anything that is not the current standard was a bad idea.
Likes For Kapusta:
Advanced Slacker
Liked 2,534 Times
I have no idea what you are talking about.
By your logic, incandescent bike lights and NiCad batteries were a bad idea because they have been replaced with LEDs.and Li ion.
3 piece Octalink was well regarded when it came out. Enough so that a bunch of other companies tried to copy it with ISIS. And it stuck around for a long time. I was only phased out by external BBs, not by a desire to go back to square taper or ISIS.
How does batteries and bulbs compare to bicycles. Look up ten good rules and rule number two..
Advanced Slacker
Liked 2,534 Times
Thanks, but I am not running around the internet trying to decipher someone’s cryptic references.
Liked 3,837 Times
Shimano is well known for shifting the goal line when competition is catching up. they have employed a patent search "department" and will change small details to have new ones issued, or just borrowed expired ones as suited their needs. This is nothing new in business but Shimano is exceptionally good and well equipped doing this. As they won the OEM spec battle with first SunTour then SRAM for many years they, pretty much, wrote the book on frame specs for a very long time. I do give them credit for also having components that work rather well the majority of the time. Still their rep for being the 500lb gorilla is well earned.
Here's my two click search for rule 2. https://acd-ext.gsfc.nasa.gov/People...ten_rules.html I could have stopped at one click but wanted to check one more site. Don't know if this is what David is referencing but I think it is good advice just the same. Andy
AndrewRStewart
AndrewRStewart
Liked 1,095 Times
Batteries and bulbs are technical devices subject to improvements and changes just like bicycles.
Quoted: 980 Post(s)
Liked 580 Times
Luckily, I was able to source an original replacement; there were 2 (TWO!) left at the time of purchase. At least I now have essentially a lifetime supply.
Ultegra 3 x 9
Advanced Slacker
Liked 2,534 Times
Stupid advice, IMO.
Cynicism is a sign of laziness, not intelligence.
Quoted: 140 Post(s)
Liked 162 Times
Most people who use or used Octalink cranks/bb's were very pleased with them, because they were well made and durable. Shimano did a very good job with their Octalink products. This was also the first generation of Hollowtech cranks from Shimano, and they generally did a very good job with that element of the design as well.
ISIS cranks/bb's as already stated, generally did suffer from poor execution of the design, and durability was generally not good.
The buzz in the bike world when big companies like Shimano went to market with outboard bearing crank/bb systems was that Bullseye's patent for this type of design had expired. This was in the early 2000's. (I believe the patent was from the late '80's or early '90's, not sure).
