Simple job turned into a disaster.
Went to simply pull the drive side crank off today using the correct puller. It was stuck on pretty tight, but I soon felt it give a little. Then all of a sudden it happened, the puller broke free and stripped out the threads. I used a heat gun and a pickle fork with no luck, I finally had enough and since the crank was toast anyway I broke out the propane torch. Couple wacks with the pickle fork and it broke free. I hated having that happen, even though they were just Blaze cranks they were mint and original to my Trek. Oh well.
And yes, the puller was threaded all the way on.
Semper fi
Semper fi
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3889 Post(s)
Liked 6,488 Times
Happened to me once too with an nds arm really stuck to the spindle. Also used heat and pickle fork and it finally gave way. At least I got it off and saved what I could.
Quoted: 378 Post(s)
Liked 1,410 Times
I have to admit I clicked on this thread to view someone else's misfortune.
Sorry. Someone had to say it, brother.
Semper Fi
Semper Fi
Mr. Anachronism
Quoted: 526 Post(s)
Liked 256 Times
HATE when that happens.
Señor Member
Quoted: 1492 Post(s)
Liked 1,095 Times
Would have happened to anyone who attempted service on that. Mere misfortune, or possibly a previous wrench's mistake. I have a Fuji that has a Mighty Tour crankset that I overtorqued on it. Nobody will be able to get it off without extreme measures. All my fault, but sometimes...
I can make you feel better. I did that to a Deore crank once by forgetting to remove the bolt first. At least I am unlikely to repeat that move.
Likes For due ruote:
Quoted: 1088 Post(s)
Liked 1,025 Times
I was smart enough to remove the bolt on a deore crank but didn't pay attention to the lack of washer; same result either way and it so sucked. I salvaged the crank by putting the bolt most of the way in and then taking it for a bumpy ride and standing a lot, took a few miles but it worked its way loose. Tightened the bolt a smidge to finish the ride and still be able to take the crank off with a rubber mallet.
Likes For Russ Roth:
Quoted: 1079 Post(s)
Liked 1,899 Times
I managed to do that to a DS Tricolour crank by not removing the little magnetic protector cap on my extractor tool. [facepalm]
Quoted: 1944 Post(s)
Liked 2,164 Times
I forgot to remove the washer removing a Sugino crank and was trying everything, including a hammer on the puller. I didn’t strip the threads, but when finally gave up took the puller out, I noticed the deformed washer and the compressed aluminum. I still have the crank arm but haven’t re-installed it on anything.
Stupid, stupid, stupid.
John
John
Bikes: Numerous
Quoted: 1678 Post(s)
Liked 3,098 Times
”Simple job turned into a disaster”
Story of my life.
To look on the bright side you got to torch something. Similar story, a couple of weeks ago I was removing a rusted in dropout screw. I PB blasted it and felt it give way as I turned the screw but it was really the head twisting off.
Story of my life.
Likes For Spaghetti Legs:
Quoted: 1627 Post(s)
Liked 630 Times
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,296 Times
I've come very close to both these goofs. Each time I was saved by the thought "Waitaminute; I've had this crank off before... there's no way in hell it should be this hard to pull, because I always use fresh grease and I don't crank a crank down all that hard when installing." Don't force it, unless you're truly desperate.
There is an easy way to get such arms off before any damage occurs to the crankarm or to the remover tool:
Leave the puller in place, fully tensioned, then put the cranks horizontal and jump on the pedals hard.
Turn cranks 180-degrees and jump again.
Re-tension the tool, noting if and how far that the tool driver rotates.
Repeat the three steps above until the crankarm comes right off.
If the crankarm threads are stripped:
Remove the bolt and apply LocTite to the inner/outer spindle/bolt threads.
loosely hand-tighten the bolt, then back it off a full turn and half. Allow Loctite to cure (heat greatly accelerates curing).
Apply penetrant to the spindle taper.
Jump on pedals as above, or, that failing, go riding in steep terrain (bring a bolt wrench to monitor progress and to adjust the bolt as needed for ride home).
Likes For dddd:
John
John
Bianchi Goddess
Quoted: 2930 Post(s)
Liked 2,927 Times
I did that an Ofmega crank on a Bianchi Trofeo once. I wasn't really intending to reuse the cranks but still it stunk.
Stein used, or maybe still does, make a tool for this but when I was thinking about one years ago it was pretty spendy. It retaps the threads oversize and then you install their oversize self extractors. One down side I saw, aside from price, is you kind of need to do both arms or atleast use a matching extractor on the undamaged arm.
Sugar "Kane" Kowalczyk
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
i think i have a blaze crank off my 91 trek
Likes For nomadmax:
Friendship is Magic
Bikes: old ones
Quoted: 26425 Post(s)
Liked 10,381 Times
But anyway, that's for the future. There's a repair you can do using an oversized crank puller and a repair insert from Stein.*
*edit: I see this tool has already been referenced above.
But it's not cheap to buy the tool. I got one to take advantage of all the relatively nice stripped out cranks that were showing up at the co-op here for a while, but it's probably not worth buying one for the occasional disaster.
Quoted: 350 Post(s)
Liked 276 Times
So should crank arms be pulled periodically and a light coat of grease be reapplied to the spindle as a preventative measure against such disasters?
To answer a couple questions and remarks, I did have the puller threaded all the way in. I really didn't crank any harder than I have before on other cranks without issues. This was all done by hand, Ive had to use a rubber mallet in the past without stripping the threads. It was a total surprise to see the puller just fall out of the crank arm. I tried using a couple pullers that I have, but the Blaze crank spider wasn't even enough for the puller to sit straight with the axel. I was trying my best to save the crank so a torch never came to mind until the threads were toast. Lesson learned on this one.
Semper fi
Semper fi
Likes For sloar:
Pedal to the medal
From my limited knowledge, stuck cranks are a result of over torquing not seized interfaces so I don't think grease would help. Others may disagree and I believe Phil Wood recommends greasing their bb's from what I recall. YMMV
señor miembro
Liked 6,488 Times
What lesson, though? Sounds like you did everything right. When we pull cranks, we just do it like we always do it. We never think that an arm is super stuck to a spindle until it doesn't come off. One bad case out of a hundred seems ... tolerable.
A bigger issue is to avoid making it a lot worse (like a trip to the ER) when using a ton of force, a heat gun, and a pickle fork. A lot can go wrong in that environment.
Quoted: 230 Post(s)
Liked 18 Times
I've only had this happen to me once. I still have the bike and the threads are still stripped. I just remove the arm, cup, bearings and spindle as one unit now. Not losing any sleep over it.
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,868 Times
I read this thread earlier today, was silently glad it wasn't me, and went about my business. Then tonight I decided to pull the crank on a bike I bought recently to regrease the bottom bracket. I didn't get as far as the crank puller before the suffering began. The drive side dust cap came off very easily as it should. The NDS dust cap on the other hand...
The hex hole was rounded off before I started. I had no luck with a screw extractor. I drilled holes for a pin spanner, which gave me really good leverage, but the cap refused to budge. So I cut a slot to try a flathead screwdriver. Then I hit the edges of the slot with an old dull chisel. Then I used penetrating oil. Back to the pin spanner, I got it to make a quarter turn, but it would go any further. Finally, I got out the heat gun and went back to the pin spanner. Finally, it started to move under near as much force as I could manage. It took about a turn and a half before it started to loosen up.
How in the world do you get a dust cap on that tight?
But it finally came out. The crank came off easily for me. Neither cup shows any signs of being open to moving. The lockring at least came off easily. Now, penetrating oil and sleep. Maybe it will feel like coming out tomorrow.
My Bikes
My Bikes
Likes For Andy_K:
