Backpack...New & Slightly Improved
Quoted: 1364 Post(s)
Liked 1,677 Times
After a comprehensive internet search including in-person evaluations at local stores I decided to replace my 7 year old backpack with the same model...a Swissgear 1696 ($59.99 from Swissgear.com)
https://www.swissgear.com/swissgear-...RoCeAEQAvD_BwE
I am used to the pocket and compartment layout which works for me (and is very similar to the Eastsport packs I had used previously). And the grommet arrangement is integral to the system I worked out for securing it to my back racks.
The Swissgear 1696 was incredibly tough hardy and secure for all seven years of all-season commuting, sun, snow and rain (with a plastic kitchen bag in the rain). The only issue was the side grommets which needed replacing, but I was using them in a manner for which they were not intended. Inexpensive press-to-install plastic grommets from the camping store replaced them as they failed.
The most used zipper began failing to keep the zipper teeth fastened, and while this is usually fixed by replacing the zipper slider I was told by local repair shops, the problem was actually some teeth separating from the fabric under a valence flap...and that was not worth repairing on a 7-year-old bag.
The new bag arrived yesterday and is identical except for the addition of a hanger loop at the top.
Although the bag has some reflective white piping, I added white reflective tape to the rear panel, same as before, but this time I added a strip of black and yellow caution tape to tie it in to the reflective tape of my main bike, and my helmet of the last year.
I woke up this morning with an idea to hopefully alleviate grommet fatigue...I made loops from some nylon camping cord and pushed them through the grommets, the knots keeping the loops from coming through. It's a simple elegant deployment that works with larger caliber clips than cannot fit through the grommets themselves.
It feels a little silly to get so excited about a new backpack, but with all that is going on in the world right now at the end of May 2020, it is nice to be able to not have any disruption to my backpack "system", especially since I have been fortunate enough to return to my usual, daily commute three weeks ago. I don't know how long it will last, but my wish is that everyone whose lives have been up-ended by Covid-19 be able to return to their old commute, or a new commute, or find a way to continue cycling in a regular fashion.
Black and yellow caution tape, helmet, bag, bike and fender.
The new loop.
The new D-clip arrangement.
The old D-clip setup.
How I carry my bag on my back racks:
The new loop.
Grillparzer
Bikes: Surly Cross Check
Cool bag! I like the built in attachment points. I use a Maxpedition Falcon II. Bought it about seven years ago and figured I would use it until I wore it out. So far I've broken one belt clip. It is going to outlast me.
Quoted: 18373 Post(s)
Liked 4,508 Times
I have a couple of SWISS backpacks that I like. Great bags, good size, and durable.
I am a bit disappointed in color choices (many brands). For cyclists, and even pedestrians, bright colors are important. Yet, so many brands like black and dull colors.
The most common pack that I take is an old Camelback Mule. I think the bladder went bad a while ago and I haven't replaced it (it makes a nice pocket for papers & etc).
Mine is similar to this one. Unfortunately discontinued, and now getting well worn.
The size is small, but great for my needs. I like the two open top external pockets/compartments. And, I often have had way more stuffed into the pack than it was originally designed for.
I'd probably move the tiedowns around a bit. I never use the belt as a belt, but use the straps periodically, so better positioning for the two long straps would be good.
Liked 1,677 Times
I think I actually saw that bag a one of the stores. If it had side pockets or a side bottle holder, I might have bought it. Big, roomy and tough!
Bikes: Lynskey GR270
Quoted: 115 Post(s)
Liked 69 Times
Cool setup!
Arkel makes a pretty nice Backpack that you can install on a rear rack.
https://www.arkel-od.com/bug-commuting-bag
Liked 1,677 Times
Cool setup!
Osprey makes a good cycling specific pack that i use regularly, forgot the model but Osprey doesn’t have many cycling specific ones so its easy to search.
Likes For GeneO:
Quoted: 5997 Post(s)
Liked 956 Times
Talking about Swiss gear. I have a vintage Swiss Army backpack, it's kind of hollow at the bottom of the backside and there's a wide tough leather strip from side to side that rests on the lower back. Somehow this makes the weight magically disappear. Best backpack design ever, at least for my posture.
Liked 1,677 Times
It sometimes feels like the bag may fall off to the side, but it never does, even when reaching for the downtube shifters.
Likes For BobbyG:
Liked 956 Times
I wear my back pack when riding my rackless old road bike to work. I leave the straps long and let the bag rest on the small of my back, just above the tailbone. Not only does that keep the bag and it's weight from pulling on my shoulders, but it allows for air circulation along my upper back.
Likes For Stadjer:
