Does anyone build their own wheels anymore?
Quoted: 3459 Post(s)
Liked 1,465 Times
Usually when I build up or true wheels, I substitute red wine for the beer. But I suspect that is solely personal preference.
Likes For Tourist in MSN:
Quoted: 671 Post(s)
Liked 49 Times
What sort of touring wheels only cost $20? No need to re-tension/re-true? Of course with a pair of wheels that cost over $500 just for the parts, who is worrying about saving ~$120 for pro building fee? Wheel building has a steep learning curve & the tools to make it easier are expensive: Park pro truing stand + centering gauge + tension meter is ~$450.
Quoted: 4806 Post(s)
Liked 3,928 Times
I've been known to buy sale wheels but like pdlamb,they are projects, Now I am light and kind to wheels but that also means that stock wheels with 14 gauge spokes beat me up. They're not really "mine" until I re-lace them with much lighter butted spokes. It is an excellent way to get good hubs and rims.
Quoted: 1949 Post(s)
Liked 2,010 Times
I've been building my own. A truing stand makes it easier and if I only had a fork to build wheels on, I wouldn't swap rims/hubs as much as I do. I also have a Park tensionometer which I use after I tension by plucking for a final examination which tells me what I already know: it is close enough. My dishing tool is a piece of Luann and a reciprocating saw blade I pinch against it at the center. It is super easy to adjust and works fine. I made a nipple driver from a cheap screwdriver blade that I can twist/spin to get a build started or disassemble one. My second hand wheels are rebuilt by backing off all the spokes to the initial lacing point and then retensioning them. I imagine a much better ride on the rebuilt wheels--most noticeable on high speed descents.
Quoted: 18375 Post(s)
Liked 4,510 Times
Off and on I'll build or rebuild wheels. So, some I get are good used wheels. Some I've built.
If you're wanting something different like a quality dynamo, then a custom wheel may be the way to go whether you build it, or get it built.
I've used a homebuilt truing stand for years. I've finally splurged and bought one. Hopefully it will last my lifetime, and the lifetime of whoever inherits it.
Plus... skills like replacing broken spokes both on the road and at home.
Quoted: 2482 Post(s)
Liked 2,953 Times
Just did a search, and found a very long thread the topic of wheel comfort on another forum with a ratio of about 20 skeptics to 1 believer. Here's what the late, great Jobst Brandt (who had worked for years as an engineer designing suspension systems for Porsche) had to say on the subject:
Considering that spoke elasticity accounts for about 1/100 the radial
(vertical) motion of the hub (in a 36 spoke wheel) with respect to the
road and that differences among wheels varies as the number of spokes
in the load affected zone, the person who can feel this would need to
be able to feel a bump when riding over a sheet of copier paper
(0.003").
I do & did.. My touring bike wheels built in the 80's are 622 '700c' specs: tandem like..
both wheels on this:
Liked 3,928 Times
I've read and heard claims made about differences in comfort as a consequence of spoke diameter in the 50-plus years that I've ridden racing bikes, but I've never experienced such myself.
Considering that spoke elasticity accounts for about 1/100 the radial (vertical) motion of the hub (in a 36 spoke wheel) with respect to the road and that differences among wheels varies as the number of spokes in the load affected zone, the person who can feel this would need to be able to feel a bump when riding over a sheet of copier paper (0.003").
Ben
Liked 2,953 Times
I know. I've been reading that a long time. And I have also observed my lighter spoked wheels are more comfortable, more fun to ride (and last longer). I'll keep doing it like I will anything that experience shows me works better than what the "experts" say. (Started riding sew-ups 47 years ago, lightly spoked ones 44 years ago.) I've ridden more than a few rides where I noticed I was getting beat up more than usual, just wrote it off to it being a bad day, then noticed I was riding a straight gauge wheel when I hung the bike up.
Ben
Ben
Liked 1,465 Times
When someone says that their thinner gauge spokes give a softer ride, I have no clue if they can feel it or if it is just imagination.
But this is the touring forum. I have toured on tires that are 37mm, 40mm, 50mm and 57mm wide. I can assure you that with the wider tires and bigger footprint on the ground, you can't feel it. My rando bike uses 32mm tires, I doubt that you could feel it with those, I know I can't.
Now if I was on 23mm tires or something like that, maybe I would think I could feel it, but I would probably have to be on a stiff Aluminum frame to feel it.
When I used to use tubular tires decades ago at over 100 psi, I had those wheels on a really comfortable Columbus tubing frame, and I am 100 percent convinced that it was the frame that gave me an acceptable ride, had nothing to do with the spokes.
Quoted: 18413 Post(s)
Liked 15,536 Times
Quoted: 671 Post(s)
Liked 49 Times
“Going out of business sale“ wheels. They are decent wheels. 26” Rhynolite rims, Shimano disc hubs, straight gauge spokes. Not the lightest, but plenty strong. The regular price was $80. The mechanic put them on the stand and they were true, and didn’t require any adjustment. They have held up very well under daily commuting and touring. $68 for 4 wheels is almost a steal.
Quoted: 753 Post(s)
Liked 737 Times
I'm still on the steep side of the learning curve. Last year I took a store bought rim down to zero tension and back up to full tension and true. Most of the parts for my first full build, a 700c SA 3speed wheelmset for "Rough Stuff" are collected, but the consecutive hours to focus on a project are in the distant future.
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,218 Times
Stuart Black
Stuart Black
Likes For cyccommute:
Quoted: 2236 Post(s)
Liked 1,314 Times
I will probably take the plunge this winter after getting a local quote to build a set of fat bike 29r wheels at about $1000, not including the hubs - that I had to source myself. WTF? If I have to buy the hubs , why not the spokes and rim too and do it myself.
Sometimes living in Canada sucks, as our market is so small that anything out of the ordinary can't be bought (in house) or costs a fortune.
Thats my only complaint about Canada though.
Clark W. Griswold
Quoted: 4353 Post(s)
Liked 3,992 Times
I personally don't build my own wheels (well one) but I do have my master techs build them. I want to get a truing stand and start doing stuff on my own as well just to truly learn and practice. I am always for custom built wheels.
Quoted: 137 Post(s)
Liked 81 Times
Hello all!
I know that wheel building is a dying art and to do it well you need to use the proper tools which is a bit of an investment. Does anyone build their own wheels in their own set up space? If you work in a bike shop I figure learning to build wheels is part of the training and it's easier with all the tools at your disposal. I feel that wheel building is part art and part science and would like to learn but I don't have the space and I can't justify wheel building one wheel every ten years or so. The cost of investing in the equipment is prohibitive for me...Thoughts?
Quoted: 671 Post(s)
Liked 49 Times
I see many complaints about this but don't quite understand the cause. There are some tariffs but also in the US. 38 million population would seem big enough that distributors could stock the majority of bike stuff. Maybe there's some sort of secret bicycle cartel.
Bikes: Basso Loto, Andre Bertain, Schwinn Madison, Litespeed Unicoi, Easton full sustension, Macau non-suspended MTN, Merlin Agilis, A-D Superlicht, Daccordi Piuma, Scott CR1 (former owner Thomas Frischnecht), Van Diesel CX, Alan Top Cross, Scattante CX, Ri
Quoted: 10 Post(s)
Liked 15 Times
Hello all!
I (personally) do not build wheels. That said, i have 3 sets of custom, hand built wheels. All 3 wheelsets were actually less expensive than anyThing factory built. Also, the wheels are much more reliable and maintainable. Finally, i like supporting local small business. See Mill City Cycle on facebook.
RidesOldTrek
A spoke key expensive?
That's pretty well all you actually need to build a wheel, and you could even use a small shifting spanner if you were very patient.
The frame or forks can be used to true. Dishing = 3 cans on a flat table with some coins as a height gauge. Little spanner to tap spokes check for even tension, or if you want to be fancy, a phone app.
This is true, all you really 'need' are the spokes/hubs/rims, a bike frame and a spoke key, a willingness to learn, attention to detail, some patience, and perseverance. There are plenty of great resources out there: wheelfanatyk.com is great, and Roger Musson's book is very good, and I'm sure there are other great resources out there, along with plenty on youtube that are done by clueless idiots. Stick with professionals.
I built my very first set as a college student in about 1981, I had just bought Jobst Brandt's brand new book on wheelbuilding (also a great resource, my hardcover copy is a First Edition), and that's all I had, because really that's all I had available to me. No internet, nobody to show me how, no bike shop giving me guidance, no dishing tool, nothing but the pure will to do it. I know I just bought a full box of all-the-same-length spokes. Not ideal, but it was cheaper, worked, and I rode those wheels thousands of miles of touring in all kinds of conditions and they stayed true enough for me for years. (I am NOT recommending all-same-length spokes now, plenty of sources to get what you need )
It's good to do it this way for your first set or two, because it may sound fun and romantic to build wheels but you may discover you don't have the knack or it's just not your thing. That's OK, we can't all be good at everything. I bought my current truing stand from a guy who fit this description.
It's very rewarding, and I highly recommend it!
Quoted: 1188 Post(s)
Liked 1,154 Times
I haven't built that many sets in my life because I tend to stick with a bike for a long time, I am working on my fourth set, with a few more in the queue, but...
And don't even think about using spokes like the Sapim Strong on your first wheel.
Quoted: 8 Post(s)
Liked 6 Times
For a dishing tool I used a straight length of timber, longer than the wheel rim diameter. Screwed a short Hex Head in the centre along the length. Then screwed two long Hex Heads in to match the diameter of the braking surface, measured out evenly from the centre screw.
The long screws must be screwed in at exactly the same height. The centre screw can be adjusted in or out to suit the dish you want.
I built a set of wheels with H+Son Architype rims, Campagnolo hubs and DT Swiss Competition spokes for my 91 Concorde Aquila.
No special tools or stand.
Very satisfying to build and ride.
