Small rear sprocket skips under tension
Hi,
I have a 1970 Schwinn Continental for which I have upgraded the rear derailleur to a GT400 from a GT100. The only issue I have is that if the chain is on the smallest rear sprocket and the pedaling pressure is great (when I really should shift to a larger sprocket) the chain skips over this smallest sprocket. I shift the rear derailleur to a lower gear and then there is not the skipping. I do not think it should be skipping in any condition. Am I wrong? I just want to make sure I have everything adjusted correctly. I just restored the entire thing from the rust bucket it had become over the 50 years I have had it. It has gone from kid treatment to antique treatment as I have become an antique as well.
Thanks,
Bob
Purchased May 31, 1970 with my newspaper route money. Celebrating its 50 year and Schwinn's 125th anniversary with complete restoration.
Thanks,
Bob
Bikes: 2016 Fuji Tread, 1983 Trek 520
Quoted: 675 Post(s)
Liked 741 Times
Did you replace the chain at the same time as the rear deraillieur? Is the freewheel new? It's unusual in high gear, but a new chain often jumps on an old freewheel.
If it's an old chain on a new freewheel, check the chain for "stretch" and twisting damage.
Edit; By the way, congratulations on your project. I had that bike in Chicago. I got it used in 1975 (high school graduation), sold it in 1982 when I got married, and my wedding present was a new bike. Mine was yellow.
Dangerous Old Man
New derailleur, check alignment of hanger, reset the indexing high and low, then adjust the cable for smoothness. Sounds like your indexing is off a bit, that is why your chain is skipping in the small ring. It is to be expected with a new derailleur, takes a bit to get it adjusted right...
Really Old Senior Member
Worn chain OR cog will cause skipping. Worn chain AND worn cog might not.
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
Thanks. I replaced freewheel with a much less used Schwinn Approved one of the same era (Schwinn Approved Model J Freewheel 5 speed 14 - 28, from a Model G) The chain is new. That helps me to understand that it is perhaps a consequence of what I want to do---have period parts. The small sprocket does not skip unless it is under tension that warrants shifting to a lower gear. Your response takes the burden off of trying tweaks in other places that would not help at all. I have the original chain but it was used with the Model G---which has rounded teeth!
