Zipp rims a bit noisy
I have zipp rims and I use tubed rims as just i find more easier
due to the design of the rims i use the 60mm stem tubes. which being so long do rattle a little bit on bumpy roads.
i was told not to use those little tube rings that u can screw on to your tube steem.
What else could i do to reduce the rattle? thanks
Quoted: 20810 Post(s)
Liked 9,456 Times
There are various stickers, store-bought or home brew, that you can put over the valve hole to keep the stem from rattling.
Likes For noodle soup:
Quoted: 850 Post(s)
Liked 344 Times
Alternatively, you can do what was suggested above and use tape. I used masking tape. Any thin tape should work. You don’t need to wrap the valve symmetrically. Adding tape to just one side is enough.
Liked 9,456 Times
I think some people are afraid of crushing the carbon. But the lockring is integral to tubeless setups, so I think you can be assured that the lockring will not damage your rim. If it bothers you, try to find a rubber ring that TL valves usually use.
Likes For rubiksoval:
On Your Left
Quoted: 3004 Post(s)
Liked 2,433 Times
I have 303s and use zipp tubes and never a rattle.
