I got TT brake levers for my bull horn bar. How should I route cables to look pretty?
How should I route this cable housing?
im using TT brake levers on my bull horn. It looks like the cable hole is on the top. I was hoping to route it underneath the bar tape for cleanliness, but I don’t think it’s possible.
any thoughts on making it look pretty?
mechanically sound
Is it possible to ditch the housing caps for a flatter transition?
Likes For Scrodzilla:
Bikes: United Motocross BMX, Specialized Langster, Giant OCR, Marin Muirwoods, Globe Roll2, VROD:)
Quoted: 238 Post(s)
Liked 404 Times
You don't want to "force" the angle of cable too much or it will affect cable response.
One of the reasons why I choose the Tektro bar-end levers is because they route the cables on the underside. Also, they're easy on the wallet and they came in black
Likes For Speedway2:
Quoted: 238 Post(s)
Liked 404 Times
I need to check my eyes for Rx glasses......the cables route along the under-side of the horns(from the Tektro RX 4.1 levers). I then routed the housing under and inside the bar. The cushioned/cork bar tape does a great job of "hiding" the cable.
bill nyecycles
Quoted: 789 Post(s)
Liked 350 Times
I used to have cane creek TT levers, these: https://www.amazon.com/Cane-Creek-Tr...reek+tt+levers
and they were great and easy to work with because the cables are routed underneath.
those ones you got are kinda weird!
Clark W. Griswold
Quoted: 4335 Post(s)
Liked 3,958 Times
SRAM S500 levers always. SRAM tends to have some of the best levers in the biz in terms of comfort and good looks.
thanks! That looks pretty sweet. I’m trying to get in touch with Soma, but I think I’ll give up. Soma has been pretty awful with communication and tech support.
Your cog is slipping.
Besides, it's not their fault you bought the wrong levers.
Like just about every company in this industry, Soma is extremely short staffed and under a tremendous amount of strain due to Covid-19. Have some understanding for the situation and stop taking it personally.
I'm not taking it personally. If they are too busy, I might give up on trying to get their support. It's not a big deal. Stop making assumption that I'm taking it personally. Their communication has been pretty awful. I've asked couple questions, not related to this lever issue, in the past few months, and I just got forwarded to a non-soma email address, and then nothing happens.
I bought the wrong levers? Oh, you mean, the poorly designed levers? I purchased what they posted. They didn't fully disclose the unusual design of the lever. I simply trusted their reputation, and perhaps it's my fault for trusting them.
Also, I don't understand how that justifies anything? Are you saying that because I bought "wrong" levers, I don't deserve any customer service? What do you think I asked in the email? I simply asked how they routed the cable when they went through the design process. I think that's a fair question. I'm a product designer, and I should definitely be able to ask such question for anything I've ever designed. I'm patiently waiting, but at the same time, I highly doubt that they will ever respond to my email. That's the reason why I posted here, and I'm probably moving on to different levers.
Quoted: 238 Post(s)
Liked 404 Times
Op....return the SOMA's and buy the Tekto's @ $30 or the SRAM 500 TT @ $70. Both route the cable underneath........
ooohhh the sram one is a beauty. Do you happen to know if that’s routed internally or externally? I’ve seen some TT brake levers that are wired internally, which would require handlebars with wiring holes.
Newbie racer
Bikes: Propel, red is faster
Quoted: 1575 Post(s)
Liked 1,569 Times
I jumped in here simply because I saw the letters "TT".
I hope it works out for you either way. But, around here most folks I know that own something like this bought a super basic alloy TT-bike base bar. Often just the round ones that perk up at the brakes like yours. TT bike base bars can almost have the exact same bar shape you have there, but the brake cable routes internal and exits the bar underneath and near the stem.
They can be really cheap too. I've seen alloy "aero" base bars like this, with the "tilt" upwards at the end like you have there......for $70. Then you can run TT bike brakes with the cable run inside.
A clean option.
I own Selcof TT brakes bought through Planet X. Internal cable run.
https://www.planetx.co.uk/i/q/BLPXAE...t-brake-levers
Not fully internal, but would use internal cable brake then exit bottom of bar there in the pics:
https://www.racycles.com/equipment/c...SABEgIdwfD_BwE
A Deda Crononero low rider would fit the bill. Almost all internal, cheap, and same shape you have almost.
A clean option.
Quoted: 2952 Post(s)
Liked 3,106 Times
I have some of those. I don't know why you'd get anything else unless you wanted CF to save every last gram.
Quoted: 238 Post(s)
Liked 404 Times
The Sram 500 TT are routed internally. You could always drill a hole in your handlebars and fish the cable thru....
bill nyecycles
Quoted: 789 Post(s)
Liked 350 Times
Dude just get these like I mentioned earlier:
Cane Creek BRAKE LEVER CC TT/BAREND 200TT BK/BK 200 TT Levers https://www.amazon.com/dp/B000R9E4C4..._wz-aFbMW4WFW7
they route under the bar, and externally. I used them on my bullhorns and was just able to wrap the bar tape around the entire cable length from the bar end to the finishing tape.
Here is my bike with said levers and wrap: https://flic.kr/p/nUWrdf
Clark W. Griswold
Liked 3,958 Times
I decided to keep it cheap, so I found the cheapest pair on eBay. Thanks for the help everyone!
Likes For curieux88:
Quoted: 238 Post(s)
Liked 404 Times
curieux88....turned out great! The chrome levers works with the rest of your bike.
Sorry to come into this thread so late, but I installed these Soma "Pursuit" brake levers on a Soma "Urban Pursuit" bull bars on my Poseidon SXL-Expressway single-speed. I faced the same dilemma about the cable routing not flowing well under the wraps. However, I found that the cables work well exposed. Although this approach may have more aerodynamic drag than keeping the cables under the wraps, I think that the lower cable resistance and better responsiveness makes up for it. I hope that the original poster found a solution to this issue.
