Zip Ties on New Bike
I’ve been out of cycling for almost 20 years and bought a new Marin Muirwoods from a local bike shop. Once I got home I noticed zip ties are used for holding cables in place. I understand that for $800 it isn’t a top of the line model. However, I am a little surprised at using zip ties for holding cables is normal for this price range. Maybe it is, I do t know. Is it?
I'm the anecdote.
Bikes: '12 Schwinn, '13 Norco
Quoted: 1110 Post(s)
Liked 1,176 Times
Do those zip ties go through bosses or around a frame tube? I think zip ties going through bosses are great. Good zip ties will last a loooooong time and being used like this makes cable maintenance/changing easy breezy.
Old Dog, New Tricks
If you ever have to replace one, make sure you get the same thick sized zip-ties. I replaced a missing zip-tie for the hydraulic brake tube and got a serious kink the nearly cut the hydraulic tubing-- the narrow zip-tie I had used as a replacement was cutting into, and kinking the tubing. Luckily, a mechanic caught the hazard during a tune-up, and an on-the-road disaster was averted.
Mother Nature's Son
Quoted: 853 Post(s)
Liked 1,436 Times
That is pretty normal now. Are they mounted on a sticky back?
The zip ties go through bosses. I’m sure they’ll last a long time. I wouldn’t have noticed if one the ties wasn’t too large and unable to grip the brake fluid tube.
Likes For DwightChris49:
You’re right. This would have been a good thing to notice before I paid for it. I was so excited to actually fine a bike in my size I may have bought it missing a wheel.
I've got the 2017 Muirwoods in all black that i've re-geared and converted to a grocery/hauler. It has the same zip ties for the housed cables and hydraulic lines.
On Your Left
Quoted: 3004 Post(s)
Liked 2,433 Times
Likes For GlennR:
Pretty standard on external hydro rake hoses saves bleeding new systems when building the bike. You can also get little pincer "C" clips
https://www.worldwidecyclery.com/pro...EaAtJ9EALw_wcB
Likes For wsteve464:
Quoted: 6963 Post(s)
Liked 10,963 Times
One of the wires on my Di2-equipped bike is held to the frame with a very small zip tie. And that bike cost a bit more than $800. About 10x more.
Doesn't bother me a bit.
Likes For Koyote:
On Your Left
Liked 2,433 Times
Many times a few zip ties are placed as spacers so the wires don't rattle inside the down tube. We don't have that probel with Sram eTap
Clark W. Griswold
Quoted: 4353 Post(s)
Liked 3,993 Times
Wait they are using a product designed to tie cables together to do just that? How dare they!
Personally zip ties don't really bother me unless uncut but with a good pair of nail clippers you can cut them easily and cleanly.
Yeah... it was just a question. I got the point, it’s a normal thing. Gotcha, understood. Thanks.
Sunshine
Quoted: 10963 Post(s)
Liked 7,490 Times
The little plastic C clamps that can hold housing and hoses are, to me, worse than zipties because they too easily unhook from the cable guides.
Just make sure the zipties are attached so the cut end us facing down/tucked under the hose. If the cut end is exposed, it can rub against a leg and cause annoying scratches.
Yes it seems low quality to ziptie housing and hoses to a frame, but its common and works well.
Thank you. In a former life, I worked with cables and made my own looms. I carried an extra nail clipper for this exact purpose. I also remember when I came across looms that weren’t trimmed. Ouch.
