Brake Pad shapes and sizes
The dropped
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules (sold) : 1966 Schwinn Deluxe Racer (sold)
Quoted: 1739 Post(s)
Liked 1,014 Times
I have a question there may not be an easy answer for. What, besides mounting post treatment (threaded or smooth) and pad thickness (or expected caliper travel) differentiates the various styles of rim brake pad? I'm only concerned about shape, not compound.
As an example, I have 2 pair of Kool Stop eagle claw 2 pads with plenty of life that were too thick for the low profile cantilever brakes and wider rims for my touring bike. I recently acquired a Raleigh-built Hercules from 1960, and a Schwinn Racer from 1966 which need new pads. So what's stopping me from using the threaded post Kool Stops I pulled from my tourer on those single pivot calipers?
SE Wis
Quoted: 2747 Post(s)
Liked 3,398 Times
If they fit, nothing. I run a pair on the front of my 84 Gran Prix
Here is the Range.. Kool Stop International - High Performance Bicycle Brake Pads Since 1977
a more recent design..
The dropped
Liked 1,014 Times
Thanks! You're using eagle 2 pads on your Grand Prix then? I'm guessing that pad shape is influenced by expected conditions, and Kool Stop added innovations like their plow tip to cope. I expect that you don't want to use a flat-faced rectangular block for harsh conditions, but using a plow tip for less challenging conditions isn't a detriment.
What I have found with Eagle Claw pads , is, on forks, the long , leading end is between the fork blades, facing back,
so the QR opening of brake calipers is ineffective.. I then must let the air out of the tire to get the wheel out..
SE Wis
Liked 3,398 Times
Yep, the back is inside the fork legs and a tight fit. My bike shouldn't need the wheel removed unless it's flat.
The dropped
Liked 1,014 Times
The dropped
Liked 1,014 Times
You must be using a wide tire on a narrow rim. Usually the brake QR does enough to squeak the wheel out, when inflated. You're not wrong about them hanging up inside the fork legs though. I can measure, but I think I'm only reducing the caliper distance by 2mm (1mm per side) by using these over the installed Weinmann pads.
Quoted: 4806 Post(s)
Liked 3,931 Times
My take (and experience) is that except for clearance issues (tires, fork, etc) I cannot tell a difference between pad style, just the rubber compound. My winter/rain/city bike has had probably every Koolstop cantilever option made over the years. (Mafac Racers and skinny Open Pro/almost as skinny Sport rims. With that combo, clearance, even tire clearance isn't an issue.) I suspect the bigger, longer pads last longer just being more rubber there but as far as stopping, I cannot tell.
The dropped
Liked 1,014 Times
Liked 3,931 Times
If you are going to run chrome rims, consider the Racer calipers. They will probably drop right on to both of those bikes. (My 1967 Peugeot came with them so while they may not be model correct, they are the right vintage. For many years, the best stoppers out there. Still excellent. KoolStop and Racers work really well (and very rarely give off little muted versions of the famous Mafac squeal)
And complete aside but fun - I miss the squeal. In traffic, what a tool! .A Boston driver cuts me off. I hit the front brake much harder than I need to . SQUEAL!!! Every head for a block in each direction turns. I point at the offending car. Driver comes out of his fog and sees everybody looking at him! Driver slinks off with his tail between his legs. (I grew my cycling legs in and around Boston.)
Ben
Ben
The dropped
Liked 1,014 Times
Ben
Ben
