Truvativ Crankset replacement
Piquantique
Bikes: REI Novara
Hey. Time to replace my crankset. Truvativ 5D 48/38/28 on a 2014 REI Novara Buzz
Only problem is I can't find a replacement anywhere. I found a 170-mm crankset online but nobody has the 5D 170-mm arm in stock.
The 175-mm arm isn't too hard to find but there again...I can't find a matching crankset.
I assume there are some restrictions in swapping out for a totally new brand (eg, Shimano), but what are my options? And if I do that will I have to replace other parts (chain, derailleur etc) to accommodate the new crankset?
Thanks in advance
Thanks in advance
Quoted: 6196 Post(s)
Liked 4,810 Times
They are square taper JIS to the spindle. So just get any other square taper JIS that suits your fancy and is appropriate for that bike. REI might have some suggestions if you bought the bike from them.
If you want to open your selection of cranksets, then consider replacing the BB too. Most BB's are less than 18.00 USD. Some less than 10.00 USD.
I'm on the older side of 50 and when I went to longer cranks on a couple of occasions I had some very minor issues I just didn't want to put up with. So if you are older and have been using 170's for a long time, then take that into consideration. Though my experience might not be typical.
Quoted: 41 Post(s)
Liked 39 Times
are you replacing it because you hate it or cuz it's worn out? I have aTruvative Touro triple crankset that has about 50 miles on it, 170 arms, that is excess to my needs (took off a recumbent I bought.) It's 30/42/52 so might want a slightly longer chain but if your crank s shot the chain needs to be replaced anyway
Send me a PM if you might be interested for more info
edit: now I'm confused...When I looked at 5D crank arms the picts were JIS/square (which is what the Touro is. When I later looked at the 2014 REI Buzz info it said it had a 5D crank with a splined BB ?!. It might help the thread to know if yours is square BB or splined.
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
More importantly that is designed for the spindle length of the current BB
Likes For dedhed:
Liked 4,810 Times
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times
I'd replace the crank with a Shimano Hollowtech II crank and BB because parts are easier to find. I think a 3x9 crank will work fine on your 3x8 system. Lots of those on ebay. You can often find Deore 3x9 cranks (48-36-26) new for less than $100 and BBs for $25.
But maybe you just need new chainrings?
Piquantique
Bikes: REI Novara
Thanks for the suggestions.
3Roch: Nah those cranks have been good to me. Just time to replace 'em.. Yes my BB is a spline. Arms on my bike do not have the square sockets.
Tyrion: replacing the Truvativ with a Shimano means I would have to swap out some of the other parts I already have, is that right?
What kind of chain would I be using on a 3 * 9? 8 or 9 speed?
What about my SRAM derailleur? Would I have to swap that out for a Shimano as well?
Thanks for all the help
Liked 4,810 Times
Durn..... so much for googling. All the pic's showed a square taper as did several on eBay I looked at. Still same advice though.
Octalink and ISIS are two different types of splined spindles. Still will limit your choice of cranks if you only look for what fits that bb spindle.
SE Wis
Liked 3,401 Times
Just replace the chainrings
Likes For dedhed:
Piquantique
Bikes: REI Novara
Maybe my last post wasn't clear enough. My understanding is that the parts are inter-related. I'm hesitant to make a major swap because I don't want to get halfway through a repair only to realize the existing parts aren't compatible.
Can I ask what the rationale is for "just replacing the chainrings?"
SE Wis
Liked 3,401 Times
Unless damaged about the only part on a crankset that wears out is chainrings. What is it besides that makes you say, "Time to replace my crankset"?
Piquantique
Bikes: REI Novara
It looks like the arms and chainrings are sold together as a unit... And the bottom bracket is part of the whole. If one part is worn I'd rather just replace the whole mechanism.
SE Wis
Liked 3,401 Times
Quoted: 980 Post(s)
Liked 582 Times
"My car's tires are worn out, so I'm getting a new car."
Removing and replacing chainrings is a snap compared to replacing the crankset.
Piquantique
Bikes: REI Novara
That makes sense...but it still takes me back to square one: the parts aren't in stock anywhere
Liked 2,011 Times
https://www.ebay.com/itm/Shimano-Ali...sAAOSwL0xe4kn9
Or, as I said, maybe just new chainrings.
Likes For tyrion:
