Brompton handlebar Stem Question
Bikes: IF TiCJ
Quoted: 11 Post(s)
So I have an opportunity to acquire a Brompton.. only thing is it has the M style bars.
I really want S style. If I put a mid rise bar like the Joseph Kousac one will that screw my geometry or is this a good solution without investing in a new stem.. Any opinions / experience / Tips ?? Oh it's a 2016 model.. ( I am not worried about adjusting cable lengths I have a fully equipped work bench..)
Thanks gang..
Thanks gang..
Steering geometry remains unchanged.. 72.4 for all
see chart. (Pre 2017) for bar height and the bend offset
Bikes: IF TiCJ
Quoted: 11 Post(s)
Hmm yep but looking at that graphic the S stem results in a 31 mm longer virtual top tube... I guess setting the saddle back a bit could compensate... I wish I could find a real Geo chart for the Brompton. I might have to be the guinea pig on this one..
a few simple tools: angle finder @ builders supply & double scale tape- measure & you can DIY the info..
I've had 2 M3 R & L. green one is current ..
Bikes: IF TiCJ
Quoted: 11 Post(s)
"a few simple tools: angle finder @ builders supply & double scale tape- measure & you can DIY the info.."
Er yeah but you have to have a Brompton to take the measurements from... If I had a Brompton I would not be asking about GEO on this forum,,,
Schwinnasaur
I have not done this but you may need to change cable lengths. I changed an M to H and had to get new cables. I have heard that you won't need to do this online but cables are fussy when it comes to folding.
This is quite a popular application for Joseph Kuosac mid riser bar on Bromptons.
You got to keep the cables unchaged (can be a little bit longer for the perfectionist), a lower riding postion (might not be as low as S type) and a very large handlebar (can be 600mm fulll length uncut) for cockpit.
BTW, Joseph Kuosac also has carbon midriser handlebar and the soon to be released carbon ergonomic S handlebar too
This one is from older M to mid-riser Joseph Kuosac uncut
Bikes: IF TiCJ
Quoted: 11 Post(s)
Thanks thats exactly what I wanted to know.. I actually did a little guesstimating using the published bar heights and it looks like using a 60mm rise bar.. like a BMX bar would put me right at the same height as the S.. just with the shorter virtual TT
Bikes: Dahon Jetstream p8 (sold), customized Dahon Helios x10, customzed Dahon Smooth Hound x11,customized Dahon Hammerhead 8.0 d7, Planet X Free Ranger (mullet setup 1x11), Planet X Giovanissimi 20 (1x9), Frog 52 (1x9) and Frog 48 1s
Quoted: 264 Post(s)
Liked 239 Times
https://www.syntace.com/en_GB/produc....4-clamps?c=79
or a litepro copy
Quoted: 264 Post(s)
Liked 239 Times
it makes sense as you went for something longer and you needed to restore clearances/play for the cable to fold
Bikes: IF TiCJ
Quoted: 11 Post(s)
Solved
I found these videos on YouTube that have the measurements.. so can work from there..
https://www.youtube.com/c/Bikesandli...y=measurements
You got some oddly complex answers to your simple question. No there won't be a massive change, the bars will just be a bit lower.
Likes For Joe Remi:
