Gearing used Mt Evans
Bikes: Habanero Titanium Team Nuevo
Quoted: 399 Post(s)
Liked 185 Times
My guess is someone in the forum has climbed Mt Evans in Colorado, supposed to be a 6500 feet climb. It is long but essentially no a steep as some in the Alps. I wondered what gear you used. For a reasonably fit cyclist what cassette would you run. I run a compact now with 11-28 and I live in the flatlands. I never actually have to have the 28 around here for sure but have used if tired and I just want to spin.
My guess is an 11-28 with the 34 front would be ok but probably better to be 11-30. But I have no idea maybe I would want an 11-34 so I had a 34-34 gear. I am fairly strong cyclist for almost 59 but it would be a shame to walk right?
Quoted: 18883 Post(s)
Liked 10,646 Times
I ride a compact with a 12-28 (on 28mm tires). The Cascades are lower than the Rockies, but steeper. Our biggest climbs are around 5k. Based on all my experience and the way fatigue sneaks up on me a little quicker than when I was 20, I'd want an 11-34 for Evans.
Hope it's a great ride, and I'd love to see some pics when you get back. 🙂
So it is
Quoted: 11393 Post(s)
Liked 4,729 Times
I've done it with both a 39/28 and a 34/28. The steeps are at the top, and you'll appreciate whichever gearing you choose, be it those, or more on the rear. It's not the leg strength, it's the nonsense that goes on above 12,000 feet elevation. Air, general feeling of being not well, all of it.
The elevation may be a bigger problem than the steepness of the slopes. I've rode it twice a year at ages 51-53, weighing in at 135 lbs. My best time was 2:35, which would most often get you a top 10 finish on race day, but probably 15 minutes behind the fastest in the age group. I always had a triple with a 28/25 low gear, that was more than sufficient. A 34/30 is the same gear ratio. The other problem for most people is they have no way to train for climbing continuously for 2-3 hours. At the time, I lived at about 6000 foot elevation and rode 25 miles into the foothills with over 10 miles of continuous climbing on my 50 mile rides, 3 times a week.
At age 67, I'm riding much steeper, but shorter climbs on my 40-50 mile routes. I've thought about driving the 1.5 hours to Idaho springs and doing it again, but it would surely take over 3 hours and then you've got the long descent. Prepare for temps in the 40's at the top.
These days, I use a 48/32 crank and 11-34 12 speed cassette. I've done at least 12% grades with it. I still weigh 135.
Quoted: 3942 Post(s)
Liked 7,279 Times
Should Be More Popular
Quoted: 22571 Post(s)
Liked 8,918 Times
A couple more comments. Strength is certainly needed, but low weight is important too. It's all about power to weight ratio, when you're climbing. This year there will be no cars on the road. There's also no water available at the top.
Likes For Canker:
Quoted: 152 Post(s)
Liked 173 Times
I'd much rather have lower gearing on the chance you won't need it than have higher gearing wishing you had another cog or two lower. Don't underestimate the effect that 14,000'+ can have if you aren't acclimated. If you are riding up from Idaho Springs you might want stash some water off to the side of the road somewhere up around Echo Lake before starting your ride so you can refill your bottles. And be prepared for just about any weather at the summit. Conditions can be drastically different than down below.
