Show Your Vintage MTB Drop Bar Conversions
#126
Thrifty Bill
Quoted: 1236 Post(s)
Liked 964 Times
Cantis are an easier choice brakes wise.
Please don't confuse ebay "asking" prices with "selling" prices. Many sellers never get their ask price. some are far from it. Value is determined once an item actually SELLS. Its easy enough to check SOLD prices.
Likes For cobrabyte:
#128
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
The way I think about this is that an MTB will generally have a much higher bottom bracket than a road bike, resulting in a shorter seat tube, relative to everything else. My 20.5" Diamondback fits much the same as my 22" Bianchi Eros, for example.
#130
Bikes: '85 Univega Safari-Ten (fixed), '84 Univega Supra-Sport, '85 Univega Gran Turismo, '86 Bianch Giro, '93 Cannondale R300, '68 Raleigh Gran-Prix (S3X fixed), '74 Schwinn Sprint (fixed), '5? Raleigh Lenton, '73 Raleigh Sprite, '36 Three Spires... etc.
Well, let's start with this: I'm six feet tall and I ride a 58cm road bike, comfortably. What do you think would be a suitable size in a mountain bike for drop bar conversion? Most of what I ever seem to come across is under 20".
#131
Quoted: 4232 Post(s)
Liked 2,947 Times
I am a bit oddly proportioned and have long monkey arms though.
Bikes: 1996 Eddy Merckx Titanium EX, 1989/90 Colnago Super(issimo?) Piu(?),1990 Concorde Aquila(hit by car while riding), others in build queue "when I get the time"
#132
Bikes: Raleigh Glacier MTB/Commuter. Cannondale CAAD5, Windsor Timeline fixed gear
I've got shallow drop bars with cable grooves and Tektro aero levers. I could fit V-brakes or canti's - which would work best with those levers?
I already have NOS indexed 7 speed stem shifters and although I'd probably prefer barcons, this is a "zero-budget" build so to those who use stem shifters with this set-up, are they OK?
I use stem shift on mine, and really love it, even if they are major dorky (but then again, so is the whole bike!). The only down side I would see to the stem shifters is if you use a threaded to threadless adapter like I originally planned on doing. They will not work properly with that since it will have a bulge on the adapter that will probably interfere with the levers.
#133
Liked 2,947 Times
#134
Fat Guy on a Little Bike
Bikes: Two wheeled ones
Quoted: 1254 Post(s)
Liked 345 Times
I LOVE the v-brake set up with Tektros...it's not terribly expensive, it's more stopping power than cantis and they're easier to set up. If you aren't going brifters or fenders, this is by far the best approach IMO.
#135
Chainstay Brake Mafia
Quoted: 16 Post(s)
Liked 11 Times
#136
I didn't think to even take pictures of it but a former housemate wanted a solid bicycle so I built her a late 80s Kona Fire Mountain (i think). It got a pair of band shifters for downtube ones instead of stems shifters I built for another friend... this one was a wicked 90s fluorescent pink mtb that got drop bars and all the goodies for loaded touring. Someone should made a stem spacer with downtube mounts on them, certainly that can't be any more obnoxious than stem shifters.
#137
Liked 345 Times
Suntour Commands...I'm not thrilled with them, though I'm picky and spoiled by Campagnolo perfection. If I did the build again I'd have used brifters or maybe even the dread barcons.
They usually sell 75-100ish in decent shape, so while not brifter price, they aren't truly budget either.
#139
Quoted: 16 Post(s)
Liked 11 Times
#140
Bicycle Repair Man !!!
As stated, these are Suntour Command Shifters which do fetch as much as a set of new indexed bar end shifters... I have a set I am saving for some future project and they are not a commonly found part and ergonomically, they are an excellent design.
#141
Bikes: many
Quoted: 18 Post(s)
Liked 16 Times
I have to admit that I like canti's over V-Brakes. I have had both and find the V-Brake tolerances to be much narrower than canti's. As a result, I have converted most of my applicable bikes to canti's. Yes, canti's are a little difficult at first, but once you get the hang of it, not at all bad. At the end of the day, both are fine and workable.
#142
Liked 345 Times
#143
Bikes: 1970 Holdsworth Mistral, Vitus 979, Colnago Primavera, Corratec Hydracarbon, Massi MegaTeam, 1935 Claud Butler Super Velo, Carrera Virtuoso, Viner, 1953 Claud Butler Silver Jubilee, 1954 Holdsworth Typhoon, 1966 Claud Butler Olympic Road, 1982 Claud
Quoted: 10 Post(s)
Liked 11 Times
Someone correct me if I am wrong, but I believe you would want to go with the cantis since the v-brakes will require extra parts or special road bike levers to work. Mine works fine with my cantis.
#144
Quoted: 10 Post(s)
Liked 11 Times
Thanks Aaron - I think that maybe sub consciously it may have been your bike that planted this seed of an idea in my feeble mind!
#145
Quoted: 10 Post(s)
Liked 11 Times
Ah, that's a point - I guess that would modify the amount of cable pull - simple and straightforward it is, then!
#146
Liked 345 Times
For what it's worth, I think it's a better, easier set up than cantis and it works very well. I was really happy about how that part of the bike worked out. The commands, not so much. I understand why suntour died in the market.
#147
Bikes: -1973 Motobecane Mirage -197? Velosolex L'Etoile -'71 Raleigh Super Course
Oh, bite yer tongue! I got two bikes set up with Command Shift, both of them Treks. The 560 has the indexed ones and they work flawlessly. The trick to setting them up is to let the housings compress down for a few rides and then adjust the cable tension for a really good crisp 3-4 downshift. Everything else then falls into line. Mind you, you also need to have everything else matched properly, which I suspect you do.
My 616 has friction style, they came to me with the ball detent already removed, and they work quite well over 8 gears in back. So if you don't want yours, let me know and I'll gladly buy them. Far and away my favorite shifters.
#148
Liked 345 Times
Capt., I think that's part of the issue...deore rear dérailleur. I might shift to suntour and see if that helps. My lbs guys all assured me it wouldn't help much. If the friction mode worked, it would be ok. I probably will switch out and you're first to know!
#149
Ohhhhh... If you're not using a later Suntour mech, that's the problem right there. Try one of the various XC models, a Pro by preference, with a 4-prong Winner. That should clear it up. FWIW I don't think Winner freewheels shift very well except in index mode. Somewhere in the forum archives, there's a Rosetta Stone with the info needed to build a Hyperglide cassette with Suntour index spacing. That would be handy to have. It would be too much hassle, but the Command Shifters are just *so* nice.
#150
Liked 345 Times
I'll give it a shot, but to be honest I've ridden commands with the xc pro and freewheel and thought they had the same issue. My cassette was spaced correctly, so it shouldn't be a problem. If the friction mode worked, it would be fine.
