Which Pedals For My New Steed
Bikes: 2011 Trek Allant, 1990(?) Miele Tivoli Road Issue, 2016 Trek Emonda ALR5, 2000 Kona Hahanna
Quoted: 11 Post(s)
I bought a 2016 Trek Emonda ALR5 at the Toronto Bike Sale last fall and stashed it in a back room until spring. Well, spring has sprung and it's time to get the bike ready to ride.
I've done the easy stuff so far - water bottle cages and a mount for my Polar M450. I'm also swapping the 23mm tires for 25 mm tires. Next thing up is pedals.
I'm 5'9" and the nasty device in my bathroom says I'm 269 pounds. On my old Miele roadbike, I have mountain bike SPDs. On my city bike, I have pedals that are SPD on one side and flat on the other. With this bike, I'm biting the bullet and jumping into actual road pedals and shoes. So my question is which pedals should I go with?
The bike is full Shimano 105 but I'm not sure I want to pay the price for 105 pedals when these are my first road pedals. I've been leaning towards the Shimano R550's instead. Anyone use them? Are there other Shimano pedals I should look at?
Or are there other companies that might offer something better. What pedals do you like and why? Are there any that a heavy guy should avoid?
Thanks.
Thanks.
Bikes: 2009 Trek 1.2
Quoted: 239 Post(s)
I have these : Shimano Ultegra PD-6610 SPD-SL Road Pedal 6600 | eBay
And yes, it's the older version as shown in that link. I've used them for six years or so ... they've been bulletproof.
For reference, I'm 6'3", anywhere between 260 and 300, currently nearer the top of that range. I have an older pair of Shimano carbon fiber soled shoes I bought at the same time. The only thing I've had to do is replace the cleats as they wore out.
On your bike, I'd spring for the matching 105 pedals. Once you use them you'll never go back to regular pedals
I really like the MTB style double entry better than single sided.
I have a set of Record pedals I don't use any more because I love the Eggbeaters better. Just so much easier to clip into and the clips do not leave me walking like a penguin when off the bike.
I forget what model Eggbeaters I have, I have had them that long, but they have a nice wide platform.
Bikes: Kona Big Unit Single Speed, Kona Private Jake Single Speed, Jamis Renegade Elite
Quoted: 40 Post(s)
I'm done with road pedals. I've gone mountain bike on all my bikes. Specifically Time ATAC. I have three versions but they all look and function the same. Been using two pairs for 5+ years with no issues and just got a new pair yet to be installed so all three bikes will be the same.
If I ever went back to road pedals...I'd go with Speedplay. Still have mine...love them as far as road pedals are concerned.
Bikes: Specialized Roubaix, 2011 and 2017
Quoted: 165 Post(s)
SPD-SL pedals (and to a nearly identical degree, LOOK) are so wide, so flat, so supportive... they are wonderful for folks our size. MTB pedals tend to be designed to have cleats which allow you to do things other than ice skating on linoleum when off the bike, which is great when you're walking through the store but far less lovely for riding.
Quoted: 40 Post(s)
My road shoes with the LOOK cleat bolted on are stiffer laterally than the MTB shoes. It's a big difference. Maybe I could remediate this with better MTN shoes, but for now I'll tell you I am much happier spending long hours in my road shoes.
Yes, these cleat designs require additional learning to clip in quickly and safely. You also need to walk carefully when off the bike. I will tell you that these are worth while drawbacks for the comfort benefits they offer.
I'll endorse my LOOK pedals and note that I've been riding these for over a year and was as heavy as 280 without issue. Pedals are in great shape.
LET'S ROLL
I use Speedplay on my roadbike. X5(chro-mo spindle) and X2(stainless spindle) have no stated weight limits:
One day: www.youtube.com/watch?v=20X43026ukY&list=UUHyRS8bRu6zPoymgKaIoDLA&index=1
Quoted: 11 Post(s)
Thanks everyone for the replies. I do like my mountain bike pedals a lot and I've been tempted to stay with those but I want to try road pedals this time and see what the difference is for myself.
Quoted: 11 Post(s)
I have been really happy with my decision to switch to road pedals. I wouldn't switch back on any dedicated road bikes.
Quoted: 40 Post(s)
I don't find any advantage at all with road pedals/shoes. Only the disadvantage of slipping around, tearing up the bottom of your shoes, and walking like a duck when off the bike.
Bikes: Specialized Secteur Sport 2015, Vitus Zenium VRS 2014
Quoted: 17 Post(s)
I used R550 pedals for a year then switched to Speedplay Ultra Light Action chromoly to help my knees, which worked. I love the float.
Keep in mind Speedplay requires more maintenance, but it's quick and easy to do.
If you go Speedplay, stay away from the titanium axles, they have a weight limit.
Quoted: 11 Post(s)
Quoted: 17 Post(s)
You also have to grease the pedals every 2,000 miles or 6 months. You have to do it more often if you ride in wet or dusty conditions. Basically, when properly greased, the pedals shouldn't spin more than half a turn. You have to use a waterproof grease. Marine grease is perfect and very cheap. The grease gun will be the more expensive part.
All the details are in the FAQ section of their website.
If you use 4-hole shoes, you need to buy the protector kit which are plates that go between the sole and the cleats. I use 3-hole shoes with the included adapter and it works very well. 4-hole shoes are typically more expensive and less common though by no-means rare.
Quoted: 1020 Post(s)
Liked 463 Times
I love the LOOK Carbon blade pedals on my four road bikes. Easy in, easy out and very stable.
Having said that, however, Shimano pedals are a great value.
You may wish to stick to what you already know, but on a road version.
Good luck.
Good luck.
