Track Cycling: Velodrome Racing and Training Area Looking to enter into the realm of track racing? Want to share your experiences and tactics for riding on a velodrome? The Track Cycling forums is for you! Come in and discuss training/racing, equipment, and current track cycling events.
Long Reach Handlebars
Old 02-10-20, 10:07 PM
nosaad
Bikes: 2019 ICAN AC135, 90's Orbea Lobular
Quoted: 5 Post(s)
I'm in the market for a handlebar in the neighborhood of 110mm Reach, 140mm Drop, and 370mm Width. I'm a little flexible on dimensions. I found the Olympus/Control Tech bar, which is intriguing, but surely there are other options.
nosaad is offline
Old 02-11-20, 02:13 AM
carleton
Elitist
carleton's Avatar
Quoted: 1386 Post(s)
Liked 92 Times in 77 Posts
Nitto ADB-X:
  • Reach: 115mm (5mm longer)
  • Drop: 150mm (10mm deeper)
  • Width: 37cm
  • URL: https://www.benscycle.com/nitto-adb-...-x_870/product
  • Sort of a hipster cult favorite, but so were Nitto B123 which were raced at the highest levels of the sport.
  • Riding the tops may be uncomfortable due to the angle. But, the same can be said of standard track bars (including Scattos) due to creating room for forearm clearance for standing starts.
Nitto heat treated aluminum is as light and strong as carbon at a fraction of the cost. I've used several pairs over the years. The only downside is that you'll need a 26.0-31.8mm shim for your stem. Not a big deal. I've used shims several times before (even for powerful standing starts), with no issues.
carleton is offline
Old 02-12-20, 07:31 PM
nosaad
Quoted: 5 Post(s)
That bar looks great, thanks for the info. Follow-up question.. is there a handling difference between bar/stem combo's so long as the hands are in the same place with respect to the steerer tube?
Example. Will these feel the same all else equal?
stem: 120
bar reach: 80
stem: 100
bar reach: 100
nosaad is offline
Old 02-12-20, 09:59 PM
taras0000
Lapped 3x
taras0000's Avatar
Quoted: 325 Post(s)
Liked 23 Times in 20 Posts
stem: 120
bar reach: 80
stem: 100
bar reach: 100
As long as the drop is the same, then they will handle the same. Although there are other factors that also influence front end handling, combinations that place your hands in the same spot will keep the same weight distribution over the front axle.
taras0000 is offline
Old 02-13-20, 04:21 PM
seau grateau
seau grateau's Avatar
Quoted: 1332 Post(s)
Liked 398 Times in 194 Posts
I've never felt confident in manfacturers' listed reach measurements when it comes to handlebars, as there isn't really any standard for measuring it.
seau grateau is offline
