Terrifying close call yesterday
Had a really close one yesterday evening... I escaped being run over by just a hair. I would probably still be shaking if it didn't happen at such low speeds.
A semi trailer had stopped at an intersection, waiting for left turn (his turn signal blinking, I specially paid attention to that). As I also needed to turn left (aiming for the sidewalk diagonally across the intersection, so I wasn't really going to be next to the semi), I passed the semi on the right and stopped a few meters in front of it to let the opposing traffic pass, just like the semi was doing.
At some point the driver of the semi must have changed his mind and decided to go straight ahead instead of turning left (allowed option there). I realized I must still be in his frontal blind spot as I heard the roar of his engine right behind me and coming nearer...I probably hadn't ever pushed my pedals this hard from a standing start, as I realized my only option was to get going and slip back to the right. Of course, my chain skipped under the load (I was in a fairly tall gear, one step below my usual cruising gear), and split second later I felt a nudge on my rear wheel. Luckily enough the semi changed gear then which allowed me to increase the distance a little bit and get off his path.
No physical harm done to me or the bike. The semi driver probably at no point realized I was there at all.
Moral of the story: ALWAYS keep safe distance from large vehicles, in any direction, even if they're not moving at the moment.
Quoted: 18369 Post(s)
Liked 4,507 Times
It sounds like a tough spot being in an optional left turn lane. And, a reason why lane splitting and filtering to the front isn't always the best. Nonetheless, make sure wherever you put the foot down, you are visible.
In many cases, I like to pull forward to the middle of the crosswalk if I'm not in the way of pedestrians. Anything to give a little more visibility.
Oh, also keep in mind, vehicles may not turn on turn signals, or forget theirs are blinking. Or, even if he had turned the signal on, he may have realized he was a block off from the destination, or turning at that spot was problematic.
Likes For CliffordK:
Quoted: 1221 Post(s)
Liked 628 Times
Holy crap glad you are ok! There's no way he would've known you were there, and two meters infront is not far enough up to see you, especially on the passenger side! Always stay behind a tractor trailer or other large truck.
Quoted: 529 Post(s)
Liked 255 Times
None of us were there to see it, but maybe his turn signal was blinking because he had just changed lanes.
As cyclists we all need to be alert all of the time, and do whatever we need to do to stay safe.
Quoted: 1364 Post(s)
Liked 1,677 Times
subgrade Glad you're okay.
I usually stay "in line" with traffic for left turns...but every situation is different. One danger of following a large truck across an intersection for a left turn is that oncoming traffic may not see you, and if the light changes, or oncoming traffic already has a green, a foolish driver in an oncoming car may try to squeeze past the end of the truck as closely as possible...and of course that's where you are. That would be one reason why turning along the right side of the truck might be a choice one would make.
Yes...something to consider!
This post reminds me specifically of the first left turn of my commute home. It's at a light and the left-turn lane is separated from the through-lanes by lines that make a bike-sized gap. I have seen other riders use it, but I am always worried about a left-turning driver swinging wide to the right while looking left. On the other hand, I have been behind a truck and been a surprise to an oncoming car who jumped the green.
Quoted: 5224 Post(s)
Liked 3,581 Times
yeah, stay away from trucks & buses, they're killers
Liked 3,581 Times
This might be a helpful video based upon my understanding of events https://www.bikeleague.org/content/intersection-positioning
Quoted: 451 Post(s)
Liked 364 Times
You are very fortunate. what I have taken to doing most of the time these days is to just take the lane and get in line like any other vehicle. Not in any kind of a hurry to make the light. Whenever it' my turn, it's my turn.
Likes For bpcyclist:
Liked 4,507 Times
Tip:
If you need to cross over railroad tracks,
be sure to do so at a 90° angle,
to prevent puncturing your tire.
Liked 3,581 Times
reminds me of this one from last year (warning - no happy ending)
https://www.bikeforums.net/advocacy-...-reported.html
Quoted: 7348 Post(s)
Liked 2,460 Times
Thanks for the reminder. I'm taking bad risks lately.
If the semi would indeed have been making the left turn, we both would start simultaneously (with the likelihood of me doing a slight jump start), and I'd have completed my move long before him - that's why I pulled up in front of him.
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,103 Times
I wonder how @joeyduck is doing
Genesis 49:16-17
Genesis 49:16-17
Yeah, that's kinda what I thought from what you were describing. You had absolutely no business being beside that vehicle regardless of what type it was. You were another vehicle, on the road, turning left. Unless there is a double turn lane the only appropriate place for you is in the turn lane behind whatever vehicles are in front of you. Just because you intended to enter the sidewalk after making the turn does not give you the right of way to jump into the intersection in any manner other than what would be appropriate for another vehicle. Otherwise you should have been in the crosswalk on the left side of the road and proceeded through based on the pedestrian signal.
Hope this schematic helps. I'm the thingy inside the blue circle.
Likes For Mitkraft:
The dropped
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules (sold) : 1966 Schwinn Deluxe Racer (sold)
Quoted: 1739 Post(s)
Liked 1,014 Times
I agree with Mitkraft . Mixing travel modes tends to make you unpredictable for other road users. Unpredictable road users cause accidents. I'm glad you didn't have to pay more than a pair of underwear for this one.
Bikes: Downtube IX NS&FS, Dahon Speed8Pro/Matrix/Curve, Brom S2L,Montague Para, ICE-XL w/Rollie/Schlumpf, Trident Spike, ebikes, BFSatRDay
Quoted: 172 Post(s)
Liked 95 Times
Similar threats to motorbikes
Defensive driving makes one aware of the unpredictability of others at all times
I ride Like I am James Bond
Everyone in the movie is trying to kill me
Likes For bikebikebike:
Disco Infiltrator
Liked 2,103 Times
Quoted: 2494 Post(s)
Liked 738 Times
I am not promising that I am going to sit at #6 from the corner in that situation, I'll definitely filter forward if time permits, but if I am turning left I am going to be on the left side of the lane and in the #2 position. I never line up with the #1 car even if I KNOW they are turning. I am going to use them as a shield as I make my turn behind them. The #3 car has definitely seen me because I have been just in front of them for some time. It doesn't matter what the #1 car/truck/bus thinks. There is often a handy bicycle symbol to the left side of a mixed use lane like that for when there aren't any other cars around. I used to think that you put your front wheel on it but actually you position your bottom bracket so it goes over the edge of the sensor loop. Works everytime now that I know to position the BB over the line and not the wheel rim.
Why exactly do you believe its ok to "filter forward" and basically cut in front of a bunch of cars waiting at a light only to have them get frustrated at the need to pass you (after already having done so in many cases)? The cars aren't going to be in your way if you wait behind them but you sure as heck are going to be in theirs if you cut in front. I can see the case for not coming to a complete stop at stop signs in deserted intersections but I just can't see the mentality that thinks filtering forward is anything other than being a jerk.
