Campagnolo disc brake rotoer lockring
Bikes: Bianchi Infinito CV 2020, Marinoni VR2 2005 (sold)
Quoted: 5 Post(s)
Hi,
I'm looking for a confirmation that the tool needed to remove the brake rotor lockring of Campy disc brake is the same as the one for the shimano disc brake rotor.
Thank you,
AB
Thank you,
AB
Quoted: 241 Post(s)
Liked 232 Times
Campag says to use the UT-BB130 tool to install or remove the lockring. And that is the same tool used to install the UT bottom bracket. Which is the same tool that works on Shimano bottom brackets and 16 notch disk lockrings.
