Alternative to isopropyl for cleaning disc brakes and pads?
Quoted: 800 Post(s)
Liked 512 Times
Historically I have been using isopropyl alcohol for cleaning the disc brakes and pads on my bike.
Now that isopropyl is difficult, if not impossible, to find what alternatives are there that can I use? This is a Shimano road bike hydraulic disc brake system if that matters.
Thank you.
Thank you.
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
I haven't ever used anything on the pads, apart from sandpaper (rarely).
The discs give many options: Methanol. Ethanol. Acetone. Soap and water. Dry rag. Nothing.
Likes For dsaul:
Quoted: 1438 Post(s)
Liked 1,092 Times
Brakleen automotive brake cleaner or equivalent; keep it off your paintwork. https://www.crcindustries.com/produc...-brakleen.html
Of course there are commercial products available. Dawn is good for safely cleaning brakes and most anything else. Just rinse with water afterward.
Generally bewildered
Quoted: 1152 Post(s)
Liked 341 Times
This is a theoretical viewpoint, but may be useful. In cars, you have pretty high heat in brake rotors sometimes. They are thick, and you are stopping a vehicle that weighs a couple-few thousand pounds. So there's some buildup of things that results from high heat. I would suspect that these would be resistant to soap and water, so Brakleen and other strong solvents are used.
If isopropyl alcohol is what you currently use, then I suspect that you don't need the strong solvents (like acetone or perchloroethylene). I'd try soap and water and see how it works for you first.
If you do use brake cleaner, keep it off the rubber in your tires (as well as following the advice to keep it off paint as dsbrantjr mentions above).
Isopropyl alcohol is not a great grease remover and it usually contains 10-30% water. As others have noted, aerosal brake cleaners have more suitable solvents. Mineral spirits won't hurt the paint, doesn't dry as fast and won't bother paint. When acetone is added to mineral spirits, it's lacquer thinner. Acetone may damage some paints. Naphtha/white gas/camp stove fuel dries faster.
Liked 1,092 Times
Liked 341 Times
Vodka with some soap, or neutral grain spirits might work. But you might want to reserve those products for other purposes.
Bikes: Downtube IX NS&FS, Dahon Speed8Pro/Matrix/Curve, Brom S2L,Montague Para, ICE-XL w/Rollie/Schlumpf, Trident Spike, ebikes, BFSatRDay
Quoted: 172 Post(s)
Liked 95 Times
Gasolines have a lot pretty toxic components, even white gas, and a stray spark can change your life.
All need ventilation and many are absorbable through the skin.
Toxicities are not always immediately apparent
Generally I avoid anything linked to renal failure and killing bone marrow, like benzene, contained in a mix
Use care. I spent 2 years in a burn unit putting skin back on folks, none of whom planned to be there.
The lucky think they are smart.
The smart know they are lucky
Likes For bikebikebike:
Quoted: 980 Post(s)
Liked 582 Times
Denatured alcohol works as well as isopropyl alcohol, and doesn't contain anywhere near as much water.
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,218 Times
DO NOT use gasoline outside of a gas tank for any reason. There are other, better, alternatives that won’t result in your house burning down as easily.
And, finally, DO NOT USE GASOLINE FOR ANYTHING OTHER THAN POWERING INTERNAL COMBUSTION ENGINES!
Stuart Black
Stuart Black
Likes For cyccommute:
Liked 4,218 Times
Maybe, maybe not. It would depend on how the denatured alcohol was produced. There are ways of making “absolute alcohol” (100% ethanol) but 95% ethanol is easier to make. 2-propanol is made with various percentages of water in it. Even off the shelf, it can contain 70% 2-propanol or it can be 96% 2-propanol. If you buy cans of it at a hardware store, it is more likely to be 96%.
Stuart Black
Stuart Black
Liked 4,218 Times
That said, bicycle rotors and pads shouldn’t need a lot of cleaning in the first place.
Stuart Black
Stuart Black
Quoted: 303 Post(s)
Liked 136 Times
Someone suggested red bottle HEET, which is basically 96% isopropanol with 2% or so of proprietary stuff as a
source for isopropanol (to make home brew sanitizer). In a pinch this should do but I would use neoprene
gloves to minimize skin contact if used as cleaner as the 2% unknown makes this a bit problematic as a sanitizer.
As long as you are paying attention to what you are doing, acetone will clean much better than IPA. Just don't pour it over everything.
Quoted: 4560 Post(s)
Liked 2,802 Times
Acetone and denatured alcohol are still readily available here, even in some grocery stores. The only "paint thinner" I'm seeing now isn't mineral spirits but some sort of weird, thick, milky white stuff. I tried it to clean a bike chain and it was absolutely useless. It made a worse mess.
There are various ways that ethanol is denatured, depending on the intended use. These ways include addition of poisons such as methanol or gasoline, and one method I read about is the addition of an amount of peppermint oil that's so concentrated nobody would want to drink it, but it's not actually poisonous. The denatured alcohol you buy in a can at the hardware store is probably ethanol that's been denatured with methanol.
Quoted: 980 Post(s)
Liked 582 Times
Denatured alcohol is sold in pints and gallons at hardware stores.
Liked 4,218 Times
There are at least 105 chemicals and 45 different mixtures used for denaturing ethanol.
Stuart Black
Stuart Black
Yeah, I was reading about this many years ago and ran into the federal law that stipulates what's allowed for denaturing, which is where I learned that there's the peppermint oil version intended for use on things where a poison can't be used. The context of me reading about this was a violinmaker recommending against people using denatured alcohol when making shellac varnishes for use indoors, due to the braincell-killing power of some of the chemicals used. I went out and bought a bottle of Everclear, and used that for my shellac and for anything else in my mancave that I wanted to use alcohol on that wouldn't wreck my already feeble mind.
Likes For SethAZ:
Advocatus Diaboli
Quoted: 4735 Post(s)
Liked 1,532 Times
Random question.. I have a bottle of 99% ISO Alcohol. But it evidently expired 2 years ago per a use-by date on the bottle. Is expiration of alcohol possible?
Liked 4,218 Times
If you see crystals around the neck of a bottle of anhydrous, that might be cause for concern but short of that just use it. However, adding a little water will interrupt the peroxide formation so diluting it to 90% would solve much of the problem.
Stuart Black
Stuart Black
