Ask the Community
Ask the Community
Old 04-12-17, 07:57 PM
  #76
bonsai171
Quoted: 750 Post(s)
Liked 90 Times in 70 Posts
Originally Posted by Unkle Rico
Need some help setting up a SS CX Surly Steamroller.. I need to acquire a 42t(ish) front chainring (130bcd) and brakes that will accommodate 700c-35 tires.. I would pick stuff up from Scrod but he doesn't really stock these kind of items..
Good places to go shopping?
Origin8 sells aluminum chainrings in 42 tooth with 130 bcd for 3/32 chains on amazon. They run about $18, I have a 45t currently with about 500 mi on it. Not a bad chainring to figure out what gearing you like.
https://www.amazon.com/Origin8-BMX-S...ing&th=1&psc=1
Dave
bonsai171 is offline
Old 04-12-17, 10:09 PM
  #77
TejanoTrackie
Veteran Racer
TejanoTrackie's Avatar
Bikes: 32 frames + 80 wheels
Quoted: 1331 Post(s)
Liked 764 Times in 431 Posts
Originally Posted by bonsai171
I was thinking about going to a master link setup, mostly due to having bad experiences with connecting chains in the past (frozen links). Can someone point me to a good resource for how to connect chains?
Dave
You need to get a chain tool with a spreader, such as the Park CT-7. When you first push the pin back into the outer plate, it will clamp the outer plates against the inner link, causing it to bind. You then place the link onto the spreader part of the tool to loosen it up enough to eliminate the binding.
What, Me Worry? - Alfred E. Neuman
Originally Posted by Dcv
I'd like to think i have as much money as brains.
I see the light at the end of the tunnel, but the tunnel keeps getting longer - me
TejanoTrackie is offline
Old 04-13-17, 06:56 AM
  #78
Bandera
Quoted: 1112 Post(s)
Liked 180 Times in 119 Posts
Here you go:
Bandera is offline
Old 04-13-17, 08:41 AM
  #79
SquidPuppet
Calamari Marionette Ph.D
SquidPuppet's Avatar
Bikes: 3 Chinese Gas Pipe Nerdcycles and 2 Chicago Electroforged Boat Anchors
Quoted: 2358 Post(s)
Liked 33 Times in 26 Posts
Originally Posted by scoho
So I'm guessing almost everyone here uses a master link, no?
I use master links. Convenient and secure. Can't imagine using a chain tool just to remove and clean the chain.
SquidPuppet is offline
Old 04-13-17, 04:56 PM
  #80
steve-in-kville
Warehouse Monkey
steve-in-kville's Avatar
Quoted: 305 Post(s)
Liked 7 Times in 2 Posts
So far I've been. But I assure you - I'm due for another chain soon. And that will have a quick link.
'10 Specialized Hardrock
steve-in-kville is offline
Old 04-13-17, 05:06 PM
  #81
hairnet
Fresh Garbage
hairnet's Avatar
Bikes: N+1
Quoted: 352 Post(s)
Liked 27 Times in 18 Posts
Tell that to Shimano and Campagnolo with their special joining pin BS. Who the hell wants to deal with that?
hairnet is offline
Old 04-13-17, 05:11 PM
  #82
SquidPuppet
I don't even like KMC's "Missing Link". F'n PITA.
Old 04-13-17, 05:14 PM
  #83
hairnet
Fresh Garbage
hairnet's Avatar
Bikes: N+1
Quoted: 352 Post(s)
Yep. I am lucky if I can open one by hand. Get yourself some Wipperman Connex links if you can, those are very easy to open by hand.
hairnet is offline
Old 04-13-17, 05:40 PM
  #84
SquidPuppet
I like plain old KMC master links. No hassles. They look just like the Connex ones. Traditional clip.
Old 04-13-17, 06:08 PM
  #85
scoho
scoho's Avatar
Bikes: steel track
Quoted: 235 Post(s)
Oh, huh, I think the Missing Link is great. If you've got the pliers, it works like a charm, although needing a specialized tool is annoying.
I don't love the traditional clip. In my experience, it's far more slippery and frustrating than the Missing Link during both installation and removal (although still far better than breaking the chain, of course). I kind of feel like I'm doing something wrong, but not sure what it would be.
scoho is offline
Old 04-13-17, 06:12 PM
  #86
seau grateau
seau grateau's Avatar
Quoted: 1332 Post(s)
Liked 398 Times in 194 Posts
I always liked the clip. Easy to push on/off with a flathead screwdriver. Also easier to find when removing the chain. Missing link is fine too though, just kind of a pain to unlock if you don't have the tool (which I don't).
seau grateau is offline
Old 04-13-17, 08:38 PM
  #87
bonsai171
Quoted: 750 Post(s)
I just bit the bullet today and bought a new chain for the mtb, along with the park ct-5 chain tool. It was a little hard to grip the chain tool, but I was only using it to cut the chain to length. The chain is a KMC, which came with the missing link. All is good, just finished my first chain install! So excited. Definitely not going back to connecting pins lol.
Dave
Old 04-16-17, 04:06 PM
  #88
bonsai171
Quoted: 750 Post(s)
Hi,
Does anyone know if it's possible to service the bearings in a pedal like the one in this picture below?
Dave
Old 04-16-17, 06:35 PM
  #89
AristoNYC
AristoNYC's Avatar
Bikes: AristoNYC's PedalRoom
Quoted: 130 Post(s)
Liked 6 Times in 6 Posts
Should I get the regular wabis (again, I sold them with my Dolan) or go with the lighter ones? I am 195#
AristoNYC is offline
Old 04-17-17, 12:17 AM
  #90
Leukybear
THE STUFFED
Leukybear's Avatar
Bikes: R. Sachs Road; EAI Bareknuckle; S-Works Enduro
Quoted: 361 Post(s)
Liked 20 Times in 17 Posts
Hi,
Dave
Attachment 559614
Attachment 559615
Yes it is.
Remove the black nylon end caps at the outer extremities of pedals. That will reveal the pedal's innerds, to access these innerds you will need to use a ratchet and the respective socket you need to loosen the retaining nut that is holding the pedal spindle in place along with its supporting bearings and races.
Assuming these cheapie loose-ball bearing pedals, it'll look like this inside:
Clean out the old grease and repack with new grease. In the process, look for damaged ball bearings and pitted bearing races. Pitted bearing races can be the deal breaker, if they are pitted, your pedal will feel rough/ course no matter what, repack or not. Replace damaged bearings with ones of same size; a moot point if the prior is true.
¿pɐǝɹ oʇ sᴉ sᴉɥʇ ƃuᴉʎouuɐ ʍoɥ ǝǝs
Originally Posted by veganbikes
Pound sign: Kilo TT
Leukybear is offline
Old 04-19-17, 06:45 AM
  #91
hay
tumbleweed
hay's Avatar
Bikes: stumpy,bianchi,Wabi classic
Quoted: 53 Post(s)
Liked 20 Times in 7 Posts
I found what seems like a good deal on a f.g. bike.It's an Eastern Lurker. Apparently it's a sister company of Gran Royale however I don't know anything about either of these companies.
The bike is a solid build with BMX components which could either be good or bad . The stem looks very tall and the cranks are straight bmx with a small sprocket like maybe 32 tooth.
My question ... Is this frame any good?
I looked for reviews but didn't find much on it . Anyone familiar?
hay is offline
Old 04-19-17, 01:55 PM
  #92
Wendell F
My pants used to fit me
Wendell F's Avatar
Bikes: Surly Steamroller, All-City Super Professional
Quoted: 18 Post(s)
Liked 4 Times in 3 Posts
Oury-Replacement Suggestions?
Can anybody suggest grips to replace my Ourys? I like them, I'm just sick of my hands getting covered with melted rubber in the warmer months. I'm willing to give up some padding and grippiness if necessary. Please note that I use two brake levers on 48cm-wide risers so I can't use anything super long.
Wendell F is offline
Old 04-19-17, 02:27 PM
  #93
sleepy
Bikes: All have flats.
Is the All City Big Block fork or a Soma straight Track Fork compatible geometry wise with a Mercier Kilo?
sleepy is offline
Old 04-19-17, 02:58 PM
  #94
AristoNYC
AristoNYC's Avatar
Quoted: 130 Post(s)
ESI 34mm Extra Chunky Silicone Grips in Tree Fort Bikes Grips
https://www.amazon.com/s/ref=nb_sb_n...ords=esi+grips
Mumonkan got me into these, they rock.
You can cut them to the length you need if required.
Old 04-20-17, 06:30 AM
  #95
danslecarton
Hi guys, first post here
I’m currently running double toe clips from BLB (size M) on my daily whip and I’m having a bit of a fitting problem. I can’t use the first gates for the straps as they are too far in the front. Well I can, but I won’t have enough grip to brake properly then.
As I’ve seen many builds with properly fitted straps and BLB steel clips on the interwebs I assume the design has been updated? Or does that depend on the size of the cages?
Cheers!
File Type: jpg
File Type: jpg
danslecarton is offline
Old 04-20-17, 08:23 PM
  #96
Unkle Rico
Unkle Rico's Avatar
Bikes: CENTURION / LOOK / Bianchi
Quoted: 214 Post(s)
Liked 10 Times in 10 Posts
Maybe those cages aren't meant for those pedals?
Unkle Rico is offline
Old 04-20-17, 11:05 PM
  #97
Leukybear
THE STUFFED
Leukybear's Avatar
Quoted: 361 Post(s)
Cheers!
Those look like MKS sylvans, the golden-standard of FG/SS pedals.
If you make cages that aren't compatible with them, you're doing something wrong.
Soma makes a proper "double gate" toe cage.
Your double cages should have the "gates" above the pedal platform in a manner such as this:
Pound sign: Kilo TT
Old 04-21-17, 05:41 AM
  #98
danslecarton
Yeah, I'd be surprised if the cages wouldn't fit Sylvans.
That's also my understanding of a standard fit. I wonder why mine are so odd
Old 04-24-17, 09:28 PM
  #99
Unkle Rico
Unkle Rico's Avatar
Quoted: 214 Post(s)
Anyone heard of "Peloton" bike frames? There is one on CL here and I must say.. It looks sweet. NJS frame apparently but I can't find any info on this color scheme.. Thoughts? I am a sucker for pink bikes. What price would you guys pay for this bike?
https://denver.craigslist.org/bik/6069972559.html
Old 04-24-17, 09:38 PM
  #100
TimothyH
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times in 469 Posts
NJS Export has seven pages of Peloton frames for sale.
Two are pink but much darker than the frame in the CL advert.
-Tim-
TimothyH is offline
