Stoker Seatpost reviews What works
I have used the Satori Animaris and think it is a great value for the money.
A Full parallelogram suspension with adjustable spring damping for $59.
https://www.amazon.com/gp/product/B07113WT58/ref=as_li_qf_sp_asin_il_tl?ie=UTF8&tag=toponlinerevi-20&camp=1789&creative=9325&linkCode=as2&creativeASIN=B07113WT58
SATORI - Riding fueled innovation
Quoted: 169 Post(s)
Liked 84 Times
We have a Suntour SP12 on our mountain tandem. We've not taken it off road as of yet as I wanted to get my wife used to how it handles and feels on pavement. so far, she has not complained about it.
I will be keeping an eye out on the Satori ones though as they seem to have a lot of offerings.
Clipless in Coeur d'Alene
The Cirrus Kinekt 2.1 (the new version of the Bodyfloat) uses two springs. One supports your body weight and the other spring (at a different angle) provides damping. The Redshift only uses one spring and has no damping. If you don't like bobbing while riding the Thudbuster, you'll be far happier on the Kinekt. The Kinekt with aluminum post is on sale for $200 while the pre-order price for the Redshift is $160. It's a small premium for a superior post that's widely used.
I had a long talk with the guys at Cirrus before buying the 3.1 version and was told the BodyFloat/Kinekt posts do not have "damping" or rebound control. I believe the gist was that they believed the 2 springs were effective in cancelling out excessive bob. However when I suggested it may still be desirable to have the ability to tune rebound rate, they did agree and said this concept is being thought over for perhaps a future model. Give them a call, you should hear the same thing.
The setup is definitely more precisely tunable than Thudbuster and the swingarm/parallelogram action is more subtle than the Thudbuster. Both have preload adjustments and both can be set to provide either a solid foundation level (zero bob) or a free floating experience somewhere between the upper and lower travel limits. In action, the BodyFloat/Kinekt posts are able to provide a plusher, linear travel and the sag tuning (foundation level) does not effect the spring rate, unlike Thudbuster which ramps up firmer very rapidly as the elastomers are compressed.
My wife is only 95lbs and when we tried setting up a Thudbuster LT with the recommended elastomers and various others, we just could not get it to function well at all. At her weight (and on a mtb tandem) the LT was either too off/on (stiff) or too sloppy (soft). We tried every tuning option and finally gave up. Plus my wife absolutely hated the travel path of the LT - she really disliked how it moved her so far backward.
Then we got the Kinekt 3.1 post on our Fandango MTB tandem (a hard tail Aluminum frame) on plenty of rough single track terrain. Incredibly, at those times when I asked my wife how rough it was back there, she always replied "great!". We quickly destroyed a set of rear hub bearings, but to my wife, the ride quality was really nice with the Kinekt 3.1. You've got to be impressed by just how good the 3.1 was in this case. For Linda on the MTB hardtail, we upped the spring set to using a white upper / purple lower and loosened the "platform" somewhat to let float a bit and to maximize the effective travel.
After ruining the rear hub bearings, I decided to switch over to a Ventana ECDM full suspension. That frame is so plush that nobody I know or surveyed online uses a suspension post of any kind. We have a few rides on the ECDM now and agree, in this case no suspension post needed - though I did "cheat" a little in the build and installed a Pave carbon post we had on the Calfee road tandem, installing a Specialized Cobble Gobbler (CGR) on the Calfee instead (post setbacks dictated which post when on which frame - the ECDM has a more laid back seat tube and so the Pave was needed for that setup).
End result of all this... the Kinekt 3.1 is a greatly effective, really tunable post. The "Cadillac" of suspension posts for sure. I can see why Craig Calfee recommends this post, even for his already nice riding carbon tandems. For us the Kinekt 3.1 on the Calfee would be way overkill. My wife was very happy with just the Pave carbon post and is now on the CGR for the Calfee.
Which means... the carbon Kinekt 3.1 post has been laying in the box for months now. Not sure if I'll sell it or hang onto it just in case we go ride some really nasty areas where it could be most effective. If anyone is interested, PM me. We have extra springs for it and the spring cover as well. For any other weight/tuning needs, you can get any desired springs from Cirrus and those are quite cheap considering this is a specialty product.
This pic is the 2.1 post. The 3.1 is virtually the same but has the very long carbon lower tube.
Bikes: Trek 7.2 FX, Co-Motion Supremo
Quoted: 44 Post(s)
Did you use a shim? How comfortable are you with a shimmed carbon seatpost, assuming the frame is steel. Problems solvers says not to use their shim on carbon frames and seatposts.
just another gosling
Quoted: 3889 Post(s)
Liked 1,938 Times
Steel makes no difference. The possible issue is that the carbon post is more noble than is the aluminum shim. If the shim/post interface were frequently wet, especially with salt water such as sweat, the shim would corrode. In that event, the post could slip down, however the post itself would be undamaged, being the more noble material. We've ridden the tandem, with this post, in the rain for 5 winters and don't see any sign of corrosion, just as shiny as the day I installed it. I put grease on the outside of the shim and carbon assembly paste on the post. I have adjusted the post from time to time with no issues. So yeah, we're completely comfortable with this post.
Results matter
Results matter
Quoted: 44 Post(s)
Thanks for the feedback. I went to a Specialized dealer at lunch and talked to the maintenance dept. They said they would install a CG-R with a shim provided the seat post would stay put without exceeding the torque specs on the clamp. I ordered a CG-R and a 27.2 by 29.8 shim.
Liked 1,938 Times
Results matter
Results matter
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
A few months ago I speculated over on MTBR about full suspension for road tandems and I was mostly shot down. But threads like this one make me keep thinking of it.
Bikes: TREK Stache 5, 2013 Cannonade Carbon 1, DaVinci In2Ition tandem, RANS Screamer, Giant Expressway 1, 1975 Crescent Mark XX, Tern Link 7, Montague Paratrooper, Raleigh Talus 29, Trek LIFT, Novara Randonee, Specialized Fatboy
Quoted: 13 Post(s)
Liked 13 Times
Stoker thought it to be an improvement, however - does not articulate specific reasons. Best description I get is that the Body Float is springy vs. spongy.
Likes For fitlerbend:
