Go Back  Bike Forums > Bike Forums > Beach Cruisers
Rear of foot touches ground.
Beach Cruisers Do you love balloon tires and fenders? Do you love riding the simplicity of a single gear and coaster brakes or a single gear cluster? Do you love the classic curves in the tubing of a cruiser that takes you back to the 1950's and 1960's, stylistically? Here's your home! Welcome to the Beach Cruisers and Cruisers forum!
Old 11-25-18, 02:51 AM
PimpMan
Quoted: 111 Post(s)
Liked 7 Times in 5 Posts
Purchased used beach cruiser today frame measures 18" and it has 26" wheels.
When pedals most low position rear of my heel is dragging on the ground (unless i keep my feet horizontal) to the point that i almost able to brake with back of my foot without taking it off the pedal.
Never had this with any other bike, but i never ride cruisers before wonder if its normal or sign of having frame that is too small?
PimpMan is offline
Old 11-25-18, 08:09 AM
rhenning
Quoted: 380 Post(s)
Liked 106 Times in 80 Posts
Not normal. Got a picture or the name of the bike? Roger
rhenning is offline
Old 11-25-18, 10:50 AM
tyrion
tyrion's Avatar
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times in 972 Posts
Sounds like the saddle might be lower than optimal, and/or the tires are skinnier than the bike was designed for.
tyrion is offline
Old 11-25-18, 10:59 AM
KraneXL
Quoted: 3405 Post(s)
Liked 240 Times in 185 Posts
This.
But a picture of your peddle strokes (top, middle, bottom) would be even better.
I never heard of anything like this in all my years.
KraneXL is offline
Old 11-25-18, 11:48 PM
PimpMan
Quoted: 111 Post(s)
It don't let me upload pictures until i have 10 posts.
Bike is Schwinn cruiser no idea what model.
Seat is not much of a problem i believe because as i was making 180 turn across the road i leaned bike and pedal dragged on the road, luckily i was pedaling so it only touched road for less than second so i balanced okay.
On flat ground distance from bottom of the pedal to the ground is 3" when pedal is horizontal and when i turn pedal 45 degree distances is 2", crank arm length measures 7 1/2".
It has MTB tires installed 26 - 1.95" wheel outer diameter including tire is 26".
Regarding the frame being too small, when i stand over the frame distance between my crotch and the frame is 3", isn't this like recommended distance for proper frame size?
PimpMan is offline
Old 11-26-18, 01:04 AM
KraneXL
The best way to tell what's wrong is to see a video of your pedal storke in motion. Otherwise, the best anyone can do is to make an educated guess.
Rule of thumb. Any measurement can be modified +/- to fit your individual body dimensions, comfort and taste.
KraneXL is offline
Old 11-26-18, 02:42 AM
dabac
Quoted: 1074 Post(s)
Liked 295 Times in 222 Posts
On flat ground distance from bottom of the pedal to the ground is 3" when pedal is horizontal ... crank arm length measures 7 1/2"
When your pedal is horizontal, it is at the same level as the bottom bracket(= crank arm axle).
If your crank arm is 7 1/2" - more than twice the stated pedal clearance when horizontal - then it should strike at EVERY revolution, unless you tilt the bike vigorously while riding.
So something doesn't add up here.
Abused step-thru frames sometimes bend in the middle, that's an option.
Regular triangle frames "never" do that.
But I suppose it's possible to splay a fork forward to drop the BB.
I'd imagine the bike would ride kinda funky though.
If you can't find a model name on the bike, do an image search on "schwinn cruiser". Scroll until you find one like yours, post link.
dabac is offline
Old 11-26-18, 10:03 AM
Philphine
Quoted: 90 Post(s)
Liked 18 Times in 16 Posts
would it maybe have a bent springer on it or something (or maybe a regular springer that sags more than usual)? does the frame have a "foot forward" design? lay back seatpost? it's happened to me, but not on a stock/normal beach cruiser frame.
Philphine is offline
Old 11-26-18, 02:23 PM
PimpMan
Quoted: 111 Post(s)
Crank arm axle center to ground is 10 1/2" i think bike is stock someone just installed longer crank arm pedals on it from a vintage bike they look nothing like cruiser.
PimpMan is offline
Old 11-26-18, 03:30 PM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
size feet like a 14 shoe ?
fietsbob is offline
Old 11-26-18, 06:59 PM
KraneXL
My first though, then I remembered I wear size 48.
KraneXL is offline
Old 11-27-18, 03:33 PM
PimpMan
Quoted: 111 Post(s)
My shoe size is 10.5"
Swapped crank arm to 6" one now i have about 4.5" space from bottom of pedal to the ground in lowest position, got to move seat up a little though, but its not a problem.
PimpMan is offline
Ridefreemc
Beach Cruisers
59
05-26-22 02:24 PM
thehammerdog
Singlespeed & Fixed Gear
15
09-20-19 09:01 PM
since6
General Cycling Discussion
41
06-16-17 04:05 PM
m1aman
19
08-07-13 08:38 AM
Allen55
10
09-25-11 09:39 AM
