Show me your work bench
I have a recessed 4 to 5' x 2' area against a stud wall in my basement that I am considering making into my work bench with a peg board to hold my tools, a vise and a bench mounted polishing/grinding wheel. Bike stand would be on the floor behind me.
Show me your work benches bought or made.
Randomhead
Liked 3,687 Times
too bad you don't live closer to me, I have a bench sitting in our storage unit.
Quoted: 5223 Post(s)
Liked 3,579 Times
these are always fun threads. usually get pretty envious. I'll spare you mine, it's not attractive even tho I added things a few years ago that made it less cluttered & more functional such as
- shelves w/bins
- old dresser w drawers
- work table w bench vise
- shelf under table
- nearby tool boxes
Bikes: 1984 Miyata 310, 1986 Schwinn Sierra, 2011 Jamis Quest, 1980 Peugeot TH8 Tandem, 1992 Performance Parabola, 1987 Ross Mt. Hood, 1988 Schwinn LeTour, 1988 Trek 400T, 1981 Fuji S12-S LTD, 197? FW Evans
Quoted: 525 Post(s)
Liked 977 Times
I would build the bench a few inches deeper than the recess. Assuming you are putting a vise on the corner, you will need some access from the side for oversize objects.
Quoted: 929 Post(s)
Liked 1,289 Times
My work bench is not visible because it is about two feet deep in car, woodworking, home and bike projects. These have even spilled over onto the top of the table saw. Clearing workspace is an ongoing chore.
Quoted: 2337 Post(s)
Liked 2,813 Times
But is you could see it it would look like below (more like the one in the background).... built using 2/4, plywood and simpson strong tie bench connector kit you can also build one with the pegboard pm the back
Quoted: 796 Post(s)
Liked 522 Times
In theory mine could double as a Dinning room table but mostly its full of tools and parts . I have dreams of someday having a garage with a workbench and my Dads 50+ year old bench vise mounted to it
feros ferio
Quoted: 1391 Post(s)
Liked 1,322 Times
I have a 1930s drafting table adjacent to a smaller all-steel bench. Pegboard above and pegboard on the side wall. Bicycle storage hooks (what a concept ) in the garage rafters.
Code-minimum 2-car garage -- just enough room for two compact-midsize cars (Audi A4, VW Passat) and my toys ... er, tools and bikes.
Quoted: 1946 Post(s)
Liked 2,004 Times
I used ideas from Paul Sellers https://paulsellers.com/workbench-gallery/ to build a dining table for my son that will one day be a workbench. Pretty satisfying and I got good at sharpening my bench plane. This is Paul's. The one I built is level and the aprons are shorter.
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
Not a good pic but I built a temporary rolling bench until I get windows in one wall and the rest of the shop area built out with a permanent bench against the window wall. Park stand now anchored to the bench for a while.
Stuff in the garage lives by a rule: if it's not up off the floor it's on wheels.
Randomhead
Liked 3,687 Times
I only have once bench in use, and it's a traditional Scandinavian-style woodworking bench. I actually had it cleared off sometime late last year. Right now it's about a half hour from being cleared off.
I'm afraid the way I cover flat surfaces with projects, a bench in an alcove would be unusable pretty quickly
Quoted: 339 Post(s)
Liked 631 Times
I built this workbench for my cabinet making business 40 years ago and it has been in continuous use ever since. It is 4' x 8' and the same height as my Dewalt table saw . it is the right height for standing or sitting on a bar stool and it is on castors as is everything else in the shop so it can be moved around if necessary.
Quoted: 741 Post(s)
Liked 818 Times
Somewhere in there is a work bench. For some reason, the patio table just seems easier to get to.
43 years in the same house, still room for two cars, 7 bikes and laundry in the 2 car garage, well sort of.
Quoted: 90 Post(s)
Liked 137 Times
First let me say that I am not a builder! I built this 2' x 6' bench in 2016 when I was insulating my shop and I wanted it to be solid because I was mounting a huge vice on the corner and I didn't want the bench to ever move. I didn't take as many pics as I thought but here are a few as I was building it. What can't be seen is the Steel I used in the left corner to tie it all together and mount the vice, the 2x4's you see in the last pic each supported over 250lbs just as you see them, they were bolted and nailed in place. Also you will notice that it looks wonky because the garage is on a pitched concrete pad and the bench is level tied in to a bench I built years ago on the right side which is also bolted in place.
Glenn
Quoted: 90 Post(s)
Liked 137 Times
This is the vise I mounted bolted down through a 1/4" solid peice of Steel under and tied into the bench. I have put some brute force on it since I mounted it and not even a creek was heard.
Glenn
Sorry about the huge pics, I don't know how to make them smaller.
Quoted: 567 Post(s)
Liked 563 Times
What's the purpose of the gigantic aprons and enormous tool tray on a woodworker's (or anyone's) bench. I am bad about tools collecting on my bench but that is crazy and I can not imagine the purpose of those aprons.
Phyllo-buster
Quoted: 2297 Post(s)
Liked 2,047 Times
It's an easier way to give the bench strength and keep it all square while bypassing lower rails and/or stretcher. Less elegant to be sure. I prefer a smaller tool tray.
Quoted: 1372 Post(s)
Liked 1,749 Times
This old Falcon seemed to work OK as a tool/work bench, in the portable sense...
Likes For randyjawa:
Quoted: 796 Post(s)
Liked 522 Times
Bikes: Only my riders left...
Quoted: 350 Post(s)
Liked 782 Times
Spring cleaning...
Come on Spring!!!
Gotta get shop cleaned up!!!
Grabbed the opportunity with two days of no rain to makes some progress on my outside shop bench(s).
One made from a huge, free pallet.
Too many variables...gonna build the next one from scratch.
Mean while my inside shop is full of my winter built projects and on going projects!!!
Liked 2,813 Times
well I got cleaned up enough to sort of see it
if you look close you can see a tubie sporting a diabloscott fold, and a pair of KKT pro-ace pedals and a bunch of other stuff
the bright colored drawers on the left are re-purposed from when my son used them for legos and magic tricks
this was built using a simpson strong tie bench kit
Liked 2,446 Times
Better photo of my roller, taken upon completion of the Park stand install and before it became a mess.
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
Large, Nedium, and Small
Large for bench vise and various projects.
