Noob help
Noob help
I have a workmans HD bicycle that I'm using to get try and get into shape. The bike come standard with a wald 872 handlebar, and with the gooseneck stretched to the limit, it is still too low for me (backpain). I'm looking for advice on a handlebar that has a 2 in higher rise without significant sweep (my gut is in the way). Any ideas?
Quoted: 569 Post(s)
Liked 581 Times
Switching to a Wald 870 handlebar won't work? There are all kinds of adjustable bicycle stems that if one were to extend as vertically as possible should get you three or more inches. Coming from heavy industry maintenance I am somewhat familiar with Workman but I doubt others here are. The ones we had, if I recall correctly, were 1" stems for 1" bars, if that's what you have I can send you this one for the cost of postage. I may even have a 1 1/8" adjustable stem somewhere.
Quoted: 128 Post(s)
Liked 12 Times
Your options are
a) go for a Wald 870 handlebar as @easyupbug mentions - this has more rise than the 872
b) swap the stem (the part that connects the handlebars to the fork) for something with more rise. If you want advice on part (b), please send a couple of photos of the stem/bar area of your bike.
Finally, for future reference, consider adding something descriptive of your problem to the subject line of a post. "noob help" is way less useful than "getting my handlebars higher (back pain)", which likely means that fewer people have looked at your post.
And there are tubular stem raisers for quill-wedge stems..
you put it in the fork, then put the existing stem in on top of it
OD of the bottom half is the ID of the upper half..
of the Chrome moly steel tube..
Quoted: 6193 Post(s)
Liked 4,809 Times
If you got to raise the bars that much, is the frame really the correct size for you?
Quoted: 128 Post(s)
Liked 12 Times
Some people just prefer to sit up really straight, too.
But worth raising the question in case the OP is willing to put a lot of time/money into the bike.
kennj123
Fitting Your Bike
5
12-17-15 09:21 PM
LibertarianPrep
Mountain Biking
6
08-18-14 02:24 PM
