Can I replace an ST-EF29-7 shifter with an ST-EF51?
Old 04-19-19, 11:48 PM
mscir
Bikes: Specialized Stumpjumper, GT Aggressor, Trek 4100
My shifter on my Trek is falling apart, can I replace the right side 7 speed ST-EF29-7 that came with the bike with an ST-EF51?
I'd post pictures of the bike and shifter but I'm new and can't include links/photos until I have 10 points, lol.
mscir is offline
Old 04-20-19, 12:07 AM
Darth Lefty
Disco Infiltrator
Darth Lefty's Avatar
Bikes: '76 Paramount, Salsa Timberjack, Burley Samba, Terra Trike
Quoted: 1436 Post(s)
Liked 55 Times in 39 Posts
Yes, if it's another 7 speed. An 8 speed approximately works too. If you are only buying one side make sure it's the correct side.
Genesis 49:16-17
Darth Lefty is offline
Old 04-20-19, 12:15 AM
mscir
replace ST-EF29-7 with ST-EF51...
Thanks Darth, I'll give it a go.
mscir is offline
Old 04-20-19, 04:43 AM
hokiefyd
Bikes: 2018 Redline Zander, 2018 Giant Roam 2, 2015 Trek Verve 3, 1997 Trek 750, 1969 Peugeot PO-18
Quoted: 727 Post(s)
Liked 26 Times in 25 Posts
Be mindful of brake caliper type. The EF51 is usually for linear pull brakes only, though types do exist that will also work with short pull brakes, like cantilevers. If your bike has linear pull brakes (also called V brakes by Shimano), then you should be good to go. If you have another type of brake, then you would need to find the dual pull model of the EF51.
hokiefyd is offline
Old 04-20-19, 06:04 AM
dmark
Bikes: 84 Pinnarello Treviso nuevo record, 70 Peugot PX-10, 92 Trek 930, 81 DX4000, 88 Ironman Master
Quoted: 10 Post(s)
EF-65 has a dual pull model (4 finger, not 2 finger) for both V & Cantilever.
dmark is offline
Old 04-20-19, 10:04 AM
Bill Kapaun
Bill Kapaun's Avatar
Bikes: 86 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds.
Quoted: 645 Post(s)
Liked 17 Times in 16 Posts
You need the "4 Finger" version. (IF you have Canti brakes)
It will have a 4 in the suffix instead of a 2 (or nothing).
Bill Kapaun is offline
Old 04-20-19, 11:24 AM
Darth Lefty
Disco Infiltrator
All the info about the old shifter I can find, it's for V brakes and usually has short levers. But it's good to check.
Genesis 49:16-17
Old 04-20-19, 04:24 PM
mscir
Mine is labeled "V Brake" so I'm good to go. Thanks.
mscir is offline
