Who has Campy components on their tandem?
Old 12-04-18, 04:08 PM
joe@vwvortex
joe@vwvortex's Avatar
Bikes: Co-Motion Speedster Tandem, S-works 29r, Specialized Tarmac SL4
Quoted: 14 Post(s)
I run Campy Record 10 speed from around 2005. I do run a Dura Ace triple front derailleur from the same time frame though, along with a Campy Long Cage Record rear derailleur. I prefer the style of the shift levers and have run Campy on all my bikes for as long as their Ergo levers have been available.
The best thing about these older levers are that the front has multiple clicks so you can always trim it - it's a double lever that works fine on a triple crank. The first generation 11 speeds were the same, but the newer generation 11 speeds don't do this, nor do the 12's. The worst thing is the limited wide range cassettes out there for the 10 speed, and the newest only goes to a 11-32, if that is an issue.
I've found the newer 2015 and newer to be a bit finicky to setup compared to Shimano, but in terms of shift quality - I don't think either is much better than the other, as I just set up my wifes single with DuraAce 9100.
joe@vwvortex is offline
Old 12-08-18, 06:55 PM
Doge
Doge's Avatar
Bikes: 1979 Raleigh Team 753
Quoted: 3374 Post(s)
Liked 371 Times in 253 Posts
A C-Record, Delta brakes. Some special wheels and hubs. I'm just finishing up a 1X Di2 now.
Doge is offline
Old 12-08-18, 07:21 PM
Binky
Binky's Avatar
Bikes: Too, too many....
Quoted: 125 Post(s)
Liked 130 Times in 57 Posts
Originally Posted by AndyGrow
Just wondering who runs Campy stuff on your two-fer?
I just started the process of switching over from Shimano to all (or as much) Campy as I can get.
And PLEASE - don't turn this into a Campy vs. Shimano thread! I just wanna know who has Campy!
I do.... bits & pieces... derailleurs, pedals, brakes, levers...
Binky is offline
Old 01-20-19, 08:23 PM
Krenovian
Krenovian's Avatar
Bikes: Hers: Volagi Liscio, Kestrel 200 SCI, Niner Jet9 RDO, Ellsworth Truth. His: Kestrel 200 EMS, Niner Jet9, Psyclewerks Wild Hare. Ours: Paketa V2
Quoted: 7 Post(s)
Campy Record Ergo 10 brifters and triple FD. Shimano XT RD and cassette. Considering changing to SRAM Etap WiFli
Krenovian is offline
Old 03-27-19, 09:58 PM
MikeAndJean
Quoted: 29 Post(s)
Liked 58 Times in 18 Posts
We used Athena derailleurs and integrated shifters on a new Tom Ritchey tandem we just built. These components were combined with an 11 cog Shimano cluster and a triple chainwheel MSA crankset. The brakes are mechanical TRP calipers with 225mm Hope rotors. So far this arrangement works great. The shifting is smooth and reliable and the braking is the best I have had on a tandem (we have been riding tandems regularly since 1973).
MikeAndJean is offline
Old 04-04-19, 06:37 PM
Doge
Doge's Avatar
My 1st was Nuovo Record. ~1980
2nd same
3rd (pictured) all C record with Delta brakes
4th hybrid
5th (pictured) Shimano DA Di2.
Doge is offline
Old 04-10-19, 01:25 PM
Duo
Bikes: The Good Book of bicycling
Quoted: 535 Post(s)
Liked 36 Times in 29 Posts
2nd same
4th hybrid
very nice wheels on the co-motion
Duo is offline
Old 04-10-19, 04:03 PM
Aubergine
Bad example
Quoted: 825 Post(s)
Liked 208 Times in 95 Posts
I am putting together a 1970 Gitane Tandem now with Campy NR front and 980 rear. I put a SOMA long cage on the rear so it could handle a triple front. I have no idea yet how it will work!
Aubergine is offline
Old 04-10-19, 07:42 PM
MikeAndJean
Quoted: 29 Post(s)
Except for the hubs, brake levers, and pedals, this bike was all Nuovo Record Campagnolo. Everything but the right rear crank and spindle lasted for 43 years of continuous use.
Old 04-11-19, 02:00 PM
Doge
Doge's Avatar
Originally Posted by ElRey
... Let's argue about steel vs. carbon!!!!!
I prefer steel tandem to alloy one. I have not ridden a carbon tandem. I expect I may feel the same.
I prefer a carbon single frame to a steel one. I like Ti for single too. Not for tandems.
I prefer carbon rims to alloy ones.
I prefer alloy stem/s to carbon. Seatpost - depends. For lightest weight - alloy.
I prefer carbon bars over alloy.
Hubs - alloy over carbon
I mention the above to indicated I am not material biased, rather use biased.
Doge is offline
Old 04-11-19, 02:02 PM
Doge
Doge's Avatar
Thank you.
The front tri-spoke I believe to be a one-off for Nimble. Dave Nayer added a layer of carbon for that wheel.
Doge is offline
