Sealed bb on loose bb cups
Old 12-17-21, 03:04 PM
CrowSeph
CrowSeph's Avatar
Bikes: BMC SLR01; Cannondale Trail; Lot's of project and vintage bikes..
Quoted: 333 Post(s)
Liked 168 Times in 101 Posts
Sealed bb cartridge on caged bearing cups
Is this a bad idea to use a sealed cartridge instead the caged bearing , with the same cups?
Everything works pretty fine , but still fells wrong. 🤣
CrowSeph is offline
Old 12-17-21, 04:01 PM
70sSanO
70sSanO's Avatar
Quoted: 1944 Post(s)
Liked 2,164 Times in 1,323 Posts
I'm guessing you are using the sealed bearing spindle with the cartridge bearings against the spindle shoulder. The chamfered edge of the outer cartridge bearing race is all that is making contact with the race in the cup.
I think it would work for a very short term, until the lack of radial and lateral support on the outer race causes it to fail.
Individual cartridge bearing bottom brackets that I have used have a cups that support the outer race of the bearings on the flat surface, not just at a edge single point. There is also a separate pre-load against the outer race to keep it snug without stressing it. What you are doing is trying to juggle both against a corner edge.
John
70sSanO is offline
Likes For 70sSanO:
Old 12-17-21, 04:07 PM
squirtdad
squirtdad's Avatar
Quoted: 2338 Post(s)
Liked 2,827 Times in 1,543 Posts
best guess is not for very long
squirtdad is offline
Likes For squirtdad:
Old 12-17-21, 04:14 PM
canopus
canopus's Avatar
Bikes: Road, Touring, BMX, Cruisers...
Quoted: 135 Post(s)
Liked 173 Times in 111 Posts
Short Answer: Yes, it is a bad idea.
Follow your gut instinct.
1984 Cannondale ST
1985 Cannondale SR300
1980 Gary Littlejohn Cruiser
1984 Trek 760
1981 Trek 710
Pics
canopus is offline
Old 12-17-21, 04:34 PM
cxwrench
cxwrench's Avatar
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times in 1,489 Posts
cxwrench is offline
Old 12-17-21, 05:31 PM
mprince
Dont fix whats not broken
Bikes: Steelman Stage Race, Dura-Ace 9s
Quoted: 95 Post(s)
Liked 166 Times in 93 Posts
Why would you do this?
mprince is offline
Old 12-18-21, 03:21 AM
CrowSeph
CrowSeph's Avatar
Quoted: 333 Post(s)
As temporary solution for lack of parts 😂
CrowSeph is offline
Old 12-18-21, 09:49 AM
Troul
Troul's Avatar
Liked 2,979 Times in 1,920 Posts
That is a realllll temp setup that even I wouldn't expect it to make it worth my time to experiment with lol.
I've often wondered why hasn't a "conversion" been produced to a sealed bearing in a part once the races are pressed out. A thicker outer sealed bearing surface seems doable. Definitely would not be a common item, but it shouldn't be that horrible for the tooling to be created in order to make such oddity exist.
-Oh Hey!
Troul is offline
Old 12-18-21, 11:00 AM
70sSanO
70sSanO's Avatar
The industry already came up with a conversion when sealed bearing bottom brackets became available. I would guess a very high percentage of square taper cranks are mated to one of these.
The market for a drop-in sealed cartridge bearing replacement for caged/loose ball bearings has to be minuscule.
John
70sSanO is offline
Likes For 70sSanO:
