Campagnolo 10 speed FD Problem
Bikes: 1986 Torpado Beta, 2006 Wilier Triestina Izoard
Quoted: 73 Post(s)
Liked 15 Times
I have a Campagnolo 10 speed front derailleur that shed a part while riding and I'm looking for a spare part or fix. It is the rear part of the cage which screws into the inner cage and connects the front carbon cage with the rear metal cage. It doesn't appear to be a Campy spare part that they sell according to Campagnolo catalogs.
Does anyone know if this part is available and if not, maybe a DIY fix? The cage seems like it's spread open now and I'm afraid the carbon will break without the support of the missing piece.
Many thanks, pics below to show what I'm talking about:
Quoted: 5793 Post(s)
Liked 2,584 Times
It's been a while, so please take this with a grain of salt.
If memory serves this was integral with the inside surface of the outer cage plate and part of the steel system that keeps the chain from cutting into the carbon as you shift.
I have to wonder if you've been dragging the chain against the cage, which is fairly common with poor trim, and over time sawed through the steel.
In any case, you'll have to either find this part in a dealer scrap heap, or fabricate it from a piece of stainless and then bond it to the outer cage plate.
IMO, you're likely best bet is replacing the entire cage if you can find one or replacing the derailleur.
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
Quoted: 73 Post(s)
Liked 15 Times
Many thanks to all for the help and very helpful links, I appreciate it!
No dragging or other strange habits going on. However, my FD shifting has never been that great but this is first and only index shifting I've ever had so nothing to compare it to. Of course, that's mostly when shifting to the big chainring where the lever needs two or three swipes to complete the move. And then to the small chainring, it's pretty easy and that is where the outer carbon cage comes into play.
Also, I don't believe there is any metal to the outer cage; it's all carbon with a plastic, replaceable insert that rubs on the chain.
Thanks so much for that first link. Very helpful and within that thread, they link to this:
https://weightweenies.starbike.com/f...10cb5&start=15
In this weightweenies thread, a guy repairs his FD using a bit of old spoke so I guess I'll give that a try as the supply of 10 speed FDs has dried up; not many out there.
Also, why wouldn't campagnolo make this small part available? Or make a metal version?
Here's the spare parts catalog for the 10 speed carbon FD:
https://www.campagnolo.com/media/fil...gnolo_2005.pdf
And again, many thanks....
35mm seat tube? You can find new and used fronts, you won't like the carbon tax, but a veloce/daytona/centaur/chorus, or something in that range should be doable. I dare say a 11spd athena would probably work also.
1984 Cannondale ST
1985 Cannondale SR300
1980 Gary Littlejohn Cruiser
1984 Trek 760
1981 Trek 710
Pics
1984 Cannondale ST
1984 Trek 760
1981 Trek 710
Pics
Quoted: 73 Post(s)
Liked 15 Times
For now I'm going with the weightweenie DIY fix. Here's my preliminary fitment of the spoke fix. I have to say the use of a spoke works perfectly!
Still need to order some wire to wrap it up and epoxy to glue it all together.
Quoted: 1609 Post(s)
Liked 2,216 Times
I would mimic the original part so you can access the screw.
Campagnolo Record Titanium Carbon & Titanium Front Derailleur Braze On | eBay
Quoted: 3514 Post(s)
Liked 2,927 Times
Part of the problem may be the obvious lack of maintenance.
Quoted: 73 Post(s)
Liked 15 Times
Yeah, it does look dirty but chain was cleaned and lubed less than 1000 miles ago.
It's a dirty world out there!
Bike is well maintained but just because I don't spend my Saturday nights cleaning chains, it doesn't mean the bike is falling apart. And the problem that happened with the derailleur disintegrating is obviously a design issue and not a maintenance issue. Many have had this problem and Campy redesigned their FDs after the 10 speed groupo to completely eliminate the plastic piece that breaks off.
Of course, with logic like your's, part of the problem may be anything from my drinking to the rotation of the earth!
Liked 2,927 Times
You've got way, WAY too much lube on the outside of your chain, which has picked up a ton of excess grit, no doubt contributing to the destructive and abrasive action that helped lead to your derailleur failure. It will also lead to the premature failure of several other parts of your bike.
Logic.
You'd think people would take better care of their things. Especially the expensive kind.
Logic.
Quoted: 73 Post(s)
Liked 15 Times
Logic.
Logic.
Mine is not the prettiest but it works. I'm not sure how much stress this part experiences and I didn't want to have to fix it again if it failed so I went overboard with the wire and epoxy. But it works and it's stiffer so I'm happy. And it's better in real life....I swear. It's not very noticeable.
Liked 2,927 Times
Likes For smd4:
Broken front derrailleur
Hey guys, im a bit late to the party
i have the same issue with exactly the same front derrailleur like the topic, but my derrailleur broke, is it possible to just replace the front (only the carbon part) or can i just replace the front derrailleur with a veloce 10 speed for €27? Sad i cant keep the groupset original but something has te be done.
thanks in advance
thanks in advance
Liked 2,584 Times
FB
Chain-L site
FB
Chain-L site
- I did it with electrical tape for now, on ebay Uk i found the part that you just DYI´d but i dont know if i should order it, the taxes at customs probobly cost more then the part we need.. i cant post the url (got a notification that i need to type more messages before i can post a url)
- Just did a check out to see how much it cost with taxes, its 40 euro´s all in
- You can search on EbayUK ( Campagnolo Front Mech Derailleur 2009-2014, 10/11 Bridge, Cage, Clip, Tab)
Just find a Chorus FD and be done with it.
aged to perfection
Quoted: 839 Post(s)
Liked 1,258 Times
agree, you can find a Chorus unit and just swap the cage (which is titanium) over onto the existing clamp.
/markp
/markp
