Correct tool??
WGB
Bikes: Panasonic PT-4500
Quoted: 1809 Post(s)
Liked 2,362 Times
Correct tool??
I guess I could just try tapping with a screw driver or a punch, or, try using the Hozan tool for notched headsets but I thought I'd ask Incase I damaged the locking nuts.
What is the correct tool for these Suntour hubs?
WGB
Liked 2,362 Times
If it helps, I think they're Suntour XC.
Quoted: 573 Post(s)
Liked 1,065 Times
There is a tool for 4-pronged Suntour freewheels but not sure if it would be correct in this instance.
Yeah, I know. Real helpful. 🙄
Quoted: 3843 Post(s)
Liked 3,398 Times
i would use the VAR lock ring pliers Nr. 16
Maybe this one?:
https://www.bikeforums.net/20809270-post6.html
Likes For jiangshi:
WGB
Liked 2,362 Times
I have the VAR tool so I'll try it "carefully".
Trying to find the correct tool might take some doing. Might get one for "next time".
Thank you all
Thank you all
Likes For Hobbiano:
WGB
Liked 2,362 Times
Gets better.
I have the VAR 13, not the 16!🤬
Local man has one so I'll bike over and borrow it.
He doesn't have the correct tool either..
Quoted: 152 Post(s)
Liked 237 Times
WGB
I have the right tool.
PM me your addy and I will send it out to you.
When you're done with it you can send it back.
Unless a better option comes your way.
Rick
Rick
Likes For OTS:
WGB
Liked 2,362 Times
WGB
Liked 2,362 Times
Duplicate post
Old fart
Quoted: 3615 Post(s)
Liked 3,446 Times
The tool for the XC hubs is this one:
Likes For JohnDThompson:
Quoted: 152 Post(s)
Liked 237 Times
The tool I have is the Suntour NWN which I thought, after the the first few posts, was the correct tool.
It turns out it is a freewheel adjustment tool.
After reading additional posts to this thread it turns out I DON'T have the correct tool.
ARRRRRRRGH
Sorry
Old guy trying to be helpful mistake.
After rooting around my tools I found another Suntour tool that I have no idea if it will work.
The search continues.
This is the other Suntour tool I found and I am NOT sure it will be helpful to you.
The business end
ARRRRRRRGH
Sorry
The business end
Likes For OTS:
WGB
Liked 2,362 Times
@OTS - Maybe someone here will recognize. Does this last tool have a Suntour model number? if so mr. Google might know it's purpose
Edit: believe it's a Suntour BB tool. Question is would it engage the seals on my hubs...**********
Likes For WGB:
Old fart
Liked 3,446 Times
Found it, in a SunTour dealer catalog: TA230:
The correct tool for the XC hubs is the TA260.
WGB
Liked 2,362 Times
@JohnDThompson
I had hoped it might work in lieu of finding the TA 260.
It seems I must find the correct tool . Might post a wanna buy on the sales thread. Frustrating that I got a nice 36/40 hole touring wheel set and can't ride them, but the one wheel seems stiff when it spins so better to wait.
Groupetto Dragon-Ass
Quoted: 416 Post(s)
Liked 793 Times
I liked your idea of a screwdriver and a mallet.
You could fix it, and still be able to do it again at least three more times.
That should take the wheel set into the next century.
Likes For Chuckk:
Quoted: 394 Post(s)
Liked 346 Times
@JohnDThompson
Likes For Hobbiano:
WGB
Liked 2,362 Times
Update: I went to a local mechanic who tried the VAR 16 with a wrench and then a socket, neither could turn as they jammed against the VAR 16 which moved it's pins.
Option 2
He tried a Park Pin Spanner - BLUE ONE! (Believe it's the SPA-1)
Next step
Sorry for the blurred photo!
Worked perfectly. This is just a fancy dust cap and holding it still allows the nut to turn. To remove the sealed bearing you follow the standard procedure for removing a hub bearing once the axle is out and the bearing exposed.
In this case, it turns out the dust caps were on too tight and after they were properly adjusted the bearings spun perfectly.
Victory!
Still want that TA 260 "just to have one...."
Option 2
Next step
Victory!
Likes For WGB:
Garage tetris expert
Bikes: A few. Ok, a lot
Quoted: 390 Post(s)
Liked 700 Times
Thanks for posting a follow-up.
I've got a number of Suntour tools. Just for my edification, do you mind measuring the ID and width of the slots on that dust cap?
Likes For Hobbiano:
Quoted: 394 Post(s)
Liked 346 Times
Option 2
Next step
Victory!
Option 2
Next step
Victory!
WGB
Liked 2,362 Times
@Hobbiano - You beat me to the measuring!
And as for the blue park tool being hard to find? That is the first law of bike tools. IF YOU NEED IT, THEY DON"T MAKE IT ANY MORE AND NO ONE HAS ONE TO LOAN YOU OR SELL TO YOU!
Likes For WGB:
