Clockwise or Counter clockwise
I will be replacing the ring in the picture here. Seems I need to take the crank part off.
Which way will I be turning the bolt to take crank off?
Clockwise or counter?
picture attached
clockwise or counter?
picture attached
Counter clockwise.
Likes For Amt0571:
Quoted: 4201 Post(s)
Liked 3,857 Times
Thanks for using specific rotating directions (clockwise VS counterCW) and not the confusing "righty or lefty". Andy
AndrewRStewart
AndrewRStewart
Likes For cbrstar:
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
Shouldn't that be anticlockwise?
Likes For thumpism:
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,218 Times
Right and left are specific rotating directions. In an era of decreasing mechanical clock use, clockwise and counterclockwise has much less meaning than it once did.
Stuart Black
Stuart Black
Likes For cyccommute:
Liked 3,857 Times
So you are right in one sense but I am in another. Hope you're safe and able to ride. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Liked 4,218 Times
The way I teach my bicycle mechanic students to remember how to remove the pedals and the bottom bracket is by using the positioning of the wrench. For pedal removal, put the crank arm so that it is pointing forward at 90°. Put the wrench on (green arrow) and push down (red arrow). Do that on both sides.
For the bottom bracket, put the wrench at 90° and push down. Again, do that on both sides.
Stuart Black
Stuart Black
Liked 4,218 Times
Stuart- My reference, righty/lefty, is about which way to turn a wrench handle. It wasn't a thread direction one. When I explain this stuff to customers and they ask which way to turn the wrench they don't mean the thread, IMO that's too big a jump for a non mechanical mind to make without some guidance first. When I do try to explain thread direction (like during "how to remove your pedals") and hold the two pedal threaded ends up next to each other many don't even see the thread direction being different without some focus. I also use the light bulb reference frequently. Or the "right's right and left's wrong" to remind the customer that their left pedal is not like their right.
Stuart Black
Stuart Black
Likes For Pop N Wood:
Quoted: 2026 Post(s)
Liked 1,096 Times
When digital watches and clocks first appeared I was convinced the analog clock was doomed. Why bother with a device so subject to misreading and so difficult to teach children to understand when the digital clock was so easy to interpret. However, I failed to realize that wrist watches and wall and table clocks aren't just time keeping devices, they are jewelry, status symbols and decor. Analog clocks fill that role far better than digitals. Notice that Rolex doesn't sell any digital watches. Yes, the mechanical clock has nearly faded away but electronically driven analog clocks are alive and well. Clockwise and counterclockwise will remain well understood concepts for a long time to come.
Likes For HillRider:
Bikes: More bikes than riders
Quoted: 1446 Post(s)
Liked 762 Times
For pedals, I think Forward to Fasten, Rearward to Remove. (And then English-treaded bottom brackets are reverse of that.)
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4338 Post(s)
Liked 2,980 Times
It took me a while to figure out "right" meant clockwise because the reference was for 12 o'clock and not 6 o'clock.
Even with cw vs ccw you have to have a face reference.
Quoted: 668 Post(s)
Liked 529 Times
Just joking, you were probably an officer.
Learned that pearl at prototype in Ballston Spa. Think of turning a car.
Quoted: 38 Post(s)
Liked 34 Times
When did you go through Nuke School? I was in Orlando for ET 'A' School and Nuke Power School in '94-'95, but I went to Goose Creek for prototype instead of Ballston Spa.
It's MY mountain
Liked 2,980 Times
Quoted: 980 Post(s)
Liked 582 Times
Another example of the need for a frame of reference is unscrewing pedals. It's commonly said "turn the wrench toward the rear of the bike"... but unless something like "over the top of the pedal" is added, there's room for misunderstanding.
(/pedant mode)
(EDIT: morning fog correction. Also, I see above that there is some feeling that the terms "clock-wise" and "counter-clock-wise" are less widely understood because of digital clocks. I disagree. There are plenty of analog clocks and watches around. Now, a term that *might* be fading away is "watch-winding"... not many watches, even analog ones, require winding anymore.)
For the totally mechanically inept, I tell them to loosen it like your taking the cap off a bottle. EX: I once built a mantle clock for a now ex-girlfriend and it was running fast. She called me and asked how to adjust it. I told her she had to turn the nut at the bottom of the pendulum to lower the bob. When she asked which way to turn it, I told her to imagine a bottle upside down and unscrew the cap. It worked out well.
Likes For gearbasher:
Quoted: 980 Post(s)
Liked 582 Times
After the morning coffee, I started thinking (always a risky enterprise!). It *is* possible to describe rotation of threaded fasteners without reference to clocks.
Threads are helical structures, and helices are either "right-handed" or "left-handed".
Anyone who's had high-school physics or organic chemistry knows the "Right-Hand Rule":
If you wrap the fingers of your right hand around a bolt and rotate it in the direction your fingers are pointing, and the bolt advances in the direction your thumb is pointing, then the bolt is said to have a "right-hand thread". If it goes in the other direction, it's a "left-hand thread". (There's also a "Left-Hand Rule", but one rule is all you need.)
Most threaded fasteners are right-handed, and most people have their right hand... handy, so no familiarity with watch faces is necessary!
(Right-Hand Rule)
(Right-Hand Rule)
Bikes: 2016 Fuji Tread, 1983 Trek 520
Quoted: 676 Post(s)
Liked 741 Times
On the bike, we sometimes have to reach through the frame to work on a thread facing away from us, usually a pedal or BB. The right or left hand rule is easier (for me) than imagining a clock face from behind.
I first learned this working plumbing back in the days of threaded galvanized pipe. When you're on your back in a nasty crawlspace, working over your head, removing a male thread from a fitting that's facing away from you, and it's a lot of work to position your wrenches, you want to get it right the first time. Right and left and clock faces don't work as well in those situations.
Likes For andrewclaus:
Quoted: 980 Post(s)
Liked 582 Times
I remember those vectors...
I teach dental students to perform root canal treatments, and some of the rotating instruments that go into the canals are direction-sensitive. If the handpiece ("drill") is going the wrong way, bad things can happen. Some of the instruments are RH helices, and others are LH, and it's important to understand the difference... but many don't.
Quoted: 1106 Post(s)
Liked 1,327 Times
Quoted: 676 Post(s)
Liked 741 Times
I heard long ago that it's easier to remember analog time after a glance at a watch. How often do you glance at a digital watch, someone will ask you what time it is, and you have to look again? That doesn't happen as often with analog time. You don't know the exact time, but you'll remember "quarter after" or similar. This was way back at the advent of digital watches and I don't know if that idea has stood the test of time, so to speak.
Liked 1,096 Times
Airplane cockpit research showed that digital was not as good as analogue, mainly because the value was not so much the number indicated but the behaviours - going up, down, or staying the same. A needle moving shows that instantly, but numbers need the pilot to do maths.
