WD40 for the chain
WD40 for the chain
Hi, just wondered if it’s ok to use wd40 for the chain. Not long term use but at the moment with the poor weather I keep hosing the bike off after each ride so then spray the chain with wd40 or similar to drive out the water and stop it rusting between uses. Would this offer enough protection for quick 20-40mile rides? Or should I apply my regular dry lube too?
Thanks
Thanks
Bikes: 2021 Salsa Fargo 1x12, 2019 Jamis Renegade Exploit 1x11. Motobacne NX Fat Tire
Quoted: 198 Post(s)
Liked 332 Times
Thanks
Thanks
Likes For Toadmeister:
I do this all the time to drive water off the chain and lightly clean it, but I then let it evaporate and apply lube. This has worked for me for thirty years of riding.
Likes For Hiro11:
Expired Member
Quoted: 3674 Post(s)
Liked 5,435 Times
WD40 is fine for what you've described and will give a little protection to whatever metal surfaces it lands on as well, derailleurs, etc. Just don't neglect your actual lube, maybe consider something that lasts longer if your chain is squeaking between lubes.
Likes For shelbyfv:
For The Fun of It
Bikes: Lynskey GR300, Lynskey Backroad, Litespeed T6, Lynskey MT29, Burley Duet
Quoted: 2135 Post(s)
Liked 1,647 Times
It will work perfectly for your stated use. Much better than Mazola.
Super Modest
Quoted: 10963 Post(s)
Liked 4,620 Times
What shelbyfv said. Whenever WD40 comes up, cycling enthusiasts throw their arms up. Shouldn’t be a problem in the way the OP asked.
Keep the chain tight!
Likes For Trsnrtr:
Yes, No problem. As long as you haven't removed the manufacturers lube you don't even have to put any other oil on it. However, under those riding conditions I'd recommend using some other chain oil.
I Use Only WD40 As Chain Lube, But I keep my bikes clean and Never Remove Manufacturers Lube and because some Remove Manufacturers Lube and allow their bikes to get really dirty using WD40 isn't for every one.
Because I will not ride in the rain and only use WD40 as a chain lube, I have to respray every 250-300 miles.
Quoted: 668 Post(s)
Liked 529 Times
WD = Water Displacing.
https://www.wd40.com/myths-legends-fun-facts/
this is exactly what WD40 was invented for and named after. I've used it to waterproof distributor caps in off road vehicles. The "residue" is a fish oil, very benign.
Compressed air is good for drying the chain, but not everyone has ready access.
Quoted: 4227 Post(s)
Liked 2,488 Times
WD 40 is perfectly fine to use on the chain. I`ve used WD 40 many times. A bicycle chain isn`t some complex machine and doesn`t require any special overpriced lubricants...Special chain maintenance is pointless, here in my area all it takes is one ride on snowy salt covered roads an your expensive lube is all going to get washed out and your chain will get all dirty. WD 40 is perfect for daily touch up to keep the chain running smoothly.
Likes For wolfchild:
Liked 2,488 Times
How I displace water from wet chain after a ride is with hot air jet from vaccum cleaner exhaust nozzle attachment. Some use leaf blower and even some even seem to have success with hair dryer (perhaps with the powerful ones), with some rags or towel between the chain and bike and the floor so the blown oily water doesn't stain the floor nor the bike.
Clark W. Griswold
Quoted: 4357 Post(s)
Liked 3,994 Times
For temporary use a water displacer is probably OK but you will want to keep up with chain maintenance and lubrication. Personally I wouldn't use it unless it was their bike lube however if you are really cleaning quite often and keeping an eye and ear on it you should do OK. Keep in mind I would be quite careful using any sprays (aside from isopropyl alcohol) on a chain or near the chain as it can get onto braking surfaces and cause issues there.
Likes For veganbikes:
On Your Left
Quoted: 3004 Post(s)
Liked 2,433 Times
Another WD-40 post... AWESOME
Likes For GlennR:
Non omnino gravis
It's a winter chain. As long as it still moves, it doesn't really matter what lube is on it, right? It's 15 bucks. Use it 'til the weather gets nice, chuck the chain in the garbage.
For all of the WD40 hooters and hollerers, y'all do know that WD40 has a whole line of bike products now, yeah? It's not 1950.
Quoted: 1062 Post(s)
Liked 665 Times
Hydrocarbons displace water. News at ten.
For all intents and purposes, WD-40 is a mixture of mineral spirits and light oil. The mineral spirits evaporate and leave a thin coating of oil. Whatever else is in it, is irrelevant. It has brand recognition and comes in a spray can.
Use it wherever you would use a mixture of mineral spirits and light oil. Mineral spirits are also the carrier for dry lube. Light oil does whatever you think it does to a bike chain, relative to your chain lube preferences.
Klaatu..Verata..Necktie?
Quoted: 10428 Post(s)
Liked 11,902 Times
This. WD40 is not a lubricant.
Quoted: 1248 Post(s)
Liked 1,323 Times
It’s a bicycle chain not the inner workings of a Rolex. I live in a very rainy place and for 40 years post ride as I roll into the garage I blast with a healthy spray of WD-40 and call it a day. It displaces the water so nothing rusts and leaves behind a thin coating of lubricant whats the big deal.
Liked 11,902 Times
I did, that's why I 'Liked' your post. I was concurring.
As an aside, my other hobby is vintage mechanical watches, where WD40 is the bane of many a collector/hobbyist. It pretty much ruins the ones where some genius sprays it in the movement. Watchmakers say they can always tell a watch that's had that treatment because of a 'fishy' smell, and greenish oily residue that's the very devil to get rid of.
Likes For genejockey:
Quoted: 198 Post(s)
Liked 332 Times
Liked 11,902 Times
Homey
Quoted: 2427 Post(s)
Liked 1,407 Times
I think for your application it's fine. It is Water Displacement formula number 40 after all. You'll lube it properly afterward so I think you're on the right track!
Likes For Siu Blue Wind:
Likes For Paul Barnard:
