Process to change handlebars
Bikes: All-City Space Horse
Hey Bike Forums -- long-time listener, first-time caller here.
I'm hoping to get some insight into the process of changing handlebars (and brakes/shifters as necessary. The bars right now are a cruiser style and I'm hoping to install some drop-bars. Essentially I'm wondering if this is a do-able project for someone with pretty basic bike maintenance skills and pretty basic bike maintenance tools. I know I could probably get this done at my LBS, but I sort of want a project to work on and hopefully learn more about bike maintenance/building along the way. But I also don't want to spend a bunch of money on parts and tools only to find out there's no way I can complete this without some serious expertise.
The bike in question is a Raleigh Lenton (I want to say 80s or 90s?). I tried adding a photo here but I don't have enough posts to do so yet.
Some final questions (and if I'm overstepping what this forum is meant for please let me know):
Thanks in advance for any information and if there is anything else I can add that will help providing assistance do let me know.
Z
- Is this realistic for a relative newbie to bike maintenance?
- Is there a list of essential tools I should have for something like this?
- Is there already an excellent guide/tutorial that covers all this that I have missed?
Z
Quoted: 1438 Post(s)
Liked 1,092 Times
The brake levers for cruiser-style bars do not usually work well on drop bars, so those will need to be changed and will need to be compatible with your brakes. There is a possibility the shifters may need to be changed as well. Also, you may need to change your stem as the "reach" of cruiser and drop bars are different. None of these tasks are difficult or require special tools, but one thing tends to lead to another with these kinds of changes.
With a mighty wind
Quoted: 1086 Post(s)
Liked 858 Times
I don't think it's a matter of technical ability but a matter of how much money you're willing to throw at it.
Off the top of my head.
There is a decent chance that drop bars will not fit the stem on your bike.
Where are the shifters? If they're mounted on the handlebars, the entire mechanism needs to be swapped. If they're on the down tube or stem, or if there are no gears, that would help.
The brake levers will need to be changed to something designed for a drop bar. If you get the type without integrated shifters, they aren't expensive.
You'll need to learn to wrap up a pair of bars. It's not hard and everyone needs to know that.
Cables and housing replaced.
How does the rest of the bike run? Is it a giant pile of crap or is it a good running bike?
I think that unless you have a deep desire to run an old cruiser as a drop bar, it's rarely worth it. Nothing against drop bars, I think 8 of my bikes have them.
Quoted: 581 Post(s)
Liked 921 Times
I couldn't find any mention of a Raleigh Lenton later than the early 1960s. Please respond to a couple more posts so you can post pictures. I am very curious to see what you have!!!
Quoted: 581 Post(s)
Liked 921 Times
Post ii:
Also, if I am correct and the bike is much older than 80s/90s, you will likely have more compatibility issues than we could even guess. Is it a 3 speed?
So more of a how much time/resources I'm willing to put into it question, eh?
Assuming the the brake levers need to be changed - how does one tell if they are compatible with the brakes?
Over the hill
Quoted: 996 Post(s)
Liked 1,203 Times
As mentioned above, this could be a large project which you might spend more on than just buying a similar bike with a drop handlebar. If you're absolutely in love with this bike and just want a drop bar on it, a basic set of tools should get it done, except you'll want something to cleanly cut the cable housing (Dremel, housing cutter, or mini bolt cutter).
As for a tutorial, Sheldon Brown is a great source to check for things like this.
https://www.sheldonbrown.com/deakins/handlebars.html
It's like riding a bicycle
Likes For urbanknight:
Quoted: 164 Post(s)
Liked 44 Times
you miught want to start at the stem , you most likely have the older quill stem , if you want to convert your entire front end it might be more cost effective to just buy a newer road bike , that would be the option i choose rather than spend 400 bucks swapping everything over , unless you REALLLLLY like the bike and you HAAAAVE to ride it !!!!!
so if you want to convert just start at the stem , it will be most likely going to give you the option of the drop bars and brake levers , and using friction shifters on the down tube , stem , or bar ends , they are pretty easy to index and can work with the older style of derailleurs .
your bike might be from the 60s or 70s , is the single speed version , you might not even have to worry about shifters , just swap the bars buy some brakes and get some bar tape , or dont
if you want to upgrade to modern stuff , like a 9 speed you might have to make sure you have enough space in the back , if your wheels are 27 , you might want to convert to 700 if possible, then you can just buy a 9 speed group set and a cable pack and you should be good !
Quoted: 2599 Post(s)
Liked 1,924 Times
If you can find a road bike with drop bars in a similar size on craigslist near you, go buy that instead. It'll be about the same price and ready to ride.
Quoted: 1572 Post(s)
Liked 643 Times
Just do it! You can do this.
There will be stupid details every step of the way for you to figure out. None are very complicated and working through them, for me at least, is part of the fun. You'll be smarter when you finish than you are now.
I understand what others are saying too -- probably going to be a pain and there are certainly paths of lesser resistance here. But while I find myself in a position of having an extra bike just laying around I think I may as well just dive and in see what I can learn along the way.
Likes For zabicdrozda:
