Is mildewy cutting board safe?
Old 05-10-20, 07:18 PM
Lascauxcaveman
Lascauxcaveman's Avatar
Quoted: 1542 Post(s)
Liked 356 Times in 210 Posts
I've been told black mold is bad for you. The amount you're likely to ingest from what's on that cutting board will definitely kill you. In a hundred years or so.
But aesthetically, I'd hit it with a belt sander, too. Since it's end grain (absolutely the worst way to make a cutting board, BTW) a planer would be harder to use. And since it's end grain, the mold probably goes pretty deep.
● 1971 Grandis SL ● 1972 Lambert Grand Prix frankenbike ● 1972 Raleigh Super Course fixie ● 1973 Nishiki Semi-Pro ● 1980 Apollo "Legnano" ● 1984 Peugeot Vagabond ● 1985 Shogun Prairie Breaker ● 1986 Merckx Super Corsa ● 1987 Schwinn Tempo ● 1988 Schwinn Voyageur ● 1989 Trek 400 ● 1989 Bottechia Team ADR replica ● 1990 Cannondale ST600 ● 1993 Technium RT600 ● 1996 Kona Lava Dome ●
Lascauxcaveman is offline
Old 05-10-20, 08:04 PM
ahsposo
Turgid Member
ahsposo's Avatar
Quoted: 4374 Post(s)
Liked 1,090 Times in 675 Posts
Might not be mold. Maybe it's just beef blood that soaked in.
Originally Posted by CarlJohnson View Post
i dont care who he is cos im carl and im awesome
ahsposo is offline
Likes For ahsposo:
Old 05-10-20, 09:01 PM
clemsongirl
Quoted: 334 Post(s)
Liked 1,060 Times in 333 Posts
Originally Posted by Russ Roth View Post
This is completely inaccurate, while tests show that a new plastic cutting board is easier to sanitize once the board has been used a couple times it can be nearly impossible to thoroughly sanitize
the main advantage of a polyethylene cutting board is i can use my dishwasher’s sani/antibacterial cycle to clean it.
clemsongirl is offline
Old 05-10-20, 09:20 PM
Russ Roth
Quoted: 299 Post(s)
Liked 203 Times in 153 Posts
I've read several tests coming out of a couple universities that suggest that once the board is sufficiently scored it can't get as clean as wood. and the virus can even thrive. I'm a little biased as I make some really nice cuttings boards for some fairly decent money as a side hobby but I spent a lot of time researching finishes, glues, woods and safety concerns. Ultimately wood kills food borne pathogens and plastic can help it thrive.
Although I don't recommend it, my MIL put her cutting board in the dish washer almost every day for 6 months straight, didn't oil it and often took it out and laid it flat to dry which started to cause warping after 6 months. A final trip through the washer, a soak in mineral oil and a 2 day dry on edge and not only did it flatten completely it went another 6 months before the first stress crack appeared so they can take some abuse.
Russ Roth is offline
Old 05-11-20, 12:00 AM
clemsongirl
Quoted: 334 Post(s)
I've read several tests coming out of a couple universities that suggest that once the board is sufficiently scored it can't get as clean as wood. and the virus can even thrive..
my dishwashers sani-antibacterial setting provides 170 degree water which will take care of bacteria and viruses…..since i don’t get scored knife marks deep enough to matter (those shouldn’t be a problem at 170 anyway) i’m not worried about that either. Personally a good polyethylene one is just quicker and easier for me to use and sanitize.
Likes For clemsongirl:
Old 05-11-20, 06:56 AM
Stadjer
Stadjer's Avatar
Quoted: 2848 Post(s)
Liked 245 Times in 177 Posts
That's what I learned too, the temperature of the water kills the bacteria, the soap is just to remove matter and whatever poisonous **** bacteria have produced. The hot tap is usually hot enough but you have to check. I use mostly end grain bamboo lately.
Stadjer is offline
Old 05-11-20, 02:34 PM
clemsongirl
Quoted: 334 Post(s)
personally i wouldn't count on tap water being hot enough, 140 degrees is the lowest that might help with some bacteria and viruses ....the temp my dishwasher uses for sanitizing would very quickly cause third-degree burns on skin.
Old 05-11-20, 02:41 PM
Quoted: 11383 Post(s)
Liked 3,022 Times in 1,682 Posts
Anyone else seeing ads for mold remediation at the end of this thread?
Likes For indyfabz:
Old 05-11-20, 03:16 PM
clemsongirl
Quoted: 334 Post(s)
(here)
Old 05-11-20, 03:18 PM
Hondo Gravel
Viking Berserker
Hondo Gravel's Avatar
Bikes: Too many Motobecanes
Quoted: 1249 Post(s)
Liked 1,098 Times in 709 Posts
Hondo Gravel is offline
Old 05-11-20, 05:58 PM
Eagerly awaiting the next thread.
Likes For indyfabz:
Old 05-11-20, 06:21 PM
Hondo Gravel
Viking Berserker
https://www.bikeforums.net/foo/12010...-here-lol.html
Here you go Indy. Don’t be so serious I know times are serious but chilling is good for the soul.
Old 05-11-20, 07:47 PM
ahsposo
Turgid Member
ahsposo's Avatar
"First Aid for Paper Cuts?"
ahsposo is offline
Old 05-11-20, 08:11 PM
wgscott
Occam's Rotor
wgscott's Avatar
Quoted: 2366 Post(s)
Liked 1,239 Times in 650 Posts
Is breathing safe?
Not when you inhale mouldy sawdust.
wgscott is offline
Likes For wgscott:
Old 05-12-20, 12:00 AM
Lascauxcaveman
Not when you inhale moldy sawdust.
Breathing sawdust (even sans mold) is bad enough. I've read the species of wood makes a difference, though. Also that long term exposure to high concentrations of any very fine solid particulate is a lung-clogger.
Likes For Lascauxcaveman:
Old 05-12-20, 03:38 AM
I like that, and maybe I can learn something. Few weeks ago I got a paper cut assembling boxes for our office move. I didn’t know what to do so I called 911.
Old 05-12-20, 03:40 AM
ahsposo
Turgid Member
ahsposo's Avatar
You are so stalwart! Pioneer stock, and all that.
ahsposo is offline
Old 05-12-20, 08:25 AM
Juan Foote
LBKA (formerly punkncat)
Juan Foote's Avatar
Quoted: 1150 Post(s)
Liked 127 Times in 95 Posts
Wash it well. Wipe it down with some bleach. Properly seal it with mineral oil (etc) and don't worry about it with proper care.
Juan Foote is offline
Old 05-12-20, 11:42 AM
Chr0m0ly
Chr0m0ly's Avatar
Bikes: '84 Miyata 610 '85 Miyata 710, ‘86 Miyata 710, ‘91 Cannondale ST600, ‘84 Trek 610, 520, 620, ‘91 Miyata 1000LT, a few frames, some odds and ends....
Quoted: 619 Post(s)
Liked 224 Times in 145 Posts
So this is what happens when cyclists have been home for weeks. I love it.
If it were me I’d bleach it first, THEN sand it with course paper tacked to a wood block, then oil it.
“once a day for a week, once a week for a year, once a year for a lifetime”
Next let’s discuss proper cast iron seasoning. No, that’s not controversial enough. How about “do you use soap to clean your cast iron?” That should generate a few pages!
Chr0m0ly is offline
Likes For Chr0m0ly:
Old 05-12-20, 11:44 AM
skijor
on by
skijor's Avatar
Quoted: 681 Post(s)
Liked 191 Times in 116 Posts
What rock have you been under?
https://www.bikeforums.net/foo/11980...-cookware.html
skijor is offline
Old 05-12-20, 11:55 AM
Chr0m0ly
Chr0m0ly's Avatar
Quoted: 619 Post(s)
I’ve been holed up in the C&V section!
I had no idea...
it’s like I’ve gone through the coat closet and found Narnia...
Chr0m0ly is offline
Old 05-12-20, 12:22 PM
skijor
on by
skijor's Avatar
Quoted: 681 Post(s)
I had no idea...
No worries. I love the passion that folks put into their hobbies. I'm not a woodworker. But I do love my CI, my home-roasted coffee, my espresso, etc.
skijor is offline
Likes For skijor:
Old 05-16-20, 09:37 PM
mtb_addict
Quoted: 3225 Post(s)
Liked 64 Times in 56 Posts
i just want to following up by saying the black mildew is still there, and i began using the board.
before using it, i soaked the board in water with tablesalt, as recommended by locals. the water was very brown whe i poured it away, after soaking for 3 days.
the board still smells very bad...like stinky gym socks.
the board is allegedly made from “steel wood”.
i am worry about what harmful chemical might be continuously leaking out of the board, onto food.
mtb_addict is offline
Old 05-17-20, 08:18 AM
FiftySix
I'm the anecdote.
FiftySix's Avatar
Bikes: '13 Norco CityGlide 8IGH, '12 Schwinn "Speedster" Willy SS
Quoted: 914 Post(s)
Liked 804 Times in 585 Posts
If you haven't tried bleach yet, why not? Bleach is a mold and mildew killer.
Salt is good for killing slugs and snails.
FiftySix is offline
Old 05-17-20, 08:35 AM
AnthonyG
AnthonyG's Avatar
Quoted: 2310 Post(s)
Liked 138 Times in 101 Posts
Meh. I think I would be writing it off at this point. I don't recommend using a smelly cutting board.
AnthonyG is offline
