26 inch wheel shopping
Bikes: 2020 Lynskey GR300, 1987 Diamondback Ascent, 1991 Skykomish Marble Point, 1994 Specialized Stumpjumper FSR, 1996 Specialized Stumpjumper M2 FS, 1992 GT Karakoram
Quoted: 69 Post(s)
Liked 226 Times
I hate to start a new thread so please point me in the right direction if one exists.
I am having a tough time finding 26 inch wheelsets to fit my 87 specialized hard rock. Front hub spacing 100mm, rear spacing 130mm between dropouts. Ideal internal width less than 25mm. Currently 6 speed cassette so don’t mind upping to 8 speed. Hubs are loose bearing so wanting sealed. Also rear isn’t quick release so hoping for QR in case of flats. Goal is QR and lighter thinner wheels than existing 26x1.95.
LBS can’t locate through their distributors as well. I tried nashbar, merlin and couple no name sites bit no luck. Any help or links appreciated, thanks in advance.
Quoted: 69 Post(s)
Liked 226 Times
I guess I should’ve posted in the marketplace. Sorry
26in wheels are not very valuable so not many people are willing to ship used sets. You can usually spread the dropouts enough to fit a 135mm hub, but I have cut down a 135mm Shimano axle to 130mm before. You'll need remove a spacer, center the hub on the cut axle and possibly re dish the wheel afterward.
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12778 Post(s)
Liked 7,694 Times
-Rear Axle: QR x 135mm
Quoted: 69 Post(s)
Liked 226 Times
Thanks guys. Didn’t know the dropouts could be spread out to accommodate 135mm. That’ll definitely open up some options.
Bikes: everywhere
Liked 7,694 Times
6-speed is probably threaded freewheel instead of freehub, so you'll need to buy a cassette to go on most 135mm QR wheels that you'll see available today.
Bikes: '04 LeMond Buenos Aires, '82 Bianchi Nuova Racing, De Rosa SLX, Bridgestone MB-1, Guerciotti TSX, Torpado Aelle, LeMond Tourmalet 853, Bridgestone Radac
Quoted: 101 Post(s)
Liked 46 Times
Do some online digging for Shimano Deore M525/Sun Ringle wheels. The rear is 135mm with a 8/9/10 cassette. Good sturdy wheels and used to be available for less than $150. If you end up having to go 8sp, I'm a big fan of Grip Shift. They're less than $20 and just plain work.
Likes For Eric S.:
Bikes: 2022 Fuel EX 8, 2021 Domane SL6, Black Beta (Nashbar frame), 2004 Trek 1000C for the trainer
Quoted: 270 Post(s)
Liked 447 Times
I run the Sun Ringle wheel in the rear but a disk brake. Replaced an old Mavic wheel that cracked The Sun Ringle have rim brake versions. Good wheel with many spokes for thrashing. Above is correct. You will need a cassette but a good upgrade. I ordered mine through a local bike shop. Got a 10% discount for bike club membership.
I went disk in the rear because I had to replace my frame. Front is still rim brake. An old Ringle hub I built up so it has sentimental value.
