Road Fork Design Question
Bikes: Current: 2016 Bianchi Volpe; 1973 Peugeot UO-8. Past: 1974 Fuji S-10-S with custom black Imron paint by Stinsman Racing of PA.
Quoted: 215 Post(s)
Liked 204 Times
I have a question for the framebuilders.
What is the reason that there has been a great increase in the use of straight-legged forks versus the more traditional curved blades? This is not a question related to trail.
By this, I am asking if there an engineering (1” or 1 1/8” steerer, disk/caliper/canti/v-brake, etc.) rationale, or are there material choice (steel, Ti, alloy, carbon) justifications (or both), or is for ease of mass production by major brands (no bending of blades) that is driving this change. Or is it more of a stylistic / popularity move?
Thanks.
Thanks.
Randomhead
Liked 3,687 Times
Engineering in framebuilding is extremely rare, outside of testing. My understanding is Colnago introduced straight blades a couple of decades ago because it was cheaper. We have just gotten used to the looks.
Likes For unterhausen:
Team Beer
Bikes: Too Many
Quoted: 114 Post(s)
Liked 159 Times
I would guess that it's just easier to build and requires one less tool. The trade off is less control over rake.
I'm not one for fawning over bicycles, but I do believe that our bikes communicate with us, and what this bike is saying is, "You're an idiot." BikeSnobNYC
Quoted: 4195 Post(s)
Liked 3,837 Times
Straight or curved blade shaping has nothing to do with how much or little rake/trail there is. The exact same amount of both can be made with either type of blade. The suggestion that a straight blade restricts the rake options is a, sadly too frequent, miss conception. Andy
AndrewRStewart
AndrewRStewart
Team Beer
Bikes: Too Many
Quoted: 114 Post(s)
Liked 159 Times
Randomhead
Liked 3,687 Times
there is considerable slop in those 7 degree fork crowns. I made a straight blade road fork with 55mm rake, for example. OTOH, every bike made in the last decade has 45mm rake.
Team Beer
Bikes: Too Many
Quoted: 114 Post(s)
Liked 159 Times
I have done the same but the fork I built was around 390-395 A-C but I had a really tight fit with mine which I preferred because I was using silver Anyway, that's good info, I'll switch to brass for the next one I have get personal with.
Randomhead
Liked 3,687 Times
I don't think there is anything wrong with using silver
Liked 3,837 Times
I note the lack of exclusion in the OP's question or the initial replies. If one wants a specific type of construction then say so right off the bat and don't assume we can read your mind. Andy
AndrewRStewart
AndrewRStewart
Team Beer
Bikes: Too Many
Quoted: 114 Post(s)
Liked 159 Times
As mentioned when using an off the shelf crown with a set blade angle there's some room for blade fit. Then there's the blacksmithy added amount. Then there's the self made crown method. Then there's the segmented fork. Then there's the unicrown fork. And oh, did I mention the drop out fit into the blade end can change the rake too?
Quoted: 215 Post(s)
Liked 204 Times
Actually, I did not exclude or include anything as I was seeking info on why there has been the shift to the straight blades on many current bikes and wanted to get a non-judgemental explanation which I did receive. My question deliberately avoided the trail aspect as the distance from the steerer centerline to the axle (rake) is the same whether it takes a longer curved blade or a shorter straight blade and that the trail/rake calculations is a frame/fork fitting and geometry design issue. This is part of my education as I am considering a steel frameset that I want to have select modern features, but with a traditional appearance and clearance for a second wheelset with up 700x38mm tires.
Personally I do not like the appearance of straight blades (granted, that is my taste), but was curious if maybe it was for discs brakes (similar to the rise of through axles), and wanted to see if there was a technical design justifications from a frame builders viewpoint. I prefer the look of a curved blade, and wanted to continue to use cantilevers brakes and a more traditional frame (although a slightly sloping TT is fine), but I like to ride a bike with a French fit so the bike has the bars and seat close to level.
Quoted: 321 Post(s)
Liked 263 Times
See: https://ceeway.com/NEWPARTSPAGES/Cast...k%20Crowns.htm. A few of those have a 7 degree rake built into the crown and say they are for straight baldes.
Liked 3,837 Times
I should apologize for taking out my frustrations on this forum. These days I'm getting home rather burned out from the bike shop. As many of you know some of us (like in NYS) have been going full bore and still falling behind in the service while we also are disappointing so many customers with the inability to supply them with their needs. It is getting harder to answer the same few questions over and over (Are you open? Do you have a XXX bike in 20" and blue? Why can't you just ramp up your staff so my bike can be fixed sooner?) I should have been more specific to who I was referring to in my rant, or just have been less rantful
As mentioned disk brakes have changed how forks are designed. It's far easier to weld/braze on a disk caliper mount onto a straight blade then a curved one. I do find it interesting that, unlike rear drop outs, there's no commonly available front drop outs with a caliper mount already included. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Randomhead
Liked 3,687 Times
Some people have asserted that a straight blade withstands disc braking forces better than a curved blade. I'm not sure I believe that, I think it's just as easy to put a backwards bend into a straight blade as it is to unrake a curved blade.
Straight blades predated widespread use of disc brakes, so that's not why companies are using them. I know there are a lot of people that like the looks of straight blade better
Liked 3,837 Times
Eric makes a good point about the historic use of straight blades. I think every high wheeler I've seen (and ridden) have had straight blades. Also the comment about the bendability of a straight VS curved blade is what I feel is correct. But count me on the curved blade looks better side of the road.
Off to the war now. Andy
AndrewRStewart
AndrewRStewart
Team Beer
Bikes: Too Many
Quoted: 114 Post(s)
Liked 159 Times
I think you just buy a cast crown with a bit of an angle built into. Then the blades go straight in.
Team Beer
Bikes: Too Many
Quoted: 114 Post(s)
Liked 159 Times
Maybe because 90 % of the disc brake bikes sold use a carbon fork so not much market for a steel one. OTH there is a much larger market for steel frames to use disc brakes, just a thought.
One thing I grasp, A disc caliper exerts a force un bending a bent blade tip a little ( amount Varies) when on the back of the left blade.
so you stiffen the blade, harsher the ride .. ISO mounts with a spine spreading out the force only seen with a straight base..
Never seen or ridden a Tout Terrain bike with a fatter left than right.. fork blade for disc brake adaptation..
only own a stubby straight fork, 20" wheel Bike Friday disc.. bike, myself .. One other bike Tange MTB fork Curved is drum braked.. the rest rim.
Offset by triple hole twin plate fork so parallel offset to steerer, and a bit of rake 40-622 wheels went on the tour/cargo-bike..
some design winging it on that one.. mean to measure the trail someday
SJS Cycles did say no discs on their raked forks, just straight ones.. haven't looked at it changing , since..
Quoted: 2337 Post(s)
Liked 2,811 Times
