Internal cable routing frame
Can you list the types of cable you know which go in the frame of a bicycle? Apart from shift, brake and dropper, what other types of cable go?
Expired Member
Quoted: 3657 Post(s)
Liked 5,393 Times
Is this a trick question? In theory you could route cable to control anything you wanted- turn signal semaphore, rocket launcher....
Sr Member on Sr bikes
Dan
I meant what are the other things apart shift, brake and dropper cablrs we can route internally? Examples of parts.
Clark W. Griswold
Quoted: 4335 Post(s)
Liked 3,958 Times
You can route just about anything internally. I have my dynamo cable running through my fork leg on one of my bikes. On the e-bikes you have tons of internal cables for the batteries and displays and controllers.
What specifically are you looking for? What do you hope to get out of your question? Do you have a cable or something you need to go internal?
I think we've covered just about everything that requires some sort of control cables/wires that you'd want on a bike.
-Brakes
-Shifting
-Dropper seatpost
-Wired computer
-Electrical lighting
Seriously...what else could there be that you want on a bike?
Ahhh!!! I've got it. Internally routing of the antenna cable for your CB radio!?!?!?
Dan
-Brakes
-Shifting
-Dropper seatpost
-Wired computer
Dan
Bikes: 2021 S-Works Turbo Creo SL, 2020 Specialized Roubaix Expert
Quoted: 762 Post(s)
Liked 4,029 Times
I’m disappointed nobody mentioned flux capacitor.
Likes For MattTheHat:
