Need Recommendation: Cable Cutters
Quoted: 479 Post(s)
Liked 277 Times
For the bike-specific stuff, e.g. cassette removal, BB wrench, etc., I typically default to Park. But, for tools that have broader applications, e.g. torque wrenches, screw drivers, cutters, etc. I'm not sure Park is always the best bang for the buck. Well, unless you're going for a full-on blue-handle matchy thing ;-)
I'm looking for good cable housing cutters. I'm sure the Park tool is good. But, I'm wondering if there's a cutter out there that's as good or better for less than $35 (or better for the same or more $$$).
Mostly Harmless
Bikes: Have two wheels
Quoted: 13714 Post(s)
Liked 4,530 Times
Not a fan of the Park cutter. We use Jagwire Pro cutters at the shop. Very durable. Clean cuts. Awl in the handle.
I use a Birzman cutter at home (replaced my Park cutter). Also makes clean cuts. Shaping tool in the head. Don't know about durability yet, but it's sturdy.
Bikes: Cervelo S3
Quoted: 38 Post(s)
MY park tool cutter has served well over the years, no complaints, I’m not a park tool diehard either, I own other tools that work just as good as park tool for half the price. Don’t cheap on cable cutters though.
Heft On Wheels
Quoted: 887 Post(s)
Liked 560 Times
I went to the box store and got one for $15. The price is cheap but the quality is not. Works like a champ and I only use it on cables. That is the key here, only use it on cables an it will last you forever! Save the money on this overpriced tool and get one at a box store. Then use the left over budgeted money to get another tool you might need.
Bikes: TRIMMED DOWN THE HERD
Quoted: 1092 Post(s)
Liked 936 Times
I've been happy with the quality of this one from EBay:
https://www.ebay.com/itm/Kengine-CT-...item5688122bec
After almost two years and about 40 or so bikes, it's still doing a good job of pretty clean cuts.
Bad example
Quoted: 826 Post(s)
Liked 212 Times
I have never had an issue with Park cutters on cables or shift housing. The only thing that could be improved is cutting brake housing. If anyone knows of a tool that can cut spiral-wound tubing without kinking the metal, I’d love to know about it.
Quoted: 1975 Post(s)
Liked 232 Times
I found the best way, regardless of the cutters, is to insert the cutters between the spirals, and cut through the coil last so it doesn't crimp into the liner. Then file the end smooth and square
Bad example
Quoted: 826 Post(s)
Liked 212 Times
Yep, that is what I do as well.
Quoted: 4806 Post(s)
Liked 3,929 Times
I have the Shimano cable cutters and use them for both wire and housings. Very good for the wire. I clean up housing cuts with a sharpened 14 ga/2mm spoke (known throughout Portland bike circles as "pokey tools". Sometimes I get fancy and further dress the cable ends with a file.
Workbench trick - staple 3" of cable housing to the bench. Stick your pokey tool in the housing. Always right there whenever you cut housing (and very useful for a lot of other things).
Ben
Ben
Semper Fi
Quoted: 1172 Post(s)
Liked 358 Times
Pedro's cable cutters have served me well. They look similar to the Jagwire cutters above.
Bill
Bill
Semper Fi, USMC, 1975-1977
For outer cables I find a diamond wheel cutter on a Dremel is better than a cutter. Doesn't squeeze the housing. For the wire you can use any good side cutter.
Clark W. Griswold
Quoted: 4357 Post(s)
Liked 3,994 Times
I got the Jagwire cutters myself. I use their cables and housing on many of my bikes (actually probably all of them) as well as other stuff from them so it seemed logical to get a cutter from them. So far great quality and well made.
Should Be More Popular
Quoted: 22599 Post(s)
Liked 8,926 Times
Quoted: 4236 Post(s)
Liked 2,949 Times
I use a Park cutter for cables. I used to use it (followed by a ice pick to open any crushing and then a file) on the housing. Now that I have a good Dremel, that's what I use for housing.
Quoted: 477 Post(s)
Liked 16 Times
My preference is my wireless Makita angle grinder with a diamond cutter for housing. Clean uncompressed cuts.
For wire cable and housing if I'm too lazy to get my Makita angle grinder, my preference is the Knipex wire cutter (made in Germany), the best in the business, also has an awesome built-in crimper for your cable end. Park tool is overrated.
I never finish anyth
Bikes: 2008 Merckx LXM, 2003 Giant XTC mtb, 2001 Lemond Alpe d'Huez, 1997 Lemond Zurich, 1989 Cannondale ST, 1988 Masi Nuovo Strada, 1983 Pinarello Turismo
Quoted: 294 Post(s)
Liked 137 Times
I have Knipex cutters for brake and shift housing/cables. They are expensive but the quality is exceptional. if you don't lose it or loan it out, you'll never need to replace them.
Dale, NL4T
Dale, NL4T
Likes For speedevil:
Bikes: 333fab Ti, Davidson Ti, Guru Flite CX, Peugeot PXN10E
Quoted: 17 Post(s)
Shimano SIS cutters. Mine have regular use and are about 30 years old. One of my favorite tools.
Never been a Park fan.
Swiss, Felco cable cutters https://www.felco.com/
https://www.felco.com/us_en/our-prod...e-cutters.html
Bad example
Quoted: 826 Post(s)
Liked 212 Times
Bikes: 2023 Canyon Aeoroad CF SL, 2015 Trek Emonda SLR, 2002 Litespeed Classic, 2005 Bianchi Pista, Some BikesDirect MTB I never ride.
Quoted: 647 Post(s)
Liked 136 Times
Wait, if you are having difficulty with the value of Park tools for a cable cutter, why would you feel the need to own any Park tools? I'd be surprised if the overwhelming vast majority of tools don't have a non-Park equivalent, so why choose Park at all? In any case, I have owned a Performance bike cutter, and it was crap. I now have the Park version, and it's only moderately better. Cuts cables just fine, the housing...not so much.
Quoted: 479 Post(s)
Liked 277 Times
For example: Estwing and Park sell hammers for around $25. I've got to assume Estwing's is going to be the better value. But, Estwing doesn't sell a chain breaker. So, I own a Park chain breaker.
