Fixie cog slip/skip
Fixie cog slip/skip
I have a fixie with flip-flop hub, I usually ride with the singlespeed side, but once I want to use in fixed gear, but when I apply back pressure on the pedal, or pulling up with the strap, like trying to skid, the cog slip or skipping some teeth, I can't describe well how it feels. The cog and the lockring was tightened up, but the problem isn't gone.
Any ideas?
Any ideas?
The only explanation for this is that your cog and lock ring aren't tightened enough. Make sure to tighten the cog and lock ring as tight as possible
Likes For rewop12:
Clark W. Griswold
Quoted: 4357 Post(s)
Liked 3,994 Times
If you don't skid your undies, don't skid your bike. If you do skid your undies, learn how to wipe.
Some of those really cheap fixed gears don't take well to much use and abuse like that. I might pull it apart, grease it properly and torque it down right or have your local shop take a look.
Bikes: Soma Pescadero, Surly Pugsley, Salsa Fargo, Schwinn Klunker, Gravity SS 27.5, Monocog 29er
Quoted: 186 Post(s)
Liked 234 Times
You cog and lockring are not tight enough. If you do one good skid the way it is now, you will strip the threads off the lockring.
Location: Traveling through time, will return last week.
Bikes: Bare Rum Sword Knuckle Runner
Quoted: 278 Post(s)
Liked 122 Times
i would remove the cog and locking and inspect for any damage. if everything looks ok clean, grease and reinstall. next put front wheel of bike into corner, hop on and stomp down on pedal to really tighten down the cog, then tighten down the lockring. if it slips after that just ted shred or buy an e-bike.
Old fart
Quoted: 3590 Post(s)
Liked 3,400 Times
If you don't have a chain whip to properly tighten the sprocket, try the rotafix method:
https://en.wikipedia.org/wiki/Rotafix
More likely, strip the lockring threads on the hub, which, unfortunately, is even more expensive to fix. It's also possible that the OP is experiencing this issue because the hub is already damaged. Remove the lockring and sprocket and carefully examine the threads.
IMO, skid stops should not be your default method of stopping your bike in the first place.
Quoted: 2483 Post(s)
Liked 2,955 Times
I stripped the sprocket threads of the rear hub of my first track bike, in 1964 (I was 13 and didn't know that you shouldn't install a British-threaded sprocket on a French-threaded hub). The mechanic in the local bike shop wrapped the hub in aluminum foil and threaded the same sprocket back on. Worked fine.
I've had that story in my holster for a long, long time, waiting for a thread like this to pop up.
Likes For Trakhak:
Bikes: Panasonic Olympic Titanium Track / Colnago Master Pista / Bishop stainless-steel road / Specialized Tarmac SL5 / Vynl Cross / Geekhouse Wormtown 29er
Tighten the cog all the way down, then the lockring after
Not all the cogs are same
I once had the same issue after changing the cog. Tightening did not work. I was thinking to buy a new hub. Then i remembered there was a thin shim between the cog and the lockring. Solved it in a few minutes.
