New Carbon Fiber Fork Issues
Hi! So I just got a new Toseek carbon fork for cheap and after installing it, i can somehow hear “clicks/ticks” somewhere near the front. I’m scared that it might be the fork that’s producing the sounds. Are new forks supposed to behave that way?
Bikes: jamis 2002 komodo, univega aplina uno, miele toscana 300, 1972 puch brigadier, Marin Sausalito
Quoted: 18 Post(s)
Liked 17 Times
no, i have install 3 of those forks without issue other than the stem expander can be a little tricky to set up.
Quoted: 6963 Post(s)
Liked 10,961 Times
Had to look it up on the web...Looks like a very cheap fork, so there could be a problem with it. But the issue is more likely with your headset.
I agree haha just needed a lighter fork for commuting. I'll have my bike checked tomorrow regarding its headset. Thanks for the advice!
Advocatus Diaboli
Quoted: 4733 Post(s)
Liked 1,532 Times
Just to eliminate possibility, remove axle/skewer and make sure they're greased
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Hey there I just installed that same brand of fork on my MTB commuter about 2 months ago and has similar fitting niggles. What I found for me was that the disc brake caliper mount was too short, so the rotor was hitting the top of the inside of the calipers. My fork came with some washers included so I threw those on the mount and it solved the issue.
Link to pic: https://www.bikeforums.net/21986527-post15.html
Likes For nel e nel:
Clark W. Griswold
Quoted: 4349 Post(s)
Liked 3,986 Times
Commuting is rough on a bike, a lighter fork from random online shop is not a good thing and especially if it is making noise after you just installed it. I would make sure everything is properly installed and torqued and greased or carbon pasted as needed. Check wheels check all your bolts and carbon expander and if you cut down the fork at all making sure it was cut properly and not damaged on install.
