Titanium road bikes
Likes For aliasfox:
yep litespeeds are crap... just awful,, and ulgy... oh wait a min...
strike that.. they are pretty amazing bikes and i would buy another used one in a second.... big bang for buck and im a clyde and at 6,3 no washy BB no flex on the bike anywhere... just one hell of a great bike and dont know about ABG,,, i just know this bike is solid and its a blast to ride fast..
Likes For scuzzo:
pan y agua
Quoted: 1447 Post(s)
Liked 727 Times
Missed my point. It wasn’t about the bikes; it’s about the company ABG. I wouldn’t not buy a used Litespeed at the right price. I would never buy a new Litesped from ABG, with a price that factored in the value of a warranty that history shows they’ve failed to honor.
So if you can find a used Litespeed at a good price ( which in part be the result of the beat down ABG put on the brand) fine. But I stick by my point I would never buy a bike from ABG, and if you want a new ”Litespeed”, the best ones carry a Lynskey badge.
You could get lost and die.
You could hit a tree and die.
Likes For Litespud:
I used to ride a Tarmac. Now I ride a Synapse, but the "snap" just isn't there when I get on the gas. I bought it because of the taller head tube as I had back surgery.
I recently got a chance to ride a Seven 622S and a Lemond Ti and LOVE the way the road feels like honey, thus went down the rabbit hole of looking for a Ti bike. The T1SL has a tight back end (406mm CS, shorter than Tarmac/Cervelo R series!) with a neutral 73* HTA (less twitchy than Tarmac, prob same as Synapse, which I like), and a BB drop of 71mm (love the 70-72mm). I'm thinking this would equate to stable turning, with very good acceleration. Am I wrong?
There are not a lot of reviews out there on the T1SL, and most sing its praises with no negative points, so that makes me a little skeptical.
Quoted: 4407 Post(s)
Liked 4,860 Times
Liked 4,860 Times
Klaatu..Verata..Necktie?
Quoted: 10425 Post(s)
Liked 11,899 Times
Because the improvement over steel is not so huge that it justifies the big jump in price for people without deep pockets. I only bought a Ti frame because it's 27 years old and the seller didn't make it look all that great. You had to look under the clapped out components.
Quoted: 430 Post(s)
Liked 460 Times
I've seen weight limits for wheels but not for frames. I wonder what the ANSI test standards are for bike frames?
Liked 4,860 Times
But aside from cost, Ti doesn't tick every other box. You asked the question, so I gave you a couple of obvious "boxes" that it doesn't tick. Cost is another one, at least when comparing against other metal frames.
For me personally Ti does actually tick all my boxes, it's just that carbon ticks some of my boxes for a frame even better - mainly it's better stiffness/weight ratio in my case.
Quoted: 722 Post(s)
Liked 353 Times
glad you like the bike you ride....thats the goal.
Liked 4,860 Times
Quoted: 3241 Post(s)
Liked 2,512 Times
Added cost of those benefits is most likely the reason most don't go the Ti route. Same for most things. I detest the long throw of Shimano brifters. The price of electronic shifting means that's not an option either. I'll always be 2 or 3 Shimano systems behind so that I can use Microshift brifters (gasp). That's just me.
Advocatus Diaboli
Quoted: 4733 Post(s)
Liked 1,532 Times
If in an alternate universe, Ti was as easy and as cheap to make into a bike as CF is, then all the manufacturers would be marketing and selling Ti, and CF would be the more niche product. There is no margin in Ti (or decent steel) -- ask yourself why any large bike manufacturer doesn't even offer 1 model of Ti bike. A quick look at eg. Spesh's website indicates they offer 124 models of CF bikes, and 86 Aluminum. Really no room for just 1 Ti model?
Likes For Sy Reene:
Liked 4,860 Times
Advocatus Diaboli
Liked 1,532 Times
CF is neither easy or inherently cheap to make into a bike. It is very labour intensive, raw materials are expensive and requires very expensive equipment. Layup design is also very technical. If you were a one-man-band then you would actually find Ti easier to work with - as difficult as it is to fabricate. That's why you don't see many small outfits making custom carbon frames and the ones that do tend to work with stock carbon tube rather than full monocoque layups.
Probably a bad analogy, but maybe like comparing a Tissot $300 quartz battery watch with a $300 Tissot Automatic. Probably the Quartz watch keeps better time and probably has a better margin.
Quoted: 645 Post(s)
Liked 797 Times
My Litespeed is lightish but not super light (nominally 1350g for the frame), but a state-of-the-art 6/4 Ti frame in 2000. A friend brought his larger custom Ti bike (Kish, Carrboro NC - 3/2.5 Ti, built ~2020) around to my place for a bit of work, and when I lifted it onto the stand, I was amazed at how much lighter his bike was than mine (transient weight-envy, but I got over it). We have identical wheels and similar group sets (I have Chorus 10, he has Chorus 11). Ti fabrication has no doubt advanced in the 20-year difference between our bikes, but someone else suggested that mass-produced frames tend to be overbuilt because they have to conform to set standards - ANSI, for example - up to and including destructive testing, while custom frames don't have to. A custom frame can be as light as the builder thinks it can be for a given user/application, while mass-produced have to cater to the worst-possible situation (ie, the heaviest possible customer). My frame is likely way stronger (and heavier) than it needs to be for me. If you want to realize all the possible benefits of Ti - corrosion-resistance, comfortable ride and lightness - it seems that custom is the way to go.
Liked 4,860 Times
Custom is a different story. Scroll thru Aliexpress for an idea of rock-bottom costs. The cheapest ti frames are typically 3x that of CF. CF may be labor intensive but I imagine its lower-skilled labor assembling them. Ti frames look to be about $800-$1k, but finding sub $500 CF frames is pretty easy. There's nothing wrong with CF and it's a great material for bike frames, but I'd wager the margin on these is double what they could get on a Ti frame that they'd still be able to find buyers for without pricing out of the market.
