Tightening torque on horizontal dropouts - Pitlock question
PITLOCK Shop
Bikes: Soma Wolverine 3.0
Hi, I need your SS expertise. Does anyone out there know what the recommended tightening torque is for the nuts on a rear SS wheel on horizontal dropouts? I've searched the web, but I'm not finding anything. I'd like to know so that I can determine whether or not Pitlock skewers can be used on horizontal dropouts at their recommended max torque of about 8ft-lb while still keeping the wheel from moving and loosening the chain. This question was asked to me yesterday, and I couldn't answer. The locking 10mm solid axle bolts will take tons of torque (more than necessary), but the "regular" size sets have a maximum recommended torque.
Thanks!
Thanks!
Bikes: Track bike, road fixed, cross fixed, two single speed mountain.
Why not tighten down your regular SS rear hub to 8ft-lb and see if it slips?
antisocialite
Originally Posted by Urbanbiketech
bump - I'm still looking for the answer to this question. Anyone?
also a lot of old touring bikes use qrs on the rear wheel with horizontal dropouts. you'll probably be okay.
PITLOCK Shop
Originally Posted by dirtyphotons
not sure about the tech specs, but rivendell quickbeams all use quick release skewers with fork ends. seems a little sketch to me, but they know a lot more than i do.
antisocialite
Thanks for the info In that case, I guess the real question is whether the clamping force exerted by 8lb-ft of torque on Pitlock is equal to that generated by a quick-release lever. My knowledge of physics is limited to what I learned in grade 12.
best of luck.
Geek Extraordinaire
Bikes: Bianchi Advantage Fixed Conversion; Specialized Stumpjumper FS Hardtail
According to the park-tool website, shimano reccomends about 21 ft-lbs on their axle bolts, control tech reccomends about 5.
I'd rather have a bottle in front of me than a frontal lobotomy.
Sintesi Conversion Serotta Track
Taking "s" outta "Fast"
pitlocks aren't going to get tight enough in a horizontal slot to hold your wheel in place. It's been tried. The pitlocks are meant, like a normal QR, to hold your axle in a vertical dropout with enough force to keep it from falling downward with cornering/gravity. It's the frame itself that keeps the wheel from moving forward. They just don't allow enough clamping force.
PITLOCK Shop
In addition to wanting to use a pitlock, I don't want to carry arround a a 2-foot wrench in case of a puncture.
Old thread, I know, but - if the conclusion is that the pitlock isn't enough for horizontal dropouts, is there any fix that would correct this? e.g. could a chain-tensioner (i.e. that just keeps the wheel in place), so that a bolt providing a lesser amount of torque could be used to keep it in place?
Horizontal Dropouts?
I don't recommend a Pitlock rear skewer if your frame has horizontal rear dropouts. Horizontal dropouts require very high clamping force, otherwise the wheel will slip forward in the right dropout. Pitlocks are designed for vertical dropouts, which do not require high clamping force. The Pitlocks can't produce enough clamping force for a horizontal dropout. Think of them as comparable to aluminum QR skewers, which, as most people now know, can't be used with older bikes having horizontal dropouts. But with vertical dropouts, Pitlocks will hold your wheel quite securely in the frame. Don't worry.
I believe the limitation on the Pitlock is the skinny-ass stainless steel skewer. It just does not have the strength to hold the axle still. They warn against tightening it too tight.I don't recommend a Pitlock rear skewer if your frame has horizontal rear dropouts. Horizontal dropouts require very high clamping force, otherwise the wheel will slip forward in the right dropout. Pitlocks are designed for vertical dropouts, which do not require high clamping force. The Pitlocks can't produce enough clamping force for a horizontal dropout. Think of them as comparable to aluminum QR skewers, which, as most people now know, can't be used with older bikes having horizontal dropouts. But with vertical dropouts, Pitlocks will hold your wheel quite securely in the frame. Don't worry.
In the other hand, the typical fixed gear axel wrench like the 3wrencho
https://ridepdw.com/products/3wrench...t=24674533569#
is less than 6" long. You can get more than enough torque on a solid 10mm axle to hold the axle tight. Back in the day racing bikes had big ass wing nuts on the axles and they had enough torque to hold the axles against racing levels of torque. Throw a 3wrencho or a campy "peanut butter" wrench in your pocket and you are good to go.
Thanks. Well maybe I just need to apply a bit more force. I'll give it a go.
But in case that doesn't work (and it seems I'm not the only one in this position) - surely the clamping of the pitlock is done at the point where they meet the dropout: at that point, they can't fix the wheel in place firmly enough. But if the tension keeping the wheel in place is provided by something else, then that shouldn't be a problem. That's why I suggested using a chain tensioner, which is also called a chain tug - I don't mean the spring-type; just something that's inserted into the dropout to keep the axle in place. (I'll try sending a link, but when I last tried I wasn't able to because I hadn't posted enough.)
Quoted: 1188 Post(s)
Liked 1,154 Times
Thanks. Yes, that's the kind of thing I'm after. I think the Brick Lane one I posted the link to (I only just graduated to being able to do that) would do the same thing. (And I can pop down to the shop in London.)
You'll be fine using the pitlock with a tensioner.
A buddy of mine has been doing that with a disc wheel at the track for years. No problems.
PI
PI
Quoted: 4806 Post(s)
Liked 3,929 Times
Now, the details make a difference. Locknuts with a pattern that serve as teeth help. Bare steel dropouts are much easier to secure than chromed ones. I thought the ti dropouts of my custom would be a challenge, but they are not. I use the same wrenches and force. (And that bike has done some very serious climbing.)
Ben
Thanks all. 8" is the maximum length instrument I'd want to carry around with me, preferably much shorter.
So it's good to know that the chain tensioner route option should work - sounds more sensible, even if one can use brute force to tighten enough without it.
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
https://www.parktool.com/assets/img/...elp/torque.pdf
