Nexus 8 for touring
Nexus 8 for touring
I know there's been a lot of talk about the Rohloff for touring, but if you had a reasonably flat tour would you attempt it with a Nexus 8?
The few, the proud, the likely insane, Metro-Atlanta bicycle commuters.
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
Yes. My touring bike now has a Nexus 8 hub, with a gear range very similar to what it had when I rode it over the Rockies in 1983. Actually, the Nexus' range is a tiny bit wider. I also have it set up lower, because my riding style has, uh, matured.
Oh yes, no problems at all. I have done many short and long tours (off road/trails, Blue Ridge Parkway, etc...) with my Shimano Alfine (newer model Nexus-8). Don't sweat it. Remember that you can change the cog on it if you need lower or higher gearing. I ride mine everyday with 38/19, but when I did the Blue Ridge Parkway, I switched to 38/23.
38 / 23
72.01 Gear inches
63.3 Gear inches
54.6 Gear inches
44.6 Gear inches
38.0 Gear inches
33.4 Gear inches
28.7 Gear inches
23.5 Gear inches
Bikes: "Hildy", a Novara Randonee touring bike; a 16-speed Bike Friday Tikit; and a Specialized Stumpjumper frame-based built-up MTB, now serving as the kid-carrier, grocery-getter.
Quoted: 11 Post(s)
Is this on one of the folding bikes?
Tour Journals, Blog, ride pix
My bands:
My bands:
- Uke On! - ukulele duo - Videos
- Ukulele Abyss - ukulele cover videos - Videos
- Baroque and Hungry's (Celtic fusion) full-length studio album Mended.
- Artistic Differences - 8-track EP Dreams of Bile and Blood.
Quoted: 3470 Post(s)
Liked 1,475 Times
If you are planning for a tour, wheel size is a factor on gearing and we do not know your wheel size. Is the tour planned on flat terrain or hilly? How heavy is your load?
HI, I will be touring in Ontario Canada which has flat and steep rolling hills. The last ride I did with a 21 gear derailleur on a norco 26" with similar bike weight. I was using easiest gear at certain points to get up the inclines and hardest gear on the way down. This trip my ride is either going to be a 700c with shimano 8 IGH or a Nexus 7 on 26" wheels. I will be loaded front and back - tent, supplies, etc. for a month ride. I reckon with self around 250lbs (I'm 180lb) on bike. Thanks
