Giant Anthem Advanced vs. Trace Advanced
Old 07-04-16, 11:45 AM
Elzot
Bikes: Giant FastRoad Comax 1; Giant ToughRoad CoMax 1
So I have decided to add a MTB to my stable. I am trying to decide between the Giant Anthem Advanced 27.5 2 and the Trace Advanced 27.5 2. I know there are a lot of other choices out there, but these are what I'm deciding between. I was leaning toward the Anthem due to the greater suspension travel. However, my LBS advised against it because most of the trails in the vicinity are relatively tame. Nonetheless, I am still leaning toward the Anthem. Maybe I don't "need" the greater travel, but does it hurt to have it? I am not interested in be speedy. Other than the suspension (and the dropper, which I probably wouldn't use much) it looks like the main difference between the two is the top tube. The Anthem's is straight, while the Trance has an elbow. I don't know how much difference that makes. I have experience with both the SRAM & Shimano equipment. I find them similar enough not to be a factor. The price difference between the two bikes is negligible. Any suggestions? Thanks!
Elzot is offline
Old 07-04-16, 04:13 PM
Kindaslow
Kindaslow's Avatar
Bikes: SWorks Stumpy, Haibike Xduro RX, Crave SS
Quoted: 514 Post(s)
Liked 12 Times in 8 Posts
In most cases, more suspension travel leads to more energy needed to climb, especially within the same brand of bikes. I think that the suspension travel has gone a little crazy these past years, and led to some terrible bikes for a while, bikes that were truly one trick ponies. The newer bikes are not so limited, but I do believe that the shop has a valid point.
Kindaslow is offline
Old 07-05-16, 05:25 AM
Canker
Quoted: 330 Post(s)
Liked 209 Times in 133 Posts
I haven't ridden a giant with maestro rear suspension but it is suppose to be great. Around here I'd want the 140mm suspension and slacker head angle. I can and do ride a rigid here but when I really want to have fun I bring out my 150mm slack hardtail. 140mm really isn't that crazy anymore with the improvements in rear suspensions. They aren't just pedal bobbing monsters anymore. Now if it is basically flat where you live the 100mm would probably be more fun just because it will be lighter and quicker turning.
Canker is offline
Old 07-05-16, 06:46 AM
hig4s
hig4s's Avatar
Bikes: Evil Insurgent, Giant Stance, Wife has Liv Cypress, son has Motobecane HT529
Quoted: 93 Post(s)
Liked 7 Times in 6 Posts
OK, first I assume you meant Giant Trance, not Trace, and if you look at the specs, the Anthem advanced has 100mm suspension, (Anthem advanced SX still only has 120mm) the Trance has 140mm. So not sure what they are telling you?
Personally I think the Trance is much better than the Anthem, and personally I own a Stance 120mm and like the feel of it better than the Anthem also. Stance just is not available with a carbon frame.
hig4s is offline
Old 07-05-16, 06:58 AM
Trevtassie
Quoted: 1188 Post(s)
Liked 1,154 Times in 640 Posts
Different bikes for different uses. The Anthem is more of a cross country race machine, enough suspension to keep up speed over bumps. The Trance is a trail machine that can take the odd jump.
Trevtassie is offline
Old 07-05-16, 07:32 AM
NYMXer
NYMXer's Avatar
Bikes: Cannondale SuperSix EVO w Hi-Mod frame, Raleigh Tamland 1 and Giant Anthem X
Quoted: 352 Post(s)
Liked 8 Times in 6 Posts
I have the Anthem X 29 w the Maestro suspension and am very happy with it. I have learned to buy a little more bike than I need because as you get better, your ride needs will change. I don't think I ever heard anyone on a trail ride complain about too much suspension travel and that Maestro suspension is all it is supposed to be. Good stuff!
NYMXer is offline
Old 07-05-16, 10:35 PM
Pendergast
Quoted: 75 Post(s)
This video might be useful to you. It's from an experienced mountain biker who owns an Anthem and a Trance.
https://youtu.be/kvumgNNGsxk
Pendergast is offline
Old 07-06-16, 04:29 AM
Trevtassie
If you get the chance, remote lockouts are well worth it. The Maestro suspension is excellent, but even better using the full abilities of CTD shocks and forks.
Old 07-10-16, 06:41 PM
Elzot
Thanks for the input, everyone.
Elzot is offline
atallen223
Mountain Biking
6
03-08-17 08:41 PM
dmmoroney
Hybrid Bicycles
3
06-09-16 01:49 PM
kanoute696
Hybrid Bicycles
2
08-25-14 08:11 AM
Teagan
Hybrid Bicycles
3
07-01-13 11:38 AM
Innes
Mountain Biking
4
08-25-10 05:52 PM
