a question about the atlantis
Old 06-09-05, 10:03 PM
D.B. Cooper
friction baby, friction
D.B. Cooper's Avatar
i'm very close to ordering an atlantis. my only reservation is the fact that the fork doesn't have the upper braze-ons for low-rider racks, therefore i'll be forced to use a rack with a clamp instead. question...does this hinder the stability of the rack? has anyone had a problem because of this? it certainly seems that the folks at Rivendell know what they're doing.
D.B. Cooper is offline
Old 06-10-05, 10:04 AM
picturemaker
Atlantis rider
picturemaker's Avatar
Bikes: Rivendell Atlantis, Scattante Road 853, Nishiki
I use a Tubus Tara Low rider rack on my Atlantis. I bought some nice hardware for attatching the rack from Peter White Cycles but when I went to install the rack I didn't like the way the hose clamps pinched so close to the paint on my fork. So, I went to my local hardware store and purchased some rubber coated P-clamps. These are used primarily for attatching conduit pipes to the wall and the black rubber coating is for insulation. I purchased several sizes because I was unsure which size would fit snuggly around the fork blade. I have to tell you that they worked out magnificently. I have had no problems with any slippage or movement of the rack since day one. The rack is rigid and I have carried as much as 25lbs. of gear in the front panniers on several tours. Hope this helps you decide. The Atlantis is a great bicycle and I highly recommend it for loaded touring. If there were any drawbacks to the Atlantis, the lack of mid fork rack mounts is the only one.
picturemaker is offline
Old 06-10-05, 10:22 AM
roadfix
hello
roadfix's Avatar
Quoted: 195 Post(s)
Liked 117 Times in 53 Posts
Just wondering why no mid fork braze-ons? Is it due to mounting bolt location issues with different rack maufacturers?
roadfix is offline
Old 06-10-05, 01:36 PM
Kodama
Quietly Desperate
Kodama's Avatar
I have an Atlantis with the Rivendell/Nitto front rack. When I went to install that it was obvious why there are no midfork braze-ons - it wouldn't have intersected the mounting points in the rack. I used the clamps that came with the rack and they work great and it is incredibly stable. I haven't toured with it yet but I have done a bunch of riding with fully loaded front panniers on it - no issues at all.
BTW if you get your Atlantis custom painted like I did (and now Rivendell is getting half the frames unpainted and you can get a custom paint job for only US$100 more) you can arrange to have braze ons added. I personally would only do this if you intend to use a front rack that doesn't connect at the top, like the Tubus racks.
Kodama is offline
Old 06-13-05, 06:06 PM
canali
also grant on the website says specifically they don't have them on so that any one you choose will fit.
I am just getting my atlantis in a few months...can't wait.
For now I'm having plenty of fun with my Surly Cross Check.
canali is offline
