Changing timing chain
Old 07-22-19, 03:43 PM
124Spider
Bikes: 2016 Cervelo R3 2018 Rodriguez Tandem
Quoted: 127 Post(s)
Liked 3 Times in 3 Posts
Hi,
It's time to change the timing chain on our tandem.
I've changed many "normal" bike chains, but I just wanted to be sure that my thought of just using two one-speed chains for a timing chain makes sense.
Thanks!
Mark
124Spider is offline
Old 07-22-19, 07:22 PM
Carbonfiberboy
just another gosling
Carbonfiberboy's Avatar
Quoted: 3889 Post(s)
Liked 1,938 Times in 1,383 Posts
Before we switched to a belt, we used the same type that we used for the drive chain. That way one repair kit covers everything.
Results matter
Carbonfiberboy is offline
Old 07-22-19, 08:15 PM
124Spider
Quoted: 127 Post(s)
But the concept that one splices together two normal chains is valid?
Old 07-22-19, 08:56 PM
ahultin
ahultin's Avatar
Bikes: 2003 Cannondale Jekyll 1000, 2014 Fuji Finest 1.5 (wife), 2008 Fuji Finest 1.0 (Daughter), 2012 Fuji Cross 2.0 (son), 2011 Cannondale Road Tandem 2
Quoted: 57 Post(s)
Liked 27 Times in 17 Posts
More or less, as I recall, pre-belt, we used about 1.5 chains spliced together for the timing chain
ahultin is offline
Old 07-22-19, 10:44 PM
due ruote
due ruote's Avatar
Quoted: 904 Post(s)
Liked 527 Times in 320 Posts
That’s what we have done. If I recall, we used 6-speed chain, but maybe single speed would last longer? We have had no issues.
due ruote is offline
Old 07-23-19, 01:15 AM
Chancy
Bikes: S&S Santana Beyond & S&S Santana Arriva. Trek Domane 3.
Quoted: 26 Post(s)
Liked 14 Times in 8 Posts
124 Spider,
I would not use a single speed chain. Under load your boom tube will bow (slightly). Now your timing chain has to flex as it is engaging the rings. Multi-speed chains are made to run like this, single speed are not. There have been reports of single speed chains coming off the timing rings because of this bow/flex of the boom tube that puts the timing rings out of alignment.
Tailwinds,
Charlie
S&S Santana Beyond
When we used a chain, I went to an 8-speed chain because it was cheaper (at the time) than the 9-speed the bike came with. I carried an 8-sp & 9-sp quick link then.
Chancy is offline
Old 07-23-19, 09:03 AM
DCwom
DCwom's Avatar
Bikes: Burley Tandem
Quoted: 29 Post(s)
Liked 11 Times in 10 Posts
Same here, I matched the drive chain so I only had to worry about 1 size quick link for repair, the cost was not much of a factor to me compared to the hassle of dealing with 2 different chain sizes.
DCwom is offline
Old 07-23-19, 09:26 AM
Carbonfiberboy
Yes, that's what you have to do. IIRC, takes about 1-1/2 chains. Save the other half.
Results matter
Old 07-23-19, 03:32 PM
JanMM
rebmeM roineS
JanMM's Avatar
Quoted: 653 Post(s)
Liked 347 Times in 226 Posts
I've been buying chain by the foot for our recumbent tandem - the timing chain and the main chain are both long.
https://t-cycle.com/collections/chain-in-bulk
JanMM is offline
Likes For JanMM:
Old 08-31-19, 11:19 AM
Road Fan
Road Fan's Avatar
Quoted: 1858 Post(s)
Liked 664 Times in 506 Posts
Originally Posted by Chancy
124 Spider,
Tailwinds,
Charlie
S&S Santana Beyond
Is this caution recommended for all tandem frames? I could see it for a round boom or a square one, but mine (Meridian) is oval, twice as wide as it is tall.
Road Fan is offline
Old 09-01-19, 12:33 PM
Chancy
Quoted: 26 Post(s)
Yes. The tests were done before carbon fiber bikes, but all tubes flexed. Oval flexed the least, thus most tandem builders went to oval boom tubes. Also why Santana developed the "Z" coupler (initially for their boom tube), thus getting away from 2 round boom tubes (with small round S&S couplers) on their travel bikes. I would assume carbon fiber flexes too, but I do not know for sure as I only play as an engineer.
Mark Johnson, of Precision Tandems, once posted pictures to prove it. In the pictures his timing chain was taunt while they were coasting, and a had a belly on the bottom run as they were peddling.
Tailwinds,
Charlie
2016 S&S Santana Beyond (with an oval coupled boom tube)
Chancy is offline
Old 09-01-19, 02:56 PM
Chancy
Quoted: 26 Post(s)
Road Fan,
For pictures, go to www.precisiontandems.com scroll down the left side of the home page and click on "Tech Tips" then "Timing Chain Adjustment." Halfway down the page you will see the different pictures, peddling vs. coasting.
Tailwinds,
Charlie
Chancy is offline
mstyer
Tandem Cycling
1
10-16-13 10:04 AM
jacks1071
Tandem Cycling
20
09-26-11 06:05 PM
zonatandem
Tandem Cycling
7
09-25-11 04:57 PM
SvdSinner
Tandem Cycling
21
06-30-10 05:10 PM
lhbernhardt
Tandem Cycling
14
05-06-10 08:02 PM
