130 psi clinchers... e.g., Felt Speed AW 700 x 25
Has a quality floor pump become indispensable? If so, I can recommend Leyzne pumps.
Beyond Bogus
Quoted: 14458 Post(s)
Liked 2,836 Times
Super Moderator
Bikes: Giant Propel, Co-Motion Supremo, ICE VTX, ICE VTX WC
Quoted: 8067 Post(s)
Liked 1,562 Times
Ditto. Most rims won't handle 130 PSI over time.
Dennis T
Where there is a will, there's a way. Where there is no will, there's an excuse.
Beyond Bogus
Liked 2,836 Times
Quoted: 6554 Post(s)
Liked 49 Times
What is the point here, that your pump gets 130 psi? That you ride at 130 psi?
Any decent, no-name $20 floor pump from Nashbar or the like will get all the bike tire pressure you need with only tolerable effort, and it will last for decades with minimal or no maintenance.
I repeat, what's your point. Or as my highly respected colleague datlas, likes to say, "What's this thread about?"
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 6688 Post(s)
Liked 2,252 Times
I'm a Silca guy. I've had it up to 160 on a couple of sewups. That was a pretty solid ride.
Quoted: 26 Post(s)
My neck and wrists already hurt after I read the thread title.
Must be a Paris-Roubaix ride everytime you go out unless you ride on a NASCAR track.
just another gosling
Quoted: 2905 Post(s)
Liked 810 Times
Be that as it may, 130 is a bit high for 25mm. I used to run 140 lbs. in my 23mm Tricomps back when I rode a single on competitive rides. That worked well too. A good max pressure estimate is (tire width in mm) X (tire pressure) = 3000. Never met a rim that couldn't handle that.
BTW, 130 is the sidewall pressure on those Felt tires. However they're an inexpensive 320g tire and I doubt they'd be comfortable at that pressure. High pressure is more comfortable using tires with light sidewalls.
staring at the mountains
I run my 25s at 84-86psi... don't pump your tires to the max. that's not what it's there for.
Beyond Bogus
Liked 2,836 Times
I wish they could make a sticky that said "Max pressure is NOT ideal pressure," you know?? I blame our car culture as typically auto tires you do pump them up to max.
or maybe put that info on the inside of the sidewall, where mechanics would know to look (and that's it)
Anyone know what the TPI of the Felt's casing is?
Vittoria makes tires with posted 130 psi max pressure recommendations. It's new to me to see clinchers with numbers like these on sidewalls so I was interested to do a little web-based research.
An ideal tire pressure, according to Vittorria, is a function of tire construction (e.g., Nylon 127 TPI), type of tire (clincher), the rider's weight (e.g., 209 or more) and the type of road surface (e.g., dry/smooth). Vittoria has an App that uses this information, which they say applies to all tires).
Based on the above factors, Vittoria's App determines the beginning point. In their view, finding the ideal pressure, however, depends on riding style and simply trying it out in the field.
My guesses based on the App and that the tires accommodate 130 psi is that Felt's clincher probably is Nylon construction in the range of 127-150 TPI (e.g., they could be more expensive higher TPI tires and according to the app the starting point would then be a little less than the starting point below unless a radial construction is employed to fabricate the tire).
Assuming they're not 220 TPI tires, Vittoria's App puts the starting point for me at: 125 psi (FRONT) and 130 psi (BACK). For lighter riders and rougher or wetter roads the starting point will be less.
FLIR Kitten to 0.05C
Quoted: 2340 Post(s)
Liked 390 Times
It might also be the app's way of telling the people at Vittoria who wrote it, to check their math....depending on your weight.
And if you'd rather look into other belly buttons: Bicycle tire pressure calculator (though I think there's something seriously wrong with the first calculator's math; it tells me 183psi?)
Quoted: 63 Post(s)
Quoted: 2151 Post(s)
Liked 1,973 Times
I still don't understand the question or even if there was a question.
ka maté ka maté ka ora
Bikes: breezer venturi - red novo bosberg - red, pedal force cg1 - red, neuvation f-100 - da, devinci phantom - xt, miele piste - miche/campy, bianchi reparto corse sbx, concorde squadra tsx - da, miele team issue sl - ultegra
Quoted: 25 Post(s)
parsed:
1. lezyne pumps are great.
2. OP uses a lezyne pump to put too much air into his tires
your welcome
your welcome
Likes For pdedes:
Bikes: everywhere
Liked 2,252 Times
Not a question just a comment
Just tried my Felt 25 x 700 tires and rims on a ride. Bikes of this type mine is 58 cm are rated for 275 lb at most and I am 385 lb. You would think that would make the ride worse since the tires are all the way to 130 psi. Ride is phenomenal, More active than a passive mountain bike ride which keeps my head in the game so far. ( just getting reacquainted ) lets see how long until a blowout. still lacking some confidence obviously. Statement complete.
Bikes: 2000 Litespeed Vortex Chorus 10, 1995 DeBernardi Cromor S/S, Nashbar 3sp commuter
Quoted: 465 Post(s)
Liked 479 Times
Don't know where you get that idea - every modern car I've ever owned lists the recommended car-specific tire pressure on a sticker on the B column - completely unrelated to whatever max pressure is on the tire itself
Reminds me of the late 80s with 18-20mm tires and even then we are only talking about 110-120 psi while applying the notion of mimicking tubulars taken to extremes. I switch to 28s in 1989 (while still participating in collegiate racing) and keep them around 70-80 psi depending on how lazy I feel. Been run 25s recently because 28s was getting expensive all of sudden but still keeping them about the same pressure.
