Simplex SX410 interchange question and other ramblings..
Quoted: 637 Post(s)
Liked 1,281 Times
Well I've jumped into the world of French bikes head first it seems. Back in July I bought a rough '72/'73 Gitane Interclub, 2 weeks ago I bought a neglected but original '81 Peugeot PXN10 and last night I closed a deal on a rough PRN10 frameset and misc. pieces which included a rough looking but functional SX410 short cage RD. This morning I picked up a late 70's UO8 for parts with a claw mounted long cage SX410 RD and the rear wheel had been replaced with a Rigida black label 27 X 1-1/4 eyeleted aluminum rim on a QR Normandy high flange hub. My SX410 question is this, can I swap the mounting bolts between the 2 RD's and make the long cage a bolt on and the short cage the claw mount? I want to gear the PRN10 to handle the hills around hear without straining my already shot knees too much so I need the long cage for it and of course it has the infamous Simplex DO which I do NOT plan to modify. The short cage would get the claw mount and probably end up on the Gitane Interclub in place of the Chinese monstrosity hanging off it. Hey, it has a red pulley so it's at least "fast", I wonder if that red pulley will fit a Simplex?
Also, anybody out there have a matching orphan Rigida black label 27 X 1-1/4 eyeleted aluminum rim or front wheel with a QR Normandy high flange hub they want to part with?
Likes For oneclick:
Quoted: 5888 Post(s)
Liked 3,471 Times
So congratulations for joining the French bike club.
https://www.bikeforums.net/classic-v...nch-bikes.html
You have a bunch of options here.
1. Stronglight bottom brackets have excellent interchangeability with stronglight cranks. You could for example with your PXN 10 swap the 106 crank that came stock on it with a stronglight 99 and run a compact crank. Chainrings are available from Spa cycles in the UK plus second hand. I'm running 47/32 rings on a 99 on one of my bikes but you could go as low as 28 on the inside. Also the drop out on the PXN 10 will take a campy style derailleur if you like.
2. The PRN 10 frame would match nicely with a stronglight 99 crank. It came stock with a stronglight 49D crank I believe which also has decent interchangeability on rings but the a stronglight 99 will be easier to track down and rings easier to find.
3. I dunno if your attempt to swap out the mounting bolts on the two SX410 RDs will work. There are a few threads on this. My recollection is that the claw mounted simplex RDs will not work properly without the claw on a simplex RD. But why not just use long cage suntour or shimano RD on the PRN 10? Also if you have a shimano crane GS lying around, it will work on that simplex drop out.
4. The SX 410 can comfortably handle up to 30 teeth. That's what I'm running on my 1982 PXN 10.
Likes For bikemig:
Quoted: 637 Post(s)
Liked 1,281 Times
I don't have the short cage in hand yet but based on what I could see in pics and I parts breakdown I found a couple days ago, and now can't find, it looked like it should work but I've been down that road before on other things and they didn't work. And so far based on other experiences with French machinery I fully expect them to have made them JUST enough different it won't work LOL. Just looking for some confirmation.
Quoted: 637 Post(s)
Liked 1,281 Times
Responses in bold in the quote text.......
I hadn't mentioned it earlier but a Gitane Tour de France frameset may also be coming my way. That one may get my 1st gen. Shimano Crane RD, 1st gen. Dura Ace FD and 1st Gen Dura Ace freewheel but I also have Campy NR derailleurs, DT shifters and cable clamps in need of a bike to call home. The RD is already on a vintage claw adapter and while a bit of a kludge I read it can be mounted right over the Simplex DO. I figure that's more acceptable than hacking away at the unmolested Simplex DO.
Thanks.
1. Stronglight bottom brackets have excellent interchangeability with Stronglight cranks. You could for example with your PXN 10 swap the 106 crank that came stock on it with a Stronglight 99 and run a compact crank. Chainrings are available from Spa cycles in the UK plus second hand. I'm running 47/32 rings on a 99 on one of my bikes but you could go as low as 28 on the inside. Also the drop out on the PXN 10 will take a campy style derailleur if you like.
I had planned on keeping the PXN10 original except for a repaint and new decals since it has all it's original components and they are in very good condition. UO8's are common around here but P series bikes are not and to find one albeit with less than great paint but pretty much unmolested and in my size is pretty cool. I just went out and looked and now see the "notch" for the stop on mine, is it also threaded?
I have been toying with running TA Specialties Cyclotouriste crank arms with chainwheels salvaged form a Lambert on the PRN 10. I love the looks of that Lambert big chainwheel, if only they hadn't stamped "LAMBERT" in it....... The PRN10 is FAR from original and quite rough so I look at it as a blank canvas. It will most likely get a set of Suntour barcons instead of DT shifters as well.
The threads I have read all sounded like people were trying to just unbolt the claw derailleurs from the claw and bolt them directly to the braze on hanger using the existing hardware and no, that won't work. I just found the parts diagram and it shows both sets of hardware and judging by that I should be able to swap hardware between the 2. The mounting bolts are different lengths, the retaining "bolt" that comes through from the back is different and the direct mount RD has a "stop plate" or tab washer that goes on the back side that the claw mount doesn't have. Other than that and the claw they appear to be identical. Hopefully I'll have the other SX410 in hand next weekend and I can give it a try.
Good to know.
Thanks.
Good to know.
Likes For Murray Missile:
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
Otherwise, you can remove the pulley cages and swap them to convert a short cage derailleur into a long cage. I used a long cage from an SX-410 to convert a short-cage SX-660 into a long cage for my tandem:
Quoted: 637 Post(s)
Liked 1,281 Times
I suspect it will work, but keep in mind that the Simplex mounting bolt installs and removes from the back of the hanger, not the front as do most other derailleurs. The Allen socket on the front side of the upper pivot adjusts the upper pivot spring tension, and shouldn't be messed with.
Unfortunately the short cage RD I'm getting with the PRN10 has had a very rough life judging by the pictures the bike seller sent me and isn't too pretty. He assures me it is fully functional and cosmetically it will be a good match for the Gitane Interclub it will end up on which requires a claw mount. The Interclub will not be getting a cosmetic make over due to some hack installing a Wal Mart kickstand, apparently with an air impact wrench...... . The chainstays are dented in pretty badly on the bottom so it will just be a beater. The PRN10 is also rough where the paint and decals are concerned but is otherwise undamaged and if I like the way it rides it will probably get a paint job in a non-factory color and reproduction decals.
