Shifting Into the Small Ring
#51
"I take issue with the current standards."
"No, the current standards are good because they're the current standards!"
Even if I could see how your objection addresses the point, I would emphasize that, while the three crankset configurations you mentioned are the most common available on modern road bikes, they are hardly the only available. For example, Shimano's current lineup of high-end road chainrings does include a combination with a 12-tooth jump (54-42 for Dura-Ace FC-R9100) and one with a 10-tooth jump (46-36 for Ultegra FC-R8000).
As far as shift quality goes, it's certainly true that a well-adjusted FD paired to a well-designed 50-34 can make the shift consistently. But the shift is still large in ratio, requiring more compensatory shifts in back. And, for the upshift, it fundamentally takes longer for the shift to resolve because of how much rotation has to happen between the initial shift engagement and when the chain has been fully lifted into place. It's not illogical for someone to prefer smaller front jumps.
Likes For HTupolev:
#52
Batüwü Creakcreak
Quoted: 228 Post(s)
Liked 288 Times
I fail to see how current standards are relevant when addressing the actual point that trailangel was making, unless you're literally just appealing to the authority of what the current standards happen to be. But since the current standards are literally what trailangel is complaining about, this is a fairly circular objection. I mean, that would basically be:
If you want the range, there's a drawback that requires shifting maybe 2 cogs in the back to end up where you wanted to be. Can be done with one motion.
How much longer are we talking about for this inconvenience? If you want to talk about progress, it's a non issue with electric shifting. You can still pick the rings you want these days as well. Gravel cranks come stock with closer ratios but you give up the range. Triples have their own set of problems or nuances so to speak.
The ten tooth ultegra crank is usually installed in cross /gravel setups more so prior to grx. You can do just about anything if you're willing to live with the shortcomings. This idea of the shifting being so inconvenient is laughable though. It's a technique and tuning issue. 'stressing the gears' isn't really a thing anymore.
#53
Quoted: 892 Post(s)
Liked 2,053 Times
In a nutshell, OP has been provided options:
BF is life.
- Buy Di2, press buttons
- Buy a triple, shift rings without needing to compensate
- Buy a non-compact double, shift rings without need to compensate, with either less range or bigger steps than 2.
- Buy a 1x, just shift
- Or don't buy anything and:
- Stay in the big ring until your cadence is way down, then shift down to the small ring, or
- Eye the climb, pick your ring early, and shift cogs as needed
BF is life.
Likes For downtube42:
#54
Likes For Reflector Guy:
#55
Quoted: 6178 Post(s)
Liked 4,795 Times
Though some think Di2 handles the OP's question better. I currently find that my 105 5800 handled it exceptionally well and quicker by being able to drop the rear a couple or even three cogs much quicker than my Ultegra R8050 can.
But that might change, I think there is an adjustment in e-tube project that controls how fast the DR's move. I've just begun to play with that so I'll have to see if I can get it doing the required shifts on the rear as quick as they happened on my 105 equipped bike.
For the most part when dropping to the small front the rear shifts quick enough while in full syncro and my cadence and power output isn't affected. However there do seem to be certain times that for what ever reason it is an issue and I'm suddenly spinning too fast too long.
#56
Another technique that I sometimes use is to stay in the big ring, riding out of the saddle for awhile during the first part of a hill, then sit and quickly shift to the little ring. Quite often no compensating shifts are then needed. If I'm already in the little ring and decide to pedal standing, usually I need to shift one or two sprockets smaller, or my cadence would be too high.
Likes For DaveSSS:
#57
Quoted: 7649 Post(s)
Liked 3,465 Times
My personal solution has been learning how to use my transmission. But I understand that's not for everyone.
#58
Quoted: 4245 Post(s)
Liked 1,350 Times
Unless you are are some sort of monster, you should not need to be in the big ring in a "climb".
The basic idea is to set up the gearing before the climb so that you just need to use the rear derailleur. That is, you shift down in the front and up in rear to keep the same gear (usually, lower) when it's easy and you have time for slow shifts.
Shifting the rear derailleur is much faster and will tolerate shifts under load much better.
Likes For njkayaker:
Likes For AlanO:
#60
Same here. I shift front and back at the same time as a normal practice. When I shift from small to large ring, I always shift to the next larger cog in the rear. Eliminates the momentum loss that occurs when the effect of the large ring kicks in. Going from big to small ring, I'll dump one or two cogs in the rear simultaneously. Same effect in the reverse. Makes a big difference in maintaining speed/cadence.
Gary
Gary
Likes For gparr:
#61
I feel like this issue is the area where Campagnolo has the advantage over Shimano. with Shimano, you need to press and release the small lever 3 times to go 3 gears harder on the RD. this makes for at best, a clunky transition from big to small chain ring. Campagnolo allows a single sweep of one lever to change 3-5 gears in one press, making the simultaneous shift work very well. it was so easy to do naturally, I even taught my wife the fine art and she mastered it quickly!(I also don't like that fact that the shift lever is the brake lever for Shimano, but that is another issue.) I recently left Campagnolo for Shimano, but only for DI2, since EPS is WAY more $$ than I cold spare.
#62
Trying to keep up
Bikes: Pinarello Prince, Orbea Onix, Ridley Fenix
Quoted: 79 Post(s)
Liked 136 Times
I'm new to Di2 - only had my new bike for a little over 3 weeks (since Nov 20) / 400 or so miles. I've been playing with the shifting options and think I finally have it where I want it - it is similar to SRAM shifting where at a certain point when shifting the rear, it shifts to the big ring when moving to bigger gears or to the small ring when shifting to easier gears. I'm moving from 11 spd, 105, and this works wonderfully. Not surprisingly, the shift to the big ring and simultaneous move up 2 cogs in the rear (or down - 2 bigger cogs up) is very rapid. When shifting to an easier gear on hills, when it drops to the small ring and to a smaller cog in the rear, there is a momentary loss of power, but overall, it works very well. Definitely smoother than shifting under load on 105. The only difference is that I would do the rear shift first before dropping into the small ring, but that also disrupts momentum.
Tl;dr I am enjoying Di2 and it seems to solve this problem for me.
Likes For ericcox:
#63
You gonna eat that?
Likes For Doohickie:
#64
I've been 1X with my road bike for close to 3 years now and love it. Simple, quiet, cheap (in comparison with electronic)... you just go up and down with none of the hassle or noise of a front derailleur.
Some of the custom cassettes (12 gears starting with a 9 or 10 tooth) allow for a huge range in ratios and the steps between are close enough for me (commuter and tourer in his 60s).
#65
When it comes time for it, first upshift one ring in the rear immediately followed by the downshift up front immediately followed by another upshift in the rear. As rapidly in succession as you can. With practice this becomes really smooth.
And if you are running 50/34 up front consider replacing the 34 with a 36...
#66
So when I shift into the small ring in a climb, it's such a drastic change that I spin my legs like an idiot while I shift the RD back into a harder gear.
Is there a better technique to this? When I shift into the big ring, I simultaneously shift the RD 3 times and by the time it takes for the FD to get the chain on the big ring, I'm comfortably in a gear on the RD that makes it all a smooth transition.... Shifting in to the small ring... not so much; the change from the big ring to the small ring happens so fast that I don't have time to make the change on the RD (without stressing the gears by shifting under power).
To make matters worse, it's usually when climbing up a hill and I lose some amount of momentum doing it.
Any tips on shifting to the small ring efficiently for a climb?
I don't know how you do it, but I press both levers at the same time and I manage to click the RD shifter 3 times, if needed, before the chain has fully engaged the small chainring.
I'm running a 50 / 34 SRAM Rival 22 groupset BTW. I don't know why there's so much hate to that combination here. It provides great range and, at least on my bike, shifts well.
Likes For Amt0571:
#67
Pointy Helmet Tribe
Bikes: R5, Allez Sprint, Shiv
Quoted: 519 Post(s)
Liked 627 Times
You could create a 1x road bike by putting on a 1x groupset and whatever chainring you want. But you are going to have to want to live with pretty large jumps between gears. To me, that's a solution looking for a problem.
#68
Campy's new 1x13 Ekar gravel group could certainly be used on the road, but there are some larger jumps between gears. The 9-42 cassette has a 467% range. I have seen single speed time trial bikes built for relatively flat terrain.
My current bike for the mountains has 15 distinctly different gear ratios and a 552% range. I use a 46/30 crank and 10-36, 12 speed SRAM AXS cassette. This combination will work with either Campy 12 or SRAM AXS shifters and deraileurs. If more top gear is needed, a Chorus 48/32 crank will give the same top gear as a 53/11, with 540% range.
#69
Quoted: 590 Post(s)
Liked 445 Times
I realize it "can" be done, but was wondering why it isn't done on a major brand? The large jumps don't seem to be an issue for gravel and mtb riders. I'd be willing to give up "some" top end speed, while maintaining my low climbing ratio (34/32) if it meant the improved reliability and cost savings of no FD.
#70
I don't see the benefit (other than esthetics) of a single ring on a gravel bike. Any weight you save in the front gets added back with the big/heavy cassette in the rear.
I have a 48/31-11/34 GRX. On the flats, I ride mostly 48 in 21, 19, 17 (2.3, 2.5, 2.8), closer to the middle of the cogs, with 3 gears for tailwinds/drafting/descending. If I had a, e.g., 40 tooth single chainring and a 11-42 cassette, I'd be mostly riding 18, 15, 13 (2.2, 2.7, 3.1). That's leaves you with 1 gear for tailwinds/descending and pretty cross-chained when there's no need to be. If anything, I'm thinking of switching the cassette to 11-32 or 11-30. On the other end, I have 31/34 (0.9) for grinding which is close (but still a little better) than 40/42 (.95, which is almost identical to 31/32). To each their own, and I'm sold on 1x for bikes with suspension, but I don't see it for a gravel bike much less a road bike.
Likes For xseal:
#71
bike whisperer
Quoted: 1523 Post(s)
Liked 716 Times
All that tooth profiling allows the chain to remain engaged throughout the shift. Depending on which point around the cassette it happens, it can result in the release of some portion of a link's worth of chain if it's coming off a bigger cog, but the chain is pulling on the cassette the whole time.
HG was the single biggest drivetrain improvement there will ever be. All subsequent improvements depend on it, since it also facilitated indexing that actually works.
Sheldon Brown's bike info ~~~ Park Tools repair help
Half-step triple, using double gear ~~~ 6400 STI rebuild walkthrough ~~~ Want 8/9/10s @126mm OLD? OCR. ~~~ Shimano cassette body overhaul ~~~ Ergopower Escape wear repair ~~~ PSA: drivetrain wear
List of US/Canada bike co-ops ~~~ Global list
#72
Quoted: 20808 Post(s)
Liked 9,450 Times
Likes For WhyFi:
#73
Liked 3,465 Times
36T max with a 1X? Not sure how that is going to work on gravel .... Not at all, for me, but you guys are all 400-watt monsters, I guess.
#74
Liked 9,450 Times
Also, 36t on a 1x gravel bike? Very uncommon. 42t is far and away the most common and Shimano doesn't even offer anything smaller than 40t, IIRC.
