glass shard in tire (no leak): leave it or take it out?
LR÷P=HR
Quoted: 867 Post(s)
Liked 1,205 Times
1. Are you sure you have sufficient sealant in the tire.
2. Is the sealant fresh ( My definition..... < 3 months old )
If the shard was only toothpick sized and not a sidewall, I’d expect the patient to make a full recovery.
Barry
Barry
LR÷P=HR
Quoted: 867 Post(s)
Liked 1,205 Times
Rema TT13. Bit like a regular patch for a tube, but reenforced specifically for tubeless repairs.
Barry
Expensive.....yes
Used often..... No (just as well)
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
I saw a TV program where the doctors had to decide whether to remove a bullet that was perilously close to a patient's spinal cord. Leave it in, and he could become paralyzed (or not). Attempt to remove it, and he could become paralyzed, die from complications, or make a recovery. I was entranced.
This thread has been like that. Except for the dramatic music, of course...
Likes For Phil_gretz:
Likes For Hit Factor:
Quoted: 6963 Post(s)
Liked 10,964 Times
Think of it as a wound that never heals. An object in a tire with sealant is going to move every time the tire rolls over the object. It opens the gap and allows air to escape as well as letting more sealant escape. The hole never really seals.
Remove the object and the hole seals properly.
Likes For Koyote:
Sealant (Stan's) is six months old, installed by LBS.
Liked 2,972 Times
time to add more stans in it.
-Oh Hey!
-Oh Hey!
LR÷P=HR
Quoted: 867 Post(s)
Liked 1,205 Times
I draw mine out every 3 months and replace with fresh.
I live in CA which is a little "arid".
Barry
On Your Left
Quoted: 3004 Post(s)
Liked 2,433 Times
The Stans instructions state... "Will last 2-7 months, depending on conditions. For best results inspect sealant every 3-4 weeks. Arid climates and storage areas may require more frequent replenishment."
Barry
Barry
On Your Left
Liked 2,433 Times
Clark W. Griswold
Quoted: 4356 Post(s)
Liked 3,994 Times
- $4k submitted to World Bicycle Relief - good suggestion and a worthy cause, thanks.
- Attempted $4k deposit to your PayPal account but received error message: "Sorry, that account has been temporarily locked pending investigation of possible fraudulent activity. PayPal regrets the inconvenience."
- Invested some of the $4K I tried to send you (you sneaky rascal, you) on a six-pack of locally brewed, hand crafted and curated Sound Sound Porter. Nice strong chocolaty overtones and a strong malt finish.
Glad you enjoy the the beer.
Liked 2,972 Times
UPDATE:
First I appreciate all the suggestions that have been offered. I read each and every one and considered them all carefully.
After yet another (nearly) sleepless night pondering this dilemma, this morning I decided to test the old dictum "The Enemy Of Good Is Better." So I went to the garage, strapped a headlamp on my forehead, procured a pair of fine-tipped forceps, and pulled the little glass shard out of the tire. It was a small bugger, about the size of a wooden toothpick head. As soon as I removed it there was a hiss of white liquid air- sealant. This did not stop. I attached the pump and kept re-filling the tire to a pressure of about 30 PSI, while orienting the puncture side down so that the sealant inside would pool over the hole and (I hoped) plug it. But the hissing and bubbling continued. For about five minutes, Then it stopped. I pumped the tire up to 50 PSI (My riding pressure) and the leak resumed, but only for a minute or so.
It's been three hours and on repeated pressure checks the tire has remained at 50 PSI.
I am looking for some SuperGlue to instill into the tiny crack in the rubber.
Tonight, I will sleep well.
Thank you.
Thank you.
LR÷P=HR
Quoted: 867 Post(s)
Liked 1,205 Times
Just let the thread die. 40+ posts on a piece of glass no bigger than a toothpick.
What, are you all hunkered down and stuck at home!
Barry
On Your Left
Liked 2,433 Times
Liked 2,972 Times
because mamma mamma mamma said the glass shard is the devil.
-Oh Hey!
-Oh Hey!
On second inspection, it was not a glass shard at all - it was plastic. Should I have removed it? Could it have been left in? Plastic will, eventually, wear down and degrade, yes? Maybe that was the correct thing to do, I don;t know. Hope to hear everyone's comments and suggestions. Thanks!
Likes For Helldorado:
Liked 10,964 Times
