Hints and tricks thread
Old 12-11-20, 11:41 AM
  #726
dmattushik
good vid
dmattushik is offline
Old 12-24-20, 06:57 PM
  #727
capnjonny
capnjonny's Avatar
Quoted: 339 Post(s)
Liked 631 Times in 229 Posts
I often repaint bikes. I take off whatever chain stay protector is there if it is chewed up. Most are made of some kind of tape. On the Fuji I just finished I was trying to think of something I could use instead of buying one. looking around the shop I saw some heavy duty duct tape on the wall. This isn't the light weight grey stuff. it is much thicker and sturdier. The Problem was how to cut it to size and shape . this tape sticks aggressively and if you stick it to itself while handling you are finished. What I needed was something I could stick a length of tape to, cut it to a tapered shape so it would fit the tapered chain stay , then be able to peal it off once it was cut. What I found that works is parchment paper, which you can find in the grocery store . it is used in baking. The duct tape sticke to it so it can be cut then easily peals off without loosing its stickiness. It worked great and should be very durable.
capnjonny is offline
Likes For capnjonny:
Old 12-27-20, 07:25 PM
  #728
capnjonny
capnjonny's Avatar
Quoted: 339 Post(s)
If you are having trouble removing the plastic covers that hide the crank spindle bolts try squirting some wd40 into the slot then use the edge of a park mini cone wrench as a screw driver to twist the cap off. I don't know how many of those old brittle plastic caps I have ruined before I thought of this. Also, it you have the kind of spindle that takes a bolt instead of a nut there is a type(I think it is shimano ) that takes an Allen key and has a rubber gasket on it . looks great and you don't need to find a plastic cap.
Old 01-03-21, 08:58 PM
  #729
Miele Man
Quoted: 1324 Post(s)
Liked 927 Times in 640 Posts
Back in the mid-1980s I made a tool for removing slotted crankarm covers. The tool was made from a T-shape piece that came with rear racks to stop the rack from sliding down the seatstays. It bolted to the front of the rack and t o the rear brake bolt. That tool still resides in my bicycling tool box and still gets used a fair bit.
Cheers
Miele Man is offline
Old 01-26-21, 12:21 AM
  #730
woodcraft
woodcraft's Avatar
Quoted: 1814 Post(s)
Liked 923 Times in 569 Posts
Here's a few:
Motor casing to hold tools. Larger one is from a garbage disposal. Not everyone likes this as it magnetizes the tools a bit.
Sprayer head on alcohol bottle for utility cleaning. Threads & sizes are pretty standard.
Master link tool from old wire stripper. Posted previously.
Vest wrapped with piece of latex tube. Makes it small and not slippery so it doesn't come out of jersey pocket.
Cassette tool handle from PVC pipe. Heat fitting with heat gun to soften and press over tool.
Glue brush stored in can.
woodcraft is offline
Likes For woodcraft:
Old 01-26-21, 10:50 AM
  #731
curbtender
curbtender's Avatar
Quoted: 1604 Post(s)
Liked 2,564 Times in 1,214 Posts
I use the alcohol sprayer for hood and grip removal and install.
curbtender is offline
Old 02-03-21, 09:15 PM
  #732
jonkang
Saved this! Thank you!
jonkang is offline
Old 02-03-21, 09:16 PM
  #733
jonkang
Originally Posted by Le Mechanic
Presta valve tips, tricks, and hacks video if you're new to this style valve:
Saving this video, thank you!
jonkang is offline
Likes For jonkang:
Old 04-22-21, 12:14 PM
  #734
NoWhammies
NoWhammies's Avatar
Quoted: 800 Post(s)
Liked 512 Times in 306 Posts
Not my hint/trick, as I read about this in a post about tyres. But I thought I'd re-share it here.
For tyres that are difficult to mount, let them sit, unboxed, out in the sun for a bit. I did this for my most recent tyre and the heat from the sun combined with the darkness of the tyre allowed it to be mounted much easier than straight out of the box.
NoWhammies is offline
Likes For NoWhammies:
Old 04-26-21, 11:34 AM
  #735
capnjonny
capnjonny's Avatar
Quoted: 339 Post(s)
3 M 90 spray adhesive lives in my shop and has many uses. When I want to mount cheap bar tape( without adhesive) I take a small bit of aluminum foil and put it inside a large mouth jar cap forming a dish,. then I spray a bit of contact cement in the dish and use a q tip as a brush to spread a ribbon of glue on the handle bars. At the levers I cut a small piece of bar tape and paint the back side along with the bottom of the lever clamp . this holds the bar tape while I wrap the bars.
Another use for the tinfoil cup is for touch up paint. I have lots of partial cans of Rustoleum spray paint in different colors. To touch up a paint job take what ever colors you want to mix together to achieve a match and spray a dollop in the cup then take a paint brush and mix them together till you get a good match.
For touch ups you need a sharply pointed brush, preferably sable . I will take a small one and carefully trim the bristles till they form a point. This makes it easy to touch up small chips without getting any on the original paint. Even a close match works pretty well if it is confined to the chip or scratch. Solid colors are much easier to touch up than pearls or metallic paints. With dark colored frames it is sometimes better to use black as a touch up paint. On dark blue for example it practically disappears.
Old 12-19-21, 08:35 AM
  #736
Le Mechanic
Le Mechanic's Avatar
Bikes: 2020 Pivot Vault, 1983 Rossin Record, Garneau R1, Mesamods home built gravel/rain commuter bike, 1995 Barracuda A2V modified with Surley single speed dropouts, 1969 Bottecchia junkyard special fixed gear, Cervelo P4, Mesamods 650b klunker
Quoted: 96 Post(s)
Liked 72 Times in 50 Posts
I made a short video of a front derailleur hack I've been doing for the last few years. I came up with this idea to mimic the structural stability of Shimano Di2 and 11 speed group front derailleurs that have a support screw and backing plate installed. Older front derailleurs, primarily those with braze on type mounts and carbon fiber frames. The improved shift performance from the small to big ring is pretty dramatic.
Le Mechanic is offline
Likes For Le Mechanic:
Old 02-09-22, 05:11 AM
  #737
zorkist
Quoted: 10 Post(s)
Liked 23 Times in 14 Posts
My trick to replace metal components with carbon fiber tubes.
And replace cable end crimps with rivets, so it's way earlier to pull with bare hand.
zorkist is offline
Likes For zorkist:
Old 02-12-22, 08:07 AM
  #738
easyupbug
Quoted: 566 Post(s)
Liked 559 Times in 403 Posts
https://youtu.be/uSkwjZ8vWUY
Great thread, I have done something similar on two bikes with the bottom bit of these hammer handle wedges, had to file some as they are not pecise to get a good fit, seemed to help:
easyupbug is offline
Likes For easyupbug:
Old 02-12-22, 09:41 AM
  #739
elcraft
elcraft
Quoted: 144 Post(s)
Liked 103 Times in 72 Posts
any particular source for Carbon Fiber tubes?
elcraft is offline
Old 02-12-22, 03:23 PM
  #740
RubeRad
Keepin it Wheel
RubeRad's Avatar
Quoted: 26 Post(s)
Liked 3,413 Times in 2,522 Posts
My guess was they were tent poles, or from tent pole replacement/repair kits
RubeRad is offline
Old 02-14-22, 12:10 AM
  #741
zorkist
Quoted: 10 Post(s)
They are quite accessible from online traders.
zorkist is offline
Old 03-06-22, 08:16 PM
  #742
SteveInConverse
Bikes: Trek
Quoted: 21 Post(s)
Liked 23 Times in 15 Posts
Originally Posted by Newspaper_Nick
. Eventually you will find the spot and the brakes won't rub. So much easier than readjusting the brakes.
Holy crap...this was my problem yesterday 😂 Thank you!
SteveInConverse is offline
Likes For SteveInConverse:
Old 03-14-22, 10:55 AM
  #743
Nate8727
Nate8727's Avatar
Bikes: 2021 Trek Verve 1 Disc
Quoted: 11 Post(s)
Liked 23 Times in 9 Posts
On the Instep Double Seat Bike Trailer:
Wrap the spring in the hitch connector with a layer of bar tape or electrical tape. Remove it completely first.
It starts rattling and the tape fixes the issue.
I thought my bike was making noise until I found that little gremlin.
Nate8727 is offline
Old 05-04-22, 10:10 AM
  #744
zacster
Bikes: Kuota Kredo/Chorus, Trek 7000 commuter, Trek 8000 MTB and a few others
Quoted: 22 Post(s)
Liked 459 Times in 361 Posts
I just posted this in a regular thread but I think it counts as a hint or trick.
This is my trick for getting even tight tires onto a rim, usually without tools. The trick is to not do the last bit opposite the valve but at 90 degrees to it, and have the opposite side as far into the middle groove as possible to give you just a little more length to get over the rim, and that goes for taking off or putting on. The valve prevents the tire's bead from going into the center groove.
On the left is the correct way, with the blue tire all the way in the groove and slightly stretched with the stem at 90 degrees on the left. On the right the tire is in the bead and can't stretch over the rim with the stem in the way. Green is outer rim, red is the bead channel and the black is the inner groove. Not all rims are like this though with the center groove but it may still make it easier.
zacster is offline
Old 07-22-22, 11:58 AM
  #745
willydstyle
Quoted: 225 Post(s)
Liked 54 Times in 33 Posts
I had a leaky presta valve core, so I removed the core, put some grease on the threads, reinserted the core and then wrapped the core/valve stem junction with a single layer of Duck Tape. It's working great, no more slow leak!
willydstyle is offline
Old 07-24-22, 06:18 AM
  #746
Apetimberlake
Quoted: 14 Post(s)
Liked 7 Times in 3 Posts
I carry a claw hammer on me while ridding. Just incase anything kicks off.
Apetimberlake is offline
Old 07-24-22, 09:23 AM
  #747
zacster
Quoted: 22 Post(s)
Try using plumber's teflon tape. It should work better even. But that begs the question, why not just replace the core. They don't cost much at all. I bought a box of 10 for $10, including the tool.
zacster is offline
Old 07-26-22, 07:38 AM
  #748
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 3580 Post(s)
Liked 3,393 Times in 1,927 Posts
Or salvage them from old tubes.
JohnDThompson is online now
Likes For JohnDThompson:
Old 11-21-22, 08:52 AM
  #749
grumpus
grumpus's Avatar
Quoted: 470 Post(s)
Liked 422 Times in 322 Posts
That's fine if you can show that you're going to/from a job that requires a hammer, or you just bought/borrowed it, otherwise it's "going equipped for theft or burglary" or "possession of an offensive weapon in a public place" depending on the mood of the police officer who stops you. Better to have something that can be concealed on the bike, or that has a bike-related application, if you must carry something.
grumpus is offline
Old 01-10-23, 10:47 PM
  #750
bluemule
Bikes: Bridgestone MB5; Dahon Speed "Trio"
Quoted: 8 Post(s)
Liked 7 Times in 5 Posts
Shimano Nexus 3 speed bell crank cable install: popsicle stick 3rd hand
Installing a new shift cable in the bell crank for a Shimano 3 speed hub, it takes three hands to hold the cable snug, tighten the clamp bolt onto the cable and also hold the bell crank push rod arm in position so the yellow mark is between the yellow set lines on the housing window. Tape three popsicle sticks together and slip the end of the stack into the bell crank housing to shim the arm into position. Add some folded paper in the stack to fine-tune the thickness. This will free you up to work on the clamp bolt with the wrench while pulling the cable snug.
bluemule is offline
