Convert Fixed to single speed PLEASE HELP
Likes For jeffreydeguia:
Quoted: 41 Post(s)
Liked 28 Times
Info you will need is whether they are road (caliper) or mounts for V-brakes or Cantilever.
For Caliper you will need the distance from the fork mounting hole to the rim (converted to mm), then buy the correct "reach" for the fork & brake stay in the rear.
Also you need to match the brake lever pull distance to the type of brake.
Good luck!
I'm not a brake aficionado. The general or mechanics forum might be able to help more.
Good luck!
Good luck!
